Alabama S2000 Owners Club Areas including Huntsville, Birmingham, Florence, Decatur, Anniston, and Tuscaloosa
S2000 Spring Rate & Sway bar rates
Old 06-23-2012, 06:26 PM
jeallen's Avatar
Default S2000 Spring Rate & Sway bar rates
Thread: https://www.s2ki.com/...ension-springs/
Link to pdf: https://drive.google.com/file/d/0Byx...VnRnQ4WXc/view
Summary of spring rate findings:
| Front Rear | Front Rear
Model Year | Spring Spring | Sway Bar Sway Bar
2000-2001 | 219 291 | 393 427
2002-2003 | 246 309 | 300 396
2004-2005 | 262 278 | 300 311
2006-2007 | 262 269 | 300 311
2008-2009 | 280 294 | 354 311
2008-2009 CR | 384 343 | 392 362
Note 1: All figures are in lb/in. Divide by 56 to get kg/mm.
Note 2: Edited 17Nov2010 with slight updates to spring rates per rev1 of paper.
Nfsryder (09-10-2020)
Old 06-23-2012, 06:48 PM
jeallen's Avatar
I especially like the chart of spring rate color codes:
Old 06-24-2012, 05:38 PM
neptuner's Avatar
Thanks for the info John. This is good stuff.
Old 06-24-2012, 06:00 PM
RedCelica's Avatar
Wow...should have bought an '08 :/
Old 06-24-2012, 06:34 PM
jeallen's Avatar
You can usually pick up set of OEM shocks on ebay or in the for sale forum for around $200.
Old 06-25-2012, 11:33 AM
Reckon's Avatar
Good data to have.
Old 01-17-2014, 11:11 AM
95maxrider's Avatar
So if I wanted to run a S2000 in B Stock class for Solo, and I didn't want to get a CR, it looks like the best combo of non-CR factory parts would be the 08/09 springs combined with either 00/01 or 08/09 sways. Not that you can do that of course, but theoretically, that would be a good setup, right?
Old 01-18-2014, 05:40 AM
Kermdaddy's Avatar
I'm not up to date on the new stock class rules since I don't run stock class anymore (and the new r-comp vs. street tire thing). Used to you could only run stock spring that came on your MY year car. You could run any damper, but had to use the stock springs. So if you had an 05 you had to use the 05 springs. That rule could be different know. Those who run stock class could chime in.
Bars were the same except you could change one. If you ran an aftermarket front sway, you had to run the stock rear sway (again same MY) or vice versa. If you are doing sway bars just bite the bullet and get a Gendron FSB. It is well worth the money and one of the biggest performance per $ you can get for the car.
Old 02-19-2014, 11:47 AM
95maxrider's Avatar
I'm pretty sure the same rules still apply. So it sounds like the 08/09 cars will be the best setup from the factory (excluding CR) for events like Solo, right?
Old 02-19-2014, 11:57 AM
Kermdaddy's Avatar
Yes,
But I'm not familar with the new stock class rules. Springs might be open now, IDK. With an adjustable FSB it is a wash on the bars. To be honest, higher end shocks can be valved to make up for the lower spring rates.
Quick Reply: S2000 Spring Rate & Sway bar rates
