SHG_James' build thread
Let's start off by introducing myself. My name is James and I live in Hawai'i. Prior to purchasing my S2000 in January of 2015, I owned a 2004 Civic coupe (EM2) for a little over 10years. Long story short, it started life as an ordinary everyday automatic Civic. Pretty much stayed that way up 'til 2008 when I swapped the trans out for a 5spd. A year later, I got a good deal on a K20A2 motor and trans, so I picked that up, and in a few short weeks, I was able to get everything to swap that in. Fast forward to December 2014, I was finishing up a 2yr ground-up rebuild on the Civic. January 2015 comes along and my friend who works for my local Honda dealer told me about a low mileage S2000 that got traded in the previous day by an older couple for a CRV. Ever since I was in middle school, I've always dreamt of owning an S2000. It met all my criteria, so I had to go and at least check it out. I went in later that day, and all within an hour of me getting there, I checked it out, closed the sale and drove it home. In the days following, a hard decision had to be made. Do I keep both cars or sell the Civic to fund the S2000 build? A week or so goes by and after much thought, I decided to part out my Civic and sell the rolling shell.
Undercarriage prep and paint
Engine bay assembly
Drivetrain in
Custom VC done by Kokenda Kustoms in memory of my father
Suspension and undercarriage assembly
After 2yrs, finally back on the ground
Here is the final look prior to the part-out
...and with that said, here is my LBP MY07, purchased January 7th, 2015 with 24,288 miles.
Stay tuned! More updates to come.
Engine bay assembly
Drivetrain in
Modification list:
Powertrain
TTS Performance Rotrex C38-91 supercharger
Setrab Series 6, 16 row oil cooler for Rotrex
Origin Fabrication custom v-mounted radiator, intercooler and A/C condenser
Origin Fabrication custom 321SS header
Origin Fabrication custom 304SS 3" resonated exhaust w/ helmholtz
Origin Fabrication custom 1.9L catch can
TracTuff custom swirl pot
Tial Q BOV
OEM throttle body bored out to 68mm, knife-edged inlet and butterfly, and machined butterfly shaft by Maxbore
Toda Racing baffled oil pan
ID1300 injectors
Radium Engineering FST-R w/ Walbro 450 fuel pump
Radium Engineering fuel rail
Radium Engineering fuel pulse damper
Billman Motion Generation-X TCT
Hondata 4bar MAP sensor
Hondata FlashPro tuned by Sean Igawa (garagemunky)
Odyssey PC680 battery
XRP HS79 CSM hose and HS79 black anodized fittings and super nickel crimp collars throughout
AMG Fuel Design A/C bulkhead and adapter fittings
Aeroquip EZ Clip A/C hose and fittings
ASM Ignition Coil Cover
Drivetrain
OEM Honda AP1 flywheel
OEM Honda friction disc
ACT HDSS pressure plate
SOS clutch line
Suspension
Öhlins DFV
Karcepts front sway bar (.250" wall)
Karcepts rear sway bar
Karcepts rear hubs
18x9.5 +45 Volk Racing ZE40 (dash white)
255/35/18 Bridgestone RE-71R
Exterior
ASM I.S. Design front aero bumper IS-11 FRP
ASM I.S. Design aero bonnet FRP
ASM I.S. Design front aero fender -04 FRP
ASM I.S. Design rear over fenders FRP
ASM I.S. Design rear aero bumper -08 wide FRP
ASM I.S. Design ducktail spoiler FRP
Mugen hardtop FRP
Origin Fabrication titanium shorty antenna (black)
OEM Honda JDM rear reinforcement bar
OEM Honda JDM rear license plate bracket
Interior
Recaro custom Pole Positions (black jersey center, black suede outer, red stitch, logo on headrest)
PCI Racing seat mounts
ASM MOMO Tuner steering wheel
ASM I.S. Design horn button
Works Bell short hub
Works Bell quick release
Renegade short shifter v2.0
OEM Honda NSX Type S shift knob
ASM shift boot (alcantara)
ASM Monaco mirror
OEM Honda 20th anniversary radio door
ASM floor mats (Ruby)
OEM Honda Access premium floor mats (black)
Powertrain
Tial Q BOV
ID1300 injectors
Drivetrain
SOS clutch line
Suspension
Öhlins DFV
Karcepts rear hubs
Exterior
Mugen hardtop FRP
Interior
ASM Monaco mirror
This car is gonna be titts!
