Gateway S2000 Owners Members for St. Louis MO and area.
Rattling soft top latches? I have a ton of extra Honda OEM EPT sealant
Old 06-29-2015, 08:43 PM
Jimbogiant's Avatar
Default Rattling soft top latches? I have a ton of extra Honda OEM EPT sealant
Hey everyone -- I recently ordered some Honda EPT sealant (special expanding foam stuff) in order to perform TSB 03-023 "Convertible Top Creaks, Pops, or Rattles While Driving Over Rough Roads" (https://www.s2ki.com/stor/library/TSB/a03-023/index.htm). In addition to greasing the rubber seals with Shin-Etsu grease, the TSB also tells you how to stop the latches themselves from rattling using some special Honda foam called "EPT sealant." The problem is, Honda only sells it in giant rolls that have enough material to perform this TSB on over 100 vehicles! Talk about overkill.
The point is, I'm going to have a ton of this EPT stuff left over once I'm through putting it in my own car, so if anyone else has rattling latches and wants to use some of this sealant to perform the TSB on their car, let me know. It's pretty easy to open up the latches and put the sound-deadening stuff in them (see this thread: https://www.s2ki.com/s2000/topic/372...rattle-fixdiy/ ).
James
Old 06-30-2015, 06:50 AM
Deepblue's Avatar
Thanks for the offer James, Bring it to the next Detail / Install Day Im sure it will be used then, ill probably use some then.
Old 06-30-2015, 07:01 AM
8BALL's Avatar
James - Thanks for sharing. I had the same issue with my latches long ago and resolved it in a similar manner. I used black window insulation tubing, cut to size and stuffed in place. Results were fantastic and stopped the rattle. Also replaced the latches themselves as they were worn and caused the tension of the seal not to be as tight as it should have been.
Old 06-30-2015, 09:04 AM
Kenshyn's Avatar
I jammed that stuff in my hardtop latches, as much as I could, and they still rattle
Old 07-22-2015, 04:27 PM
Jimbogiant's Avatar
I ended up putting some of this stuff in my latches last weekend, and it worked great. If anyone else needs some of this to stop a latch rattle, send me a PM or something, I've got a boatload of it left on the roll.
marc.2k
10-21-2014 10:09 AM
toekneedahtiger
03-04-2014 11:55 PM
Jeff_Loadman
03-16-2010 09:50 AM
tebs
09-07-2005 11:25 AM
juspimpin
11-20-2002 01:50 PM
Quick Reply: Rattling soft top latches? I have a ton of extra Honda OEM EPT sealant
