OEM vented hood
OEM vented hood
Anyone in the Bay Area feel comfortable cutting the vents to an OEM hood? Willing to compensate for the time or trade my hood for one with vents. Color I'm looking for is SSM. This is off a my00. Thanks.
https://www.s2ki.com/forums/s2000-under-hood-22/diy-vented-aluminum-hood-324009/page11/
seems some peoole had had good results. I'm perfectly fine with giving this a go since I can always find another OEM hood and paint it. Thanks for the concerns fellow members. Just trying to alleviate some under hood temps. Btw the car is really only driven during spring/summer. maybe once or twice a week. Depending on egt and iats, I would like to get it down to a speed sf event to see how the car does.
you should really get more cooling though. doesn't hurt to have a good airflow and room for heat
can you recommend a hood that's aftermarket with decent fitment and not carbon fiber? Any other suggestions for heat dispersal?
just curious, but why not cf? it's cheaper to get a vis cf hood with similar styles to js, mugen, spoon, top secret, etc, than to buy an authentic frp hood.
hear dispersal - something other than an oem bumper. i'd get a voltex front bumper (or even a rep) and use the side inserts to collect air for cooling your engine bay and/or fresh air to your filter.
if you don't want a different bumper, you can try cutting your oem bumper to fit one of those ram intake inserts to feed fresh air to your engine bay << probably the better route, but have to cut your oem bumper
again, this is all with some sort of vented hood and not a cut oem hood. vented hoods pull the heat from the engine bay when driving. oem cut hood wouldn't work as efficiently. not sure how well it would work when you're driving. most def works when you're not driving though
js frp hood. still costs some money though :/
