2007 NFR Build
#121
How was the fitment on the Q300 / did you get a model specifically for the 06-08?
I had a lot of fitment issue with the 60RS on my 06 since they didn't design the 60rs for the 06-08 exhaust tunnel and subframe.
Car looks good by the way!
#122
And for anyone else wondering, I paired this exhaust with my invidia test pipe and I have ZERO drone. Maybe it's because I was use to the n1 but I am in love with the sound, I am working on recording some sound clips!
#125
Thanks man! only thing I've debated is putting the oem mirrors back on just to rock them for a bit lol but other than that, exterior wise I think I am done. That is ofcourse unless a set of 17x10 ce28s pop up for a good price lol
#126
No real updates as of late, put back on my OEM mirrors for the time being:
And I also decided to make a custom intake after seeing countless post from other users claiming them to work well:
For anyone interested I am using the following parts.
3.5inch 2' 90 degree aluminum pipe
3.5 to 2.75 inch silicone reducer
3.5 Fujita filter with built in velocity stack
Uniseal 1/4inch fitting for iat sensor
Universal fitting for valve cover breather hose
Fabbing custom heat shield to wrap with the infamous "radmat" insulation material.
Will post pictures once I am finished with it, as well as an updated Dyno plot to sort of compare what the t1r and intake combo makes vs the Invidia and stock modded box.
#127
Here is a picture of the finished product! As you can kind of see I also did the tb coolant bypass mod since I wanted to remove the bracket anyways, car started right up, normal idle and operating temperatures and the intake worked perfectly as well! Butt dyno gives it a
Future plans after the holidays is to finish fabing up the heat shield and hop back on the dyno.
#129
