DIY Rear Brake Caliper Refresh
after doing literally 100s of rear pad replacements between the track and my garage, I never thought to use a 3/8 ratchet. Genius! I've been using coilover wrenches to turn the piston!
I just did all four brakes on my hatch... brake caliper hinge/ slide points had frozen and ended up breaking one. I learned the hard way.
What you need to know is that once it begins to freeze from corrosion/heat it will take a tremendous amount of time and effort to get it out.
Make it easy on yourself and take the extra 5 minutes to do this each time you change brake pads.
Good write up.
Good write up.
