My detailing Tips...
#51
1) What are the brushes you would recommend for cleaning the top?
2) Am I correct in saying that when something needs to be applied, I should use a sponge and something needs to be wiped, a towel should be used.
3) What products do you use to apply the 303 on the top?
4) What product is best for cleaning the seats using lexol.
Thanks!
Thanks!
2: That's a little bit too general. You're going to find that there are lots of different tools to solve each job in a bunch of different way. It's going to come down to what exactly you're looking too do.
3: 303 Cleaner, I use the 303 itself, and a sponge or another wash mit for the top. Soak it down, spray it all over the wet top, and scrub. After you're done washing and drying the car you then use the 303 protectant. Spray it on to a towel folded in thirds and then apply it from the towel. It will take multiple passes to get everything even. Remember to coat the front most portion of the soft top that's inside the cabin. That portion is exposed to the sun when the top is down or the hardtop is on.
4: I use a microfiber waxing pad. The pad has just enough of a nap to help get dirt out of the pores in the leather without being aggressive enough that it will damage or mark the leather.
El Borracho Chino
08-16-2013 09:24 AM
