DIY Rear Brake Caliper Refresh
#53
Bump for a good maintenance thread. I need to do this with mine. When I was installing my new rotors and moving the pins by hand they were not moving nearly as easy as I'd like or think they should.
#54
Any update on the Bendix stuff? Seem to work fine? I see 3m has some silicone grease but I guess it has too low a flash point (570F) to be used on brakes for a track car..? http://www.amazon.com/3M-08946-Clear.../dp/B005RNEH5O
#55
I ended up using Permatex 24125 Ceramic Extreme Brake Parts Lubricant instead: Permatex 24125 Ceramic Extreme Brake Parts Lubricant 8 fl. oz. brush-top bottle
I'll have to be going to the track often to see if this stuff holds up
#56
Crap, I didn't even realize there were flat sided pins for the front. All I know is I put the flat sided pins on the bottom, for the rear. I just need to buy myself a damn Helms manual.
#57
Also a quick search advises to use Wurth Silicone Lubricating Compound pricey but what honda techs are supplied with for the job and Napa 7651346 Sil-Glyde Silicone Lubricating Compound is a good substitute.
Mark Bridgett
01-25-2013 04:21 AM
