Florida For Sale Members Only!
Mark this thread as Unsold
Sway Bars Galore - Ankeny Dual Blade, Karcepts Front and Rear, NC/S2000 Rear Bar
Old 10-12-2016, 05:24 AM
ViperASR's Avatar
Default Sway Bars Galore - Ankeny Dual Blade, Karcepts Front and Rear, NC/S2000 Rear Bar
Contact: PM
For anyone that knows me I am extremely OCD about my equipment, so everything on the car has been well taken care of and maintained, as well as being setup perfectly.
Prices do not include shipping.
Ankeny Dual Blade Front Sway Bar
Price: $650
The Ankeny Bar shows small signs of use, but the bushings and endlinks are in excellent condition. The bar made zero noise. This bar comes with the upgraded aluminum mounts to replace the OEM chassis mounts. All hardware needed to install is included.
The blades can be adjusted in seconds with the car on the ground with a 14mm wrench. Beyond the easiest to adjust bar I’ve ever had.
NC Miata/s2000 Rear Bar
Price: $50
Popular NC Miata/s2000 rear bar. I notched the mounts and spaced the bar out to provide plenty of clearance for the rear diff mounts. I also drilled a second adjustment hole. The bar mounts with OEM hardware, and uses OEM endlinks. I had plenty of clearance to my KW Clubsports.
Brackets, bushings, and spacer are included.
Karcepts Front Sway Bar (.250 STR center section)
Price: $525
Good condition overall. There are a few nicks and dings from use as shown, but the bar is in perfect working order. The bar made very slight clunking from the endlinks over large undulations at parking lot speeds, but most would not care or notice, it was significantly better than my old Gendron and Saner.
All hardware needed to install is included. I will include the Karcepts install directions.
Karcepts Rear Sway Bar
Price: $275
In great condition as shown. There are a few very small nicks and dings from use as expected. One of the endlinks has a small bit of play, but there was no noise from it at all on my car.
ViperASR is offline
Old 10-12-2016, 05:29 AM
King Tut's Avatar
Time to look for that chart of sway bar rates. I have the Eibach rear bar, but I want more rear bar.
King Tut is offline
Old 10-12-2016, 05:32 AM
ViperASR's Avatar
My gut feeling is that this is softer than the Eibach rear, as I believe the stiffest setting is right around the OEM rear rate. Usually people are looking for less rear and more front bar on a square setup. Aero seems to change that quite a bit.
ViperASR is offline
Old 10-12-2016, 08:05 AM
slowd16's Avatar
$34
slowd16 is offline
ViperASR's Avatar
Originally Posted by slowd16
$34
ViperASR is offline
Old 10-12-2016, 10:25 AM
ViperASR's Avatar
Karcepts Rear Bar is sold.
Apparently you can't edit posts anymore...
ViperASR is offline
Old 10-14-2016, 09:28 AM
ViperASR's Avatar
Both Karcepts Bars are sold.
Ankeny front bar is sold.
NC/s2000 Rear Bar is still available.
ViperASR is offline
ViperASR
Member S2000 Classifieds and For Sale
10-14-2016 09:28 AM
DeAnza
09-13-2007 11:02 AM
bunjimobile
08-07-2004 05:02 AM
t.c.
01-15-2003 02:39 PM
Quick Reply: Sway Bars Galore - Ankeny Dual Blade, Karcepts Front and Rear, NC/S2000 Rear Bar
