o_O S2000 | Mk I — Stage II
#2461
With the car setup as is the reduction in lift up front is definitely apparent. The car feels drastically more stable at high speeds (100+mph). I think the front end and hood both contribute to this, as well as moving to a square setup. The hood was quite a big surprise, particularly how much of an affect it has on the car under high speed turn in. The stability of the car also went up just from changing the ride height as well. With the car setup as it is now, it should be very easy to add rear aero and maintain good balance. I know I could get more front downforce with a larger splitter, but with an appropriately sized rear wing the car would still be very well balanced and still quite quick. The goal is to make it quick without getting ridiculous. As the lift in the rear is reduced more I have the sway bars to help dial in the balance. I think even as is the front end might be producing a small amount of downforce at speeds above 100mph. It's amazing how stable the car is even when hitting a bump or something at 120+mph, it just doesn't budge. When hitting those same bumps at that speed with no aero at all the car was definitely more frantic.
#2462
Originally Posted by andrewhake
You asked me a technical question over PM and I didn't answer it because I just don't like either of you. It's not the end of the world. Nothing to be hostile about.
Anyways...I am about to pull the trigger on the ASM hood from a local pending he still has it. Think it has the same results as the Amuse?
#2464
Originally Posted by andrewhake' timestamp='1451957018' post='23843739
Why not one of these?
http://www.gotuning.com/product_info...oducts_id=1116
#2465
I don't like you so I unfortunately I can't be bothered to answer your question.
#2466
I am most definitely not in IT. I don't like you so I unfortunately I can't be bothered to answer your question. If I was being hostile I would find your build threads and make it a point to regularly post dipshit comments that in no way contribute to the discussion.
But in all fairness, I have asked pertinent questions, touge questions aside. I do read your summaries and find them quite intriguing and insightful. Just take my comments with a grain of English cynicism. I understand that sometimes it can be lost, but all in all its a compliment.
#2467
Hi Andrew,
I might have missed it going through all 99 pages of your build.
Did you ever get tuned with the mugen intake and your exhaust? What did you put down? I read that you also have a header you were going to put on. Is that happening any time soon?
With the snorkel, do you find that the filter gets dirty more frequently?
Great info by the way! I love your in depth and thought out reviews.
#2468
In regards to the ASM hood. I would imagine the Amuse hood has a little bit larger of an aero effect simply because it has a wider and taller vented area, but I would guess the ASM hood still provides a useful benefit.
#2469
Hi Andrew,
#2470
Do it!
