SoHonda Garage. S2000 Build
#111
Here is a glimpse at the final design. Should be sanded and prepped for paint this weekend.
Still not the best but I am getting better with practice...
Also got my rubber delivered...
#112
For a track only car, I'd remove that rubber cover that goes over the filler neck. Especially if some sort of shock adjustment is under there.
#113
crappy pic
#114
crappy pic
Huh!?! I have never seen anything like your tin cover on a W2W S2000. I track occasionally and street drive less that 3K miles / year but have removed that rubber cover for easier access to my Konis.
That said, I have never smelled fuel in the cabin. Nor would I expect to.
Nice write-up regarding Thompson.
#117
The front plates are using existing hole/bolt locations that have been drilled out larger for larger M10 hardware. I will be making pass through access holes for the front bolts through the chassis with 1/8" backing plates. Rear will be the same 1/8" backing plates with M10 hardware.
#118
The rear shelf interior paint was looking a little ratty and I needed to paint the center tunnel anyway so this weekend I got the interior prepped and re painted base SSM.
before
after:
The wheel wells after 14 years were also looking a bit tired so I cleaned, brushed and wired wheeled them to prep for some fresh undercoat. While I was at is I added a few extra beads to better secure the upper arm mounting points which have been known to tear out with out this treatment.
I tossed around many ideas for wheel well paint or coatings but at the end of the day this car will be used and used hard so spending a huge amount of ware to being everything down to metal and repaint a nice silver would really be worth it. I decided to just redo what Honda did from the factory and used some nice Dupicolor undercoat. It left a nice hard coating exactly like OEM so I was pleased with the results.
The cage and suspension arms will be painted this week(end) and then things will start to go back together!
before
after:
