Arizona S2000 Owners Arizona S2000 Owners. s2000arizona.com
Brake Caliper Tool Recommendation
Old 05-30-2016, 06:33 PM
Skrily's Avatar
I don't change my rotors I just swap pads for track days.
Old 05-30-2016, 09:41 PM
dc2-2-ap1's Avatar
It is always recommended to swap rotors. Pads work best with a transfer layer applied. It is very difficult to get a transfer layer to lay down properly over the layer of another pad (bedding). That is why it is always recommend to resurface or scrub the rotors prior to a pad swap. You should be fine if you go fairly easy at the track or your pads are not overly aggressive.
Old 06-01-2016, 01:32 PM
leshiro99's Avatar
http://minkara.carview.co.jp/en/user...2909/note.aspx
I made a write up for rear brake pad replacement a while ago. Hopefully your google translate works well. haha
Old 06-01-2016, 04:21 PM
Skrily's Avatar
Hahaha
Old 07-09-2016, 12:57 PM
AZS2KDancer's Avatar
The free deaership inspection said my rear pads were at 4mm. At what point should I replace them? The front pads were measured at 7mm.
Old 07-09-2016, 07:48 PM
peiserg's Avatar
For street driving your fine
Old 07-10-2016, 09:23 PM
Thanks, peiserg, I'll keep an eye on them. The dealership wanted to replace them, of course. I'm trying to see if I can get financing and the car ready for some HPDE this fall, so I don't want to run too low.
SDueces
03-02-2014 09:24 PM
llckll
11-09-2013 08:33 AM
stainbow1
05-15-2004 05:15 PM
S2K_LA
03-07-2002 10:43 AM
WillErickson
01-21-2001 08:36 AM
Quick Reply: Brake Caliper Tool Recommendation
