Automotive builds Got an automotive build you want to want to document? Post it here!
o_O S2000 | Mk I — Stage II
Old 02-11-2016, 11:00 AM
  #2521
jst2878's Avatar
That bumper is beautiful. They don't offer a dual exit?
Ze40 in your spec is face 3. 9.5 +40 is face 4, not so bbk friendly
Will fit 328mm and above. Not fitting spoon, js, urge ap racing
Old 02-11-2016, 11:19 AM
  #2522
andrewhake's Avatar
Originally Posted by sillyboybmxer
I like how most of the muffler is hidden (until that bumper goes on!!)
And the tip fills the hole ;-/
I almost feel my Urge exhaust is too loud plus i dont like how it hangs by the differential. It seems too low.
The Amuse looks to be tucked up high like oem. Bulletproof said i could get euro s without a resonator or a different one than standard, but im wondering how that would sound. Could be an expensive mistake
The things I try and justify!!!!
I am actually considering making a resonator-less version with the current one I have, so maybe just wait until I do that haha. It is quiet enough that I sort of want a very loud, light and angry one and nice calm one for the street.
Old 02-11-2016, 11:23 AM
  #2523
evoq007's Avatar
See if you can find a place to add/remove a resonator with v-bands to quick swap between quiet/loud
Old 02-11-2016, 11:28 AM
  #2524
andrewhake's Avatar
Yep they offer a dual exit as well. The lower piece is easily removable so I would guess one could acquire both lower sections for dual/single options. Ah yes the +40 is face 4. They are clearly fitting it with a BBK, they are actually running larger front and rear rotors on that car. +40 is pretty aggressive, I don't see why they would have any problem fitting a BBK. People fit BBK no problem with 17x9+40 CE28Ns. Every wheel design is pretty different when it comes to caliper clearance. I guess smaller diameter rotors could be an issue but who knows. I am sure I will be happy with the +47s.
Old 02-11-2016, 11:52 AM
  #2525
//steve\\'s Avatar
The ZE spoke design even with face4 should offer a lot more clearance than an equivalent CE.
Old 02-11-2016, 12:56 PM
  #2526
andrewhake's Avatar
I would rather have two separate exhausts because it motivates me to buy more S2000s.
Old 02-11-2016, 04:35 PM
  #2527
jst2878's Avatar
Still. On 300mm bbk, there is no clearance for the ze40, ce28 on a 9.5 +40. That's what stopped me from getting a set. But it would of filled my fender nicely, however, I'll take the weight savings for now
Old 02-11-2016, 04:40 PM
  #2528
andrewhake's Avatar
It's funny that I will sort of end up with CE28N and TC105N and the wheel that is essentially right in the middle of those two in terms of design with the ZE40.
Plan is to test fit the new bumper this weekend. And get the new support and plate bracket mounted. I think I am going to mount the plate bracket with my trusty rivnuts instead of the included rivets so I can easily switch back to the OEM bumper if it is needed for whatever reason. I am going to have the paint shop paint the rear of the car behind the bumper black as well so should be easier if they can remove that bracket after I install it.
Might even pop on the Spoon mirrors so I can see how they look in black.
Old 02-11-2016, 07:00 PM
  #2529
blueprint's Avatar
As always a quality build and a top notch build thread.
Good work Andrew.
Old 02-11-2016, 09:18 PM
  #2530
arsenal's Avatar
Originally Posted by blueprint
As always a quality build and a top notch build thread. Good work Andrew.
Agree. One of the nicest builds on here.
Quick Reply: o_O S2000 | Mk I — Stage II
