JustinSour's 05 Berlina BilleD Updated MRacing door mounts
#122
Thanks Andrew. I believe the pads are a few mm thicker compared to stock caliper but not 100% sure. Ohlins arrive today with my new steering wheel. These overseas vendors ship very quick. I'm not sure why I would want to pay top dollar over here and wait 3-6 months for a container to come in. Unless it's big parts. Toda throttle body should be arriving next month. Can't wait to see that gem
#125
Wheel arrived so I decided to put together a little test fit. Looks great, I'm going to have to experiment with this 325mm. Kind of small, but I'll wait until I get it in the car.
#126
Wheel setup looks awesome. I've had a 320mm wheel and the only time I found it annoying was at parking lot speeds. And to me it just doesn't look as at home as a 350mm wheel.
Where did you get the Type-S button?
#127
Your right Steve. The small wheel looks a bit odd. Swapping a wheel is probably the easiest mod to do. I ordered the button from Japan. New in bag. Theyre out there
#128
FedEx finally delivered one revised set of dfv's. Revalved for 13/12k swift springs for my application
Packaging was top notch and I can't believe how nice these are. I'm happiest about the aluminum shock bodies instead of steel. Can't wait to dial these in. Thinking of going 10mm lower then the recommended setting
