Engine Swaps Discussion of alternate engine swaps into the S2000 other than F20/22. K24, 2JZ, V6, V8 etc...
Compression test question
Old 03-21-2017, 04:10 PM
MikeGs2k's Avatar
Default Compression test question
I have a 2001 S2000. Swapped a new low mileage motor about 2.5 years ago. Recently past few months has been blowing smoke at idle and small amounts when accelerate/reverse. I thought maybe the valve seals?!
The car just doesn't perform like it used to. Definitely doesn't "pull" as efficiently as it used to. Today I did a compression test and this was the outcome! The numbers did jump but not drastically. I had not yet done a leak down test.
I was going to first try a valve adjustment and see if that helps any. If it is valves that is not a huge deal but if it is in bottom end I mine as well start shopping for a motor
Any insight is appreciated! Thanks
CYL 1-191
CYL 2-180
CYL 3-180
CYL 4-190
Wet compression test:
CYL 1-193
CYL 2-208
CYL 3- 182
CYL 4- 208
MikeGs2k
03-22-2017 05:53 PM
Backmarker
09-21-2016 03:59 PM
RHDS2K
05-01-2014 09:24 AM
rbtz
12-19-2013 07:34 AM
Quick Reply: Compression test question
