Automotive builds Got an automotive build you want to want to document? Post it here!
My Suzuka 2004 AP1 S2K build-up
Old 07-12-2016, 06:11 AM
gusbo's Avatar
On with my build. I didn't like how the licence plate looks attached to the bumper, so I decided to get a motorcycle plate holder with adjustable angle and move it to the vent area. I can fold it all the way up in case of a track day.
On one weekend I had some adventures. Welds holding the oxygen sensor let go on my Megan test pipe and it started bouncing off the ground. I had to do something about it to be able to go back home. Found a ditch and crawled under the car... don't try this at home - scary AF.
Later I received a set of clear diffuser for the headlights. By coincidence one of ballasts died and I had to take care of it anyway.
For some reason on of the tail lights wasn't sealed properly and there was moist and a lot of dust inside it. So I decided to take those apart too. And so it became a horror two weeks long story of silicone abuse to my hands and a test of my patience.
I had to add something from myself so I decided to change some bits on the front:
I cut the amber part out of the diffuser:
Here's a "naked" tail:
I thought about how to make the tails look as OEM as possible and decided to use clear diffuser out of AP1 tails. It's now nearly OEM clear tail light:
And the fronts:
OK, OK, and the fronts:
I'm happy with the all clear look now. Stay tuned
Old 07-14-2016, 07:23 PM
Photo's Avatar
Gotta say... One of the best looking Suzukas I've ever seen. Amber-less tail lights look amazing too. How does the AP1 clear diffuser fit in the amber part of the AP2 tails? Or did you cut it?
Old 07-15-2016, 01:56 AM
gusbo's Avatar
Thank you! I had to trim about 1,5 inch of the diameter of the AP1 diffuser to fit it inside the red "ring". I made sure it sits there tight and then had some plastic glue on the inward edge. You can see it better here:
And a tail light without a lens:
Old 07-15-2016, 04:02 AM
Vagelis's Avatar
very well executed
Old 08-09-2016, 09:45 PM
gusbo's Avatar
It's time to clean up my engine bay. I bought a set of Z-Spec fasteners in dark blue color and decided to go with black / blue/ silver theme. It will be carried over to the whole car. I still need to paint the valve cover and put on a cooling plate and such.
Here's what it looked like versus now:
Old 08-10-2016, 08:43 AM
Vagelis's Avatar
what brand are your side diffusers?
Old 08-10-2016, 10:04 AM
NNY S2k's Avatar
Looks great, congrats on the nice work you've done
Levi
Old 08-10-2016, 03:38 PM
uh0h50's Avatar
Very cool build!
Old 08-11-2016, 08:36 AM
Micalbertl's Avatar
this thing looks fantastic . makes me almost want ap2 headlights because of how those clear lenses look
Old 08-17-2016, 01:20 AM
gusbo's Avatar
Thanks guys!
These are ABS replicas of Spoon diffusers, painted Honda Quantum Grey.
It's a really hard color to build a car's look around. I decided I have to go a little more aggressive on the setup to pull it off. Here's a drawing showing how I envisioned it:
The final outcome will be a little different however as I already have an OEM bumper shaved and APR lip waiting to be sprayed. Wheels are also on order. They will be Work instead of planned Advans though.
In the meantime I got a cool mileage number:
and a pic from a weekend trip:
Quick Reply: My Suzuka 2004 AP1 S2K build-up
