Automotive builds Got an automotive build you want to want to document? Post it here!
daily driven Track car Build--Ap1
Old 01-20-2017, 01:28 PM
  #61
willix231's Avatar
Originally Posted by Singh_snisen
U might need a major roll but I think it should fit.
Yeah im going to roll it for sure. thats not hard at all. I already have a roller and know how to do it on my own.I might have to run alot of camber to clear though even after that. I had to do the same thing to get the rears to fit on the mazda lol
Old 01-27-2017, 02:38 PM
  #62
willix231's Avatar
Finally installed the speakers
And a modifry dash mounted cell phone holder
Received a set of these in the mail. Oem remanufactured injectors
Old 02-11-2017, 10:03 AM
  #63
willix231's Avatar
Havent updated in a while, finally got the upper ball joints on the front. put new brake lines on and blead the whole system out. I have never in my life seen brake fluid this dirty. Its amazing how much people ignore small things sometimes
Brake fluid was so dirty it looked like oil.SMH
Got my alignment done thanks to the recommendation of YamahaSHO
His friend at Superior Honda of Omaha Took care of me
BEFORE
FRONT AFTER
REAR AFTER
the drives straight so im happy with the alighnment. I wont really know how this does till i get on track with new tires and take some temp readings
yamahaSHO (02-11-2017)
Old 02-11-2017, 01:17 PM
  #64
Singh_snisen's Avatar
That fluid is darker than Pepsi. Hopefully it didn't damage anything
Old 02-11-2017, 01:24 PM
  #65
willix231's Avatar
i dont think it damaged anything.it was more fine dirt and discoloration due to age. i have put some cheap fluid in for now to "wash out" the system for now before i drain it again and put in the brembo fluid. something ive noticed alot now is that everytime i install SS brake lines on a car the pedal changes feel alot. the initial travel of pedal is soft before getting hard and bitting. it changes the feel of the pedal and you have to readjust but its actually better for heal toe.
Old 02-11-2017, 06:23 PM
  #66
yamahaSHO's Avatar
A reverse bleed should solve the initial softness. I pretty much always reverse bleed anymore, especially if I've swapped lines or calipers.
Old 02-11-2017, 06:27 PM
  #67
willix231's Avatar
How does a reverse bleed work? and now its actually perfectly fine and firm. I have no idea why it was a bit mushy right after we just bleed the new cheap fluid in.
Old 02-11-2017, 06:29 PM
  #68
yamahaSHO's Avatar
Reverse bleeding pushes fluid up through the bleeder. It helps get air out of the lines as it travels up more easily than down.
Old 02-11-2017, 07:11 PM
  #69
willix231's Avatar
Hmm, sounds interesting. I usually go for a regular gravity bleed then a pressure bleed into a bleeder bottle ensuring that there is fluid in the line to the bottle so no air return back into the caliper. I make sure to keep the bottle at a height higher than the caliper that way fluid is always sitting right at the bleeder and air wont go back in
Old 02-17-2017, 05:42 PM
  #70
willix231's Avatar
Recently dropped off he car to get some body work done. Had rust by driver side door and decided it was time to get it fixed and take care of most of the annoying dings all over the car. also had the front emblem on the bumper shaved
Previous owner left holes in trunk from a wing. Got those filled in
front emblem shaved
Quick Reply: daily driven Track car Build--Ap1
