Tama05's Build
#205
Finally got around to getting the tires on the new wheels and finishing up the car for a little bit. I love the feel of the square setup so far. The steering feels a little heavier, but the car begs to be pushed through the turns. It definitely feels more balanced and predictable, which gives me more confidence while driving it. I only cruised around for a little bit to make sure I wasn't rubbing and that everything felt good. The front end will need some more camber dialed in for sure and maybe bring the back to 3 degrees.....we'll see. Anyways here are some pics for now of how the car's sitting.
Another of the top:
Another of the top:
Car looks amazing! Do you plan on adding black vinyl to the windshield frame to match with the CF hardtop?
#206
Thanks Yves! How's it going?
Appreciate it man
Thanks a lot
Thanks Andrew, waiting to see those bronze CE's mounted.
More photos please!
Hey thanks, I've thought about it, but to be honest, I don't mind the look with the white windshield frame. If I do, it will be a little bit.
Appreciate it man
Thanks a lot
Another of the top:
Another of the top:
#209
Nothing new at the moment, I'll be overseas for a few more months...don't have any real plans for the car other than maintenance and a detail when I get back. Throwing around the idea of an ASM CF hood and Mugen intake setup.
Thanks a lot! The front fenders are rolled flat and are slightly pulled as well. Right now I'm running 2 degrees of camber up front with 0 toe. I plan on increasing the front end to around 2.6 degrees for better clearance and to help utilize the square setup to a fuller potential. The 9+35s will be a little more difficult to fit with 255s, I feel that I am pushing the limit with 9+40 at the moment. It can be done but depends on how you drive the car and what you want out of it. I have about an inch gap on all four wheels which helps out a lot and I feel the car responds well at the current height which is recommended for my coilovers. Also, it depends on what tires you want to run as some manufacturers sizing are a bit wider than others. Hope this helps out.
