View Poll Results: Which sub-$20k car should I buy for track/daily?
Used BRZ/FRS
43.48%
E36 M3
0%
E46 M3
17.39%
E46 330i ZHP
0%
Something else
39.13%
Voters: 23. You may not vote on this poll
What daily/track car should I buy?
#92
Yeah the 996 idea was really appealing at first, but I've decided I don't want to test fate. Most of the examples within my budget don't have the IMS fix.
Now that I'm looking to get a dedicated S2000 track car, one topic that has popped up a few times is the AP1 banjo bolts. The car I'm looking at is a 2002 and I believe the engine number falls into the range for problematic banjo bolts. I'll do more research, but has anyone here dealt with this issue on a heavily tracked AP1?
If you have a heavily tracked AP1 and havent upgraded your banjo bolts you may be encountering some major oil issues and possible compression loss...
#93
https://sfbay.craigslist.org/sfc/cto/5989651502.html
https://sfbay.craigslist.org/eby/ctd/5987052680.html
2004 Rio / Rio/New Indy Yellow Pearl - $16,500
#94
Here is a list of the other mods, taken from the maintenance records:
RPF1 17x9 +45, RS3 255/40/17, Project Mu CR F/R, Ballade air filter, 2 NSK wheel bearings, 2 wheel hubs, 2 used axles, 1 Ballade axle spacers
<!--td {border: 1px solid #ccc;}br {mso-data-placement:same-cell;}-->Ballade throttle body, Ballade intake arm, Ballade custom coilovers (believed to be 16k/16k)
<!--td {border: 1px solid #ccc;}br {mso-data-placement:same-cell;}-->Ballade clutch kit, lightweight flywheel, Buddy Club ball joints, new clutch master cylinder
Details on the Ballade head:
<!--td {border: 1px solid #ccc;}br {mso-data-placement:same-cell;}-->Supertech valves, valve guides, valve springs, Honda head studs, spark plugs, thermostat, coolant, head gasket, Ballade intake, throttle body, timing gear, compression (210, 215, 230, 180), leakdown (20%, 35%, 5%, 30%), valve job
I'm planning to call Ballade to ask about the car and get a compression/leakdown test done. If it all goes well, might make a deal. Anything else I should be looking for?
All very nice but will require another 3-5k to set the car up the way I want.
#95
Details on the Ballade head build, which was done after compression/leakdown tests showed the results below:
#96
I read somewhere that the banjo bolts usually aren't an issue unless the car is driven above 105mph. Not sure how this claim is backed up, though.
Take my conclusion with a grain of salt, as I have no personal experience with this nor an engineering background. I just researched it and drew my own conclusion. Since I was planning to autox my car and maybe track it, I strongly preferred to not buy any VIN potentially effected by the banjo bolts. An 03 of similar condition to an older car did not command much of a price premium and was worth it for peace of mind. That being said, I would not turn down the right deal strictly because of the "issue". Especially if it has good compression/leakdown. I would just account for the price of adding banjo bolts to my purchasing decision.
#97
I currently own 07 S2000, 92 NSX, 98 M3, and an 05 M3 Comp. pkg. - all manual
For what you are looking for, I would start with an E36 M3 - great car
This is my second one - I have always been a Honda fan - but there is something about the E36 M3 that makes it feel very special in daily driving as well as occasional track days. Once you address certain issues, you won't have to worry about it for the long term - the one I have now had all issues addressed and also came with a bonus (BBK, 18" wheels, and revised suspension) at no extra cost over a non-modified one.
The E36 is better for the track than the E46 imo due to weight - which I definitely feel when I drive both the E46 and E36
as for the 996 911, I owned an 02 for a year - great driving experience, but even if the IMS was addressed, there are other risks in the engine and it is $25K for a replacement engine - and that's why I sold it after one year (LN Engineering has a huge writeup on all the engine issues)
hope that helps
hope that helps
#98
I'd actually be in favor of purchasing a track prepped vehicle if that is the exact intended purpose. If it has all of the maintenance records and passes a pre-purchase inspection, then that means it's ready to take to the track purchased as is. Track cars don't last very long when they're not maintained, so if it runs and passes a thorough PPI...
You generally pay less for a lightly prepped track/street car because "no one wants someone's else vision/build". I say, take the discount, part out aftermarket pieces that you don't like, keep what you do like, and go buy what you want with the savings in price difference and the proceeds from part out.
As for banjo bolts, do it, and put in a baffle/anti-slosh plate while the pan is pulled. If it's really going to be a track car, save your motor - both items are cheap compared to a used motor and the labor needed to put it in. If you're too lazy or don't have enough money to do those items, then you'll be too lazy/poor for a replacement motor... Gotta pay to play.
Edit: missed that.
I agree with everyone else's concern on that.
Edit: missed that.
boyguan
21
07-26-2012 12:02 PM
Blackie
24
04-28-2003 07:39 PM
