Ignition Stuck in Lock
Old 11-03-2015, 05:55 AM
scoobydoobydo's Avatar
Default Ignition Stuck in Lock
I have a 2006 CBR 600RR and it only has about 2k miles on it. No issues with the bike until now. I went out to the garage to take it for a spin, and when I tried to push down and turn the key out of the 'LOCK' position, it won't turn.
I've read countless posts about this problem, but no real resolve. I have the spare keys, they don't work either. All of the keys work on the gas tank and the trunk.
List of things I've tried:
1) wiggling the handlebars (whilst attempting to turn the key)
2) shooting air into the keyhole
3) WD-40 in the keyhole
I thought about removing the upper triple but I saw someone else mention that if it is locked, I cannot remove it. I dread dropping the forks anyways...
Mind you, this has been going on for a week. I keep thinking there is a shred of hope that I will walk out to the garage and it will unlock.
Any one have any advice?
Thanks.
Old 11-04-2015, 01:37 PM
Vanishing Point's Avatar
Try a few (5-6) drops of motor oil in the lock, insert your key and withdraw it. Do this several times to coat the internal lock mechanism, then try turning it.
Old 12-02-2015, 11:50 AM
s2000Junky's Avatar
Still locked?
Old 12-03-2015, 03:12 PM
windhund116's Avatar
Received 1,424 Likes on 954 Posts
Is this a spare key? One made by a locksmith. You may need to polish down rough edges with a steel brush on grinder.
Lube the lock and key with 3-in-one of some such lubricant. Be liberal with it. Have someone gently rock the handlebars back-&-forth. You try to turn key at the same time.
iceman86
04-09-2020 10:38 AM
Mr.SweetRoll
04-25-2014 07:28 AM
zenairdave
02-16-2012 06:30 AM
GoldLude
11-02-2011 02:31 PM
Kyras
05-04-2005 06:45 AM
Quick Reply: Ignition Stuck in Lock
