Help! C/F Hood installation.....cant lock
Old 02-13-2003, 06:44 PM
north9586's Avatar
Default Help! C/F Hood installation.....cant lock
Hey,
Im currently attempting to install an Amuse C/F hood, its on, its beautiful, but I cant get it to completely close and lock! If anyone has had this problem/knows how to help, please let me know, Thanks!
~Andrew
Old 02-13-2003, 06:59 PM
TreyMan's Avatar
Is it latching at all? If it is not check out your alignment, and make sure you mounted the latch facing the right way. Ive never put a hood on a S2000, but I have on my sol and I screwed up doing the above a couple of times. Just an idea.
north9586's Avatar
The hood is lopsided and that's looking like the problem. Dag-nab-it! Well....back to the drawing board....but if anyone still has advice or if this is common please let me know! Thanks again.
Old 02-13-2003, 07:02 PM
north9586's Avatar
Will check alignment, etc. Yea it will latch, and it will push down, just not *click* lock. Im still gonna have at it....
Old 02-13-2003, 07:11 PM
w1ngman's Avatar
You have a slight amount of adjustable play available to you with loosening, adjusting, and then retightening the portion of your hood latch that is mounted to the frame/arm in front of the radiator. Look at pic below & see the area juuuuuust above my Rick's "S" badge for a sense of where I'm trying to point you...
Been a while since I'd had to adjust my own...but anyway, I *know* you can adjust the lower hood latch mechanism because I had to when I installed my Fiber Images CF hood. Best of luck , but shouldn't be a real problem.
- Dave
Old 02-13-2003, 07:17 PM
whiteGoKart39's Avatar
is it a real amuse hood?
Old 02-13-2003, 07:42 PM
crockey's Avatar
I had the same problem with my Amuse style hood. The gap on the passenger side is a little wider then on the driver side. Can you adjust the hood that much from side to side? I can't seem to do it.
Old 02-13-2003, 07:55 PM
w1ngman's Avatar
[QUOTE]Originally posted by crockey
[B]I had the same problem with my Amuse style hood.
Old 02-13-2003, 08:23 PM
m777erlin's Avatar
You can adjust the latch a little which should help. Make sure that the hood is not hitting the bumpers by the shocks also. If the latch does not line up, you can adjust the brackets that hold the hood in any direction. If you notice there are little lines there to use as guides. Don't worry, all hoods need some minor adjusting. I had to do everything above with my J's.
Old 02-13-2003, 10:18 PM
north9586's Avatar
WELL...........ive jiggled, ive twisted, ive begged, ive adjusted, ive yelled.....it still wont lock.....well now to go to plan B....make someone else do it ...thanks for all your help!
Quick Reply: Help! C/F Hood installation.....cant lock
