Automotive builds Got an automotive build you want to want to document? Post it here!
DIY F24 build
Old 02-21-2016, 04:15 PM
Bad1flip's Avatar
Nice progress sir. I hope it makes some nice power
Old 02-21-2016, 09:07 PM
Soviet's Avatar
I have this kit sitting on my garage waiting for a reason to install it. I love DIY and aspire to build my own motor someday. This is my kind of build. Subbed.
Old 02-22-2016, 01:11 AM
jonner's Avatar
Keep up the good work....
Old 02-22-2016, 03:13 AM
RWDlover's Avatar
All nice and clean, but are you sure you should have done than with the bores? If i were you, i wouldn't touch the bores at all
Old 02-22-2016, 04:52 AM
s2000ellier's Avatar
I am not sure at all! I got the advice to do that from Jason at CNCSpeedshop.
Old 02-22-2016, 08:17 AM
starchland's Avatar
Looks good I hope this works out for you. Ap2 motor right? How did you use the hone tool in a drill?
Old 02-22-2016, 08:26 AM
the donor long block was a 04 F22c that was turbo charged for like 50000 miles but had something like 80000 miles total. the crank and rods were perfect too. So if worst comes to worst I'll rebuild another motor with that 2.2L crank/rods and my AP1's pistons.
I used an electric variable speed drill on the middle rpm range (1500 rpm?). 10 passes each bore. used 1/4th of a quart of ATF per bore to keep things lubed.
Old 02-22-2016, 08:31 AM
SlowTeg's Avatar
Originally Posted by s2000ellier
plastigauge is another tool, the primary tool is a micrometer and bore gauge. if you read the honda service manual all they mention is plastigague! check out section 7, its all plastigague haha
rods
When a friend used to build engines all he'd use was plastigauge and it seemed to do the trick, just like the honda service manual suggests. I don't remember hearing about a spun bearing, and my motor lasted 30k+ miles (b series) before cracking a sleeve (completely unrelated).
I've never tried manual re-honing a cylinder by hand to try and clean it up, but it probably can't hurt as long as it's done right. The big problem with the F series is the damn special coating..
Old 02-22-2016, 09:35 AM
King Tut's Avatar
Very interesting. What whp are you hoping to get out of this setup? You stepping up to TT3 with Ian and I?
Old 02-22-2016, 10:19 AM
No idea on the power, was going to build a TTB points car but now that B is going away not sure where i'll end up. See how TT4 shakes out I guess.
Quick Reply: DIY F24 build
