InTheRough's AP2 Build
Hey all,
I have been into trucks for so long that I realized that I needed some thrill in my life. It has been 10+ years since owning a manual transmission and, after waiting 1.5years for Magnuson to release a SC for my Tundra, I decided it was time to shift my focus to something else.
Year: 2004
Title status: Rebuilt
Miles: 53,500
Currently has:
Kraftwerks SC (cogged; installed Dec 2018)
AEM V2 EM
Skunk2 4Bar MAP sensor
Radium High Flow Fuel Rail
Radium Fuel Pressure Dampener
AEM FUEL Pressure Regulator
Grams 1000cc injectors
Billman TCT
Skunk2 Alpha headers
High flow cat
Tanabe Medallion dual exhaust
Competition Stage-4 PP & 6-puck sprung disc
Competition Ultra Lightweight Flywheel
AP2 Clutch Delay Valve (CDV) delete
Ballade CF hardtop (glass w/ defrost, tint, lock)
J's Racing wing (not installed)
HKS Hipermax IV GT
Hasport Race (70a) differential mounts
AP2V1 wheels w/ 20mm spacers
Pioneer stereo w/ kicker speakers
35% tint
Dynamat sound deadening
Euro floor mats (like new, removed)
Paint correction & ceramic coating (done 6/2020)
Current project:
Build roll bar
Carbon fiber
New side markers (on the back burner)
Future plans:
Joying 8.8 Inch Single Din stereo & rear camera
Depo tail lights
Replace the AP2V1 wheels (I may just paint them for now)
BBK
Swap Kraftwerks SC for SOS (or at least replace the cogged belt with the ribbed belt replacement)
Possibly Ford 8.8 3.73 Trac-Loc Diff swap (really just a spare in case I trash the stock diff and I already have it from my Datsun build)
I have CNC Plasma & Router tables as well as finger & tube benders so I look forward to modifying/building some parts myself. I have built some parts from fiberglass in the past and will attempt some CF resin infusion for some small parts at some point.
Year: 2004
Miles: 53,500
Currently has:
AEM V2 EM
Billman TCT
High flow cat
HKS Hipermax IV GT
35% tint
Current project:
Build roll bar
Carbon fiber
Future plans:
Depo tail lights
BBK
I'm working on doing the first bit of maintenance.
Starter has been removed and ready for replacement. I picked up a Reman Denso starter but, after doing a bench test, I found that it had issues right out of the box. I have another on order. I plan on removing the CDV, swapping the clutch set and flywheel. Once I have everything buttoned up, I will be doing a valve adjustment, oil change, and Billman TCT some time late Nov.
I'm sure that this isn't the best option for mounting but I really needed to get the top off the car to get working on it. I originally set the top on two saw horses spaced with a furniture blanket but my 2yo son rans past it almost daily and I didn't want him to knock it off so I was in a bit of a rush to get it moved. I used these . Making sure I hit the studs, I used two - along with the screws pictured - to mount them approximately 34" apart. The two hooks grab the primary support bar at the bottom of the rear window; it doesn't touch the window at all. I may reconsider the mounting application but I didn't want to mount it in a way that touched the seals in any way. If I do keep this mounting option, I do plan on applying some sort of soft barrier between the drywall and where the top touches.
Thanks! Both are a work in progress. I am glad to be getting some work done on the S2K. I couldn't even walk through the garage without stepping on something a month ago.
The following 2 users liked this post by InTheRough:
Luder94 (11-11-2021),
rush2redline (11-06-2021)
InTheRough (12-03-2021)
Well that took longer than expected... It is hard to get something like this done when I only have about an hour or two of free-time on an average day.
I really had a hard time getting the subframe and transmission low enough with the supercharger in place. Being new to S2k & boost, I didn't feel comfortable removing the supercharger to accomplish this task so I made due with the space that I had but it was a PITA. I hope I don't have to do that again for some time or I will have to learn to be comfortable removing the SC. Everything went relatively smoothly with the exception of the release bearing falling back into the pressure plate while I was trying to align the bellhousing. I didn't noticed until I had everything snugged and tested the clutch slave functionality. I found the issue as I heard a 'click' sound when the clutch was fully depressed. The 'click' was the fingers of the pressure plate rubbing on the small lip - or flange - that was supposed to sit outside of the fingers. After removing the bellhousing and realigned the release bearing everything went back together nicely.
In this stage of maintenance I completed: (Mileage - 54,038)
Clutch Delay Valve (CDV) Delete
Competition Ultra Lightweight Flywheel (2-669-STU)
Competition Stage 4 6-puck sprung ceramic clutch and pressure plate (8023-1620)
OEM Pilot & release bearings (91006-PCX-008 & 22810-PCY-003)
Shift lever rebuild (54111-S2A-003 & 54110-S2A-003) & re-grease (08798-9002)
Denso Reman Starter replacement (280-0316)
Flywheel Comparison w/ OEM pilot bearings: (185.375oz [old] vs 139.5oz [new] = 45.875oz less [2lb 13.875oz])
Pressure Plate & clutch disc w/ OEM release bearing: (222.75oz [old] vs 229.125oz [new] = 6.375oz more)
I read a lot of discussions regarding Loctite on the flywheel and pressure plate. I hope I don't regret the decision but I did end up using Loctite 2422 High Temp (650f) Medium blue. I used this because nearly all of the references of 'why not to use Loctite' only mentioned the fact that the trans temp will make Loctite gummy while this should hold up to the heat.
I just ordered a Billman TCT. Once that is received, I plan on doing an oil change, valve adjustment, and TCT replacement.
I obviously don't have a need for this just yet but I couldn't pass up this authentic J's Racing wing that popped up locally. I plan on picking up a trunk off of a parts car or CF trunk before mounting it. I will have to figure out what to do about the S2K specific trunk plates; it didn't come with it.
I understand the stands need to be tall for track functionality but I'd like to make a set of low stands for street use; like what is pictured below.
