Project Hondatsun (F20C Swapped Datsun 510) - S2KI Honda S2000 Forums
Old 11-08-2016, 11:27 AM   #1
Default Project Hondatsun (F20C Swapped Datsun 510)
I guess it is time to start a build thread. A) So I can keep track of everything I’ve done, and B) So I can leverage the knowledge of the community!
History: I’ve owned two S2000’s (among a lot of other cars), both AP1’s. So the F20C is nothing new to me. About 4 years ago I started an Exomotive Exocet. For the past 3 years I’ve driven, and tailored the Exocet into what I wanted it to be. I just recently sold it to get funds to buy a house. If you care to view that build thread it can be found here:
Because I can’t leave well enough alone, and because I love projects I’ve bought a Datsun 510 that needed some love (and was pretty cheap).
It currently isn’t running, but it does have a ‘heart of gold’.
The car has been around the block, meaning under the owner from yesteryear once had a F22C in it. The car was then stripped and sold to someone else. That person then installed a F20C swap and then abandoned the project. The swap was performed by T3 (Techno Toy Tuning), who is a well known Datsun Tuner/Parts Manufacture. The swap was done correctly, and I understand that the person that has done the swap has done a few F20C swaps in Datsuns and AE86’s.
Now that brings us to present day. I’ve sense altered the header to clear the steering box. The header then runs to a muffler that is in the rear part of the passenger seat, and side exits on the drivers side.
What the car needs:
New fuel system. A fuel cell, pump, filter, and lines.
All safety related items replaced; seats, harness, steering wheel/hub, new front suspension
A new radiator, either custom, or making a s2000 radiator work
Custom driveshaft
Clutch lines, and brake lines
Some sort of intake
Lights; headlights, and turn signals
Wiring altered
Some sort of interior revamp; will likely start with lizard skin sound and heat control, and then go from there.
I’m sure I’m missing many things, but I’ll cover that as I move through the process! Anyways, I look forward to posting a lot and gaining knowledge along the way. I’ve already determined some issues that I’ll likely post about soon. Thanks for reading!
StedFast is offline   Reply With Quote
The Following 3 Users Say Thank You to StedFast For This Useful Post:
blixhavn (11-30-2016), Grip Hrd (11-20-2016), Kenny_Stang (11-09-2016)
Old 11-08-2016, 11:35 AM   #2
Very cool, subscribing to the thread for updates.
Kenny_Stang is offline   Reply With Quote
Old 11-08-2016, 12:23 PM   #3
TsukubaCody's Avatar
VERY cool.
TsukubaCody is offline   Reply With Quote
Old 11-08-2016, 06:43 PM   #4
In for the updates. Nice projects!
sirbikealot7 is offline   Reply With Quote
Old 11-09-2016, 04:33 PM   #5
Ricky_Flowers_'s Avatar
Ahhhh I'm so jealous! I've always wanted to do something like this. Keep us posted!
Ricky_Flowers_ is offline   Reply With Quote
Old 11-11-2016, 10:48 PM   #6
This has to be the most ridiculous ECU (Kpro) install ever. Had to pull the motor because removing the oil pan isn't possible because of the motor mounts/bar. Good news is, I can give her a new clutch/flywheel.
Old 11-11-2016, 10:59 PM   #7
Also started working on the ECU A-connector and C101 connector harness:
There isn't much needed, but should be fairly simple. I plan on using this as a relay/fuse board/switch panel:
Old 11-14-2016, 08:17 PM   #8
Because I have to remove the oil pan, and because this is a canyon/track car, I feel like I should replace it with a baffled oil pan. Because Blacktrax is right down the street, I feel like I should use theirs. I'm trying to keep this build cost-effective and am tempted to use Ballade Sports bolt in kit. Thoughts?
Old 11-14-2016, 08:35 PM   #9
I personally went with Moroso, because its a true baffle with traps. Not just a slosh plate like the above designs.
Old 11-16-2016, 08:01 AM   #10
Well I didn't even see that in my research, I just ordered the Moroso one.
Thread Thread Starter Forum Replies Last Post
CA - GARAGE SALE - NIB AP1 oem springs/seats/retainers, head, cluster, PTE 5558 Turbo rustrocket Member S2000 Classifieds and For Sale 18 02-23-2017 05:47 AM
MN FS: 17x10 +45 CE28 Mag Blue pennies_hatchie Wheels and Tires 16 01-28-2017 08:50 AM
CA: New Precision Turbo PTE 5558 turbo, ball bearing, v band mount/exhaust. rustrocket Forced Induction For Sale 6 01-22-2017 01:42 PM
OH: F20C head mint bare Teglove2 Member S2000 Classifieds and For Sale 3 11-30-2016 10:15 AM
F20c sensors? rickii S2000 Modifications and Parts 0 11-20-2016 08:34 PM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
