***\\\ LS2Kitt ///***
Probably going to piss off a bunch of people but what the hell. lol
So here's my LS swapped S2000 and my build sheet
Motor/Trans:
LS1 5.7/T56 from a 01 WS6 Trans Am
Induction
FAST 102mm LSXR Manifold
WARR 92mm Throttle Body
3.5" Carbon Fiber Intake Tube
JLT Air Filter
Fuel
Fuel Safe 10g Enduro Fuel Cell
Radium FSCT w/ AEM-1200’s
Radium 12 Micron Fuel Filter
Radium Fuel Pressure Regulator
Radium Fuel Pressure Gauge
Radium Fuel Level Sender
Radium AN Fittings
Russell’s AN Fittings
Russell’s Black Fuel Line
Holley AN Fittings
Holley EFI Billet Fuel Rails
FIC LS2 42lbs Injectors
Valvetrain
243 TBSS Heads
BTR Stage 3 Cam
BTR .660" Dual Valve Springs
BTR Steel Retainers
BTR 7.400" Chromoly Push Rods
COMP Trunion Upgrade Kit
LS2 Timing Chain
LS7 Lifters
Bottom End
Kings Bearings
Kings Rings
Melling High Volume Oil Pump
Trickflow 25% Underdrive Pulley
Headers/Exhaust
Hooker Block Hugger Manifolds
Speed Engineering 3” X Pipe Kit
Vibrant 3” Ultra Quiet Mufflers
Vibrant 3” Resonators
Vibrant 3.5” Tips
Vibrant 3” V-Band Clamps
Mahle Manifold Gaskets
ARP Header bolts
Accessories
Katech Billet Tensioner
LSSimple Alt. Relocation Bracket
TSP 1.9hp Mini Starter
TSP Black 180amp Alternator
OriginFab Catch Can
OriginFab Coolant Overflow
AlloyWerks/Hasport Motor Mounts
ICT Billet Battery Tray
Cooling
Schmuckbuilt Radiator
Schmuckbuilt Shroud & Fans
Holley Steam Line Kit
LS2 Water Pump
Jegs Black Thermostat Housing
180° Thermostat
ECU/Electrical/Wiring
Ms3Pro EVO Full Stand Alone
Aim MXS Strada Icon Display
AEM X-Series Wideband x2
NGK Plugs
Taylor 10.4mm Spark Plug Wires
LSX Innovations LS1 Coil Brackets
AlloyWerks Relocation Brackets
MotionRaceworks USB Bulkhead
Optima Yellow Top Battery
Transmission
McLeod RXT Twin Disk
McLeod Billet Steel Flywheel
Speedway T56 Remote Bleeder
MGW short throw shifter
Earl's Steel braided clutch line
Earl's AN fittings
Energy Suspension Trans mount
AlloyWerks T56 Trans Bracket
Rear End
Import Muscle Camaro SS Diff Kit
DSS Aluminum Driveshaft
DSS 600hp Axles
DSS 600hp Hubs w/ ARP studs
2012 Camaro SS 10 Bolt Diff.
GM 3.91 Final Drive Gear Set
Eaton Detroit Truetrac LSD
Ratech GM Bearing/ Shim Kit
Brakes
Powerstop Calipers
Stoptech Street Pads
Stoptech Slotted Rotors
Stoptech Steel Braided Lines
Wilwood Clutch master cylinder
2000 Civic Si Prop. Valve
Hardcore Bays ABS Delete/Tuck kit
Chassis/Suspension
KW V2 Coilovers
Cusco 32mm Front Sway Bar
Cusco 30mm Rear Sawy Bar
Cusco Subframe Brace
PWJDM Rear Lower Brace
Hardrace Roll Center Adjusters
SPC Adjustable Ball Joints
ARP Extended Studs
Wheels/Tires
CCW LM5
18x9 +38
Nitto NT05 255/35/18
18x12.5 +32
Nitto NT01 315/30/18
Skunk2 Black Series Lug Nuts
Interior
Rockstar Garage DD Roll Bar
Rockstar Garage Seat Belt Bar
BRAUM Venom R Seats
BRAUM 5pt Harnesses
PCI Seat Mount (Driver)
BuddyClub Rail (Passenger)
Ballade Sports Aim MXS Bezel
Custom 3D printed Bezel Inserts
Sparco 330mm Steering Wheel
Works Bell Hub
Exterior
VIS Top Secret CF Hood
VIS Amuse Front Bumper
Chargespeed CF Canards
RockstarGarage Mugen CF HT
Circuit Garage Rear Flares
Carbon Fiber RX7 Side Diffusers
400hp
370tq
Motor/Trans:
Induction
JLT Air Filter
Fuel
Radium AN Fittings
Holley AN Fittings
Valvetrain
243 TBSS Heads
BTR Stage 3 Cam
BTR Steel Retainers
LS2 Timing Chain
LS7 Lifters
Bottom End
Kings Bearings
Kings Rings
Headers/Exhaust
Vibrant 3.5” Tips
ARP Header bolts
Accessories
OriginFab Catch Can
Cooling
LS2 Water Pump
180° Thermostat
NGK Plugs
Transmission
Earl's AN fittings
Rear End
DSS 600hp Axles
Brakes
Powerstop Calipers
Chassis/Suspension
KW V2 Coilovers
ARP Extended Studs
Wheels/Tires
CCW LM5
18x9 +38
18x12.5 +32
Interior
BRAUM Venom R Seats
BRAUM 5pt Harnesses
Works Bell Hub
Exterior
400hp
370tq
Bullwings (02-13-2021)
Get some NT-01s on the front to match the rears, A BBK, and take it to the track. This should be fun.
I've had the car for 15yrs, 3 F20c's one being fully built/sleeved/CNC head and boosted. After the last one spun a rod after 2500 miles I wanted to try something else. It was either part the car out completely and buy a C6Z or LS swap with what I already had.
One day if you ever put that thing up to check the cross weights I would be interested how it looked. Also with tank moved behind the diff that has to mess with handling I'd think. But like everything, theory doesn't equate reality. Having owned boosted S2000 and a C6 Corvette; I get why you did this. Looks extremely clean.
When it comes to the handling, the tank relocation not so much but pushing the steering rack forward definitely makes the snap-steer worse. (ask me how I know) lol
Very cool and looks well built. I'd be curious to see cross-weights too.
