Automotive builds Got an automotive build you want to want to document? Post it here!
o_O S2000 | Mk I — Stage II
Old 02-18-2017, 05:11 AM
  #2971
Orjinal's Avatar
Those parts looks beautifully crafted!
Props to you for doing a high quality build.
Old 02-18-2017, 07:12 AM
  #2972
tama05's Avatar
Haha I knew you had to have still gotten this! It almost seems like you have to run the diffuser with the rear bumper, the two go perfectly together. I want to see how you end up trimming the diffuser for the exhaust, I eventually want to run this bumper/diffuser combo as well, but it will be years before that happens.
To to change the subject from your badass parts inventory, do you see any issues with running the ASM TB spacer with a Toda TB versus an ASM one. Both pieces have very similar designs but I haven't seen anyone running that combo. For me, it's $300 saved over the ASM TB so I figured I would ask you about it.
Old 02-18-2017, 08:31 PM
  #2973
andrewhake's Avatar
The ASM version of the TODA throttle body is a slightly revised design:
I believe it also has refinements made to the throttle shaft as well so all the mounting hardware sits flush. I believe they had TODA make revisions to accommodate the spacer.
Old 02-18-2017, 09:27 PM
  #2974
Bullwings's Avatar
So? do you have a street car or another mode of transportation aside from your feet?
Once all that stuff goes on, the car is going to be obnoxious as a DD based on the wrong kind of attention it may draw...
Old 02-18-2017, 10:02 PM
  #2975
andrewhake's Avatar
Ok old man. :P
The wing can be removed in 4 bolts, and my car won't really look much different than it does now. I have no intention of daily driving it to work with a large wing mounted on back.
Old 02-19-2017, 12:49 AM
  #2976
Mike RT4's Avatar
This takes love for a car to a whole new level
Old 02-19-2017, 08:08 AM
  #2977
sillyboybmxer's Avatar
Are you leaving the underside of the wing exposed and painting everything else on the exterior side? Maybe the inside of the end plates as well?
just saw in Sept. the carbon doors are gonna be available again. Get on that too!
Old 02-19-2017, 07:23 PM
  #2978
andrewhake's Avatar
The underside of the wing or trunk? The only things that will be painted are the outside of the trunk and the duckbill, and I think I am going to leave the trailing edge of the duckbill in exposed carbon similar to what bouford did on his blue car.
Wing and wing stands I plan on leaving all in dry carbon. Might look into having the various bits wrapped to protect it a bit. I like the idea of the wing remaining all carbon though.
Old 02-19-2017, 07:24 PM
  #2979
andrewhake's Avatar
Evo SS GoPro gimbal
o_O S2000 | Mk I — Stage II - Page 18 - S NI SEN
Got a 3-axis gimbal recently to mount inside the car. Works quite well, and the thing that really sold me on it is being able to just reach back and triple press a button to have it rotate around 180 to capture what is behind me. I am often trading lead and follow back and forth with friends so this is a great way to deal with that.
It is mounted on the shorter Modifry camera mount that can easily be clipped on to the main Modfry wind screen mount.
I am using this model - https://www.evogimbals.com/products/...-hero5-cameras
Old 02-20-2017, 05:48 AM
  #2980
ALBERTS2K's Avatar
This is the guy I bought my previous CE28's from. Looks good everything painted, except leaving the Gernby flap and the end mounts of the wings dry carbon exposed.
S1 S2 (02-20-2017)
Quick Reply: o_O S2000 | Mk I — Stage II
