Pages: (2) [1] 2  ( Go to first unread post ) Reply to this topicStart new topicStart Poll
Changing Defi BF gauge color in easy 9 steps- the cheap way
Offline 3ngin33r1
Posted: Oct 14 2003, 02:24 AM
· · · Quote Post
Gold Member
Group IconGroup IconGroup IconGroup IconGroup IconGroup IconGroup IconGroup Icon
S2KI User #: 19859
S2KI Age: 7 yrs 6 days
PPD Average: 6.4
Enthusiast
Kingston, WA
WA -
In preparation for my DJ Qube blue dash which I've already received part of when I had him do the audio controls, I felt the need to have my Defi BF Gauges match what will be the rest of my cluster color.
I did not feel like investing a lot of money to do this and I wasn't entirely sure how the gauges were constructed. So, I pulled them apart to see what I could do.
Tools required:
1 small flat head screwdriver
1 #2 Phillips head screw driver
1 #1 Phillips head screw driver
1 Blue Sharpie (or any color you desire)
Step one: Gently pry the back of the gauge face cover that is flanged to hold it onto the gauge back casing with a small flat head screwdriver. Be very careful with this as you can damage the flange easily so that it is visible when you reassemble it. Do this on about 3/8s of the flange. Gently pull the gauge face cover off, it will take a little bit of effort as you pull the back casing off at an angle. If you want, you can bend the entire flange to make this easier but it's not necessary. You may want to cover the screwdriver head with tape to avoid scraping the flange.
Gauge face cover flange[/PHOTO]
Gauge face cover removed[/PHOTO]
Step two: Remove the two screws retaining the gauge back casing. Remove the gauge casing.
Gauge casing removed[/PHOTO]
Step three: Remove the two black screws that are recessed in the black plastic portion of the gauge (see image above). Gently remove the dual board. This will take a bit of effort as this piece has the gauge needle attached. Be sure to pull straight back to get the needle out of the mechanism. Be careful not to bend the needles pin. Also be careful not to bend the electrical connecting ping on the board below.
Needle and second board removed[/PHOTO]
Step four: Remove the three black screws on the board and gently pull it off of the gauge face. There is another set of electrical connector pins on this piece as well.
Three Black Screws[/PHOTO]
LED cluster[/PHOTO]
Step five: Take a blue Sharpie (or whatever color you desire) and color each of the 8 rectangular LEDs, you may want to go over them a few times to darken your color choice when they are lit.
Colored LEDs[/PHOTO]
Step six: Reassemble the gauge pieces in reverse order. I don't know the torque settings for the screws but do not overtighten the once that are in direct contact with the circuit board, you don't want to crack it. The board with the colored LEDs can only go one way onto the back of the gauge face but the board that goes on top of the LED board can go back on the wrong way. There are electrical pin connectors that must connect, be careful not to bend the male ends.
Electrical Connector Pins[/PHOTO]
The last dual board also has connectors that must connect to the lower board. Tighten down the two recessed screws.
Step seven: The gauge needle is calibrated and you may loose calibration by a significant degree. From my best guess the calibration is set with the needle touching the stopper pin. You can get close to this if you insert the needle pin part way until it engages the control mechanism
Needle Partial Press[/PHOTO]
Gently rotate it until it hits the mechanism stop point at 0.
Stopper Pin[/PHOTO]
If this point has the needle beyond the stopper pin, rotate the needle all they way up to the higher mechanism stop point and then push the needle a bit further to rotate it. Don't man handle it, I don't know the strength of the mechanism.
Needle Up[/PHOTO]
Rotate it back down to see where it stops at the low point. Repeat this process until the needle appears to be at the stopper pin at the low point and press the needle completely down into the mechanism.
Needle Pressed all the way down[/PHOTO]
Step eight: Reassemble the gauge back casing and tighten down the two screws. Be sure the daisy chain connectors are in the proper holes on the casing. Slip the gauge face cover back over the lip of the back casing. Bend the flange back over. I used the back of a screwdriver to get a nice smooth bend and you may want to gently press it back with a tape covered screwdriver tip to get a better fit.
Step nine: Reconnect the daisy chain wires from the control unit and fire it up
Blue Defi[/PHOTO]
If you find that the gauge is completely off calibration, there is a calibration control on the back of the dual board section, this can be adjusted with a small flat head screwdriver and you may want to check it against your known readings before you began this process. Or you can adjust the needle accordingly before you press it all the way down. You can check this before you reassemble the gauge casing by connecting the daisy chain wires and turning them on.
Startup and power down is the same, the fade out with the power off will still light up the gauge face in red as the colored LEDs are off and the red light comes from the center LED cluster that lights the needle.
Current Toys
2005 Triumph Rocket III - #001/200
Recent Toys
1959 Chris Craft Conqueror #C40109 SOLD
2003 Honda S2000 #3414 SOLD
2006 Ariel Atom 2 300SC SOLD
2001 Bell 430 SOLD
1997.5 Hummer H1 HMCS SOLD
1997 Honda CBR1100XX Super Blackbird SOLD
This post, and all subsequent posts, is intended as an observation, opinion, and perhaps a different perspective. No intent to disparage, flame, or denounce another's integrity, intelligence, or sincerity in purpose exists in this missive. For a taped copy of this post, contact the manufacturer. All posts final. Void where prohibited. If you feel that you have read this post in error, return it in original packaging for immediate refund.
Email PosterUsers WebsiteICQAOLYahooMSN  Ignore
Top
Offline honda9krpm
Posted: Oct 14 2003, 04:45 AM
· · · Quote Post
Guest
S2KI User #: 9352
S2KI Age: 7 yrs 293 days
PPD Average: 1.7
Owner
2000 Monte Carlo Blue/Black
Gold Coast
AU -
Thank you for the excellent writeup.
I was wondering the same thing and wanted to change the colour to red to match the dash
Thx
11.4@ 126mph
The power of dream!
  Ignore
Top
Offline NJSY2K!
· · · Quote Post
Guest
S2KI User #: 8476
S2KI Age: 7 yrs 327 days
PPD Average: 0.7
Enthusiast
BERGEN
US -
wow.....cool...
Sold--2002 SS S2000
Yahoo  Ignore
Top
Offline MacGyver
Posted: Oct 14 2003, 07:17 AM
· · · Quote Post
Guest
S2KI User #: 225
S2KI Age: 9 yrs 120 days
PPD Average: 2.5
Owner
2000 Custom Color/Black
Columbia, MD
US -
lol.gif Marcus, you win my award for best electrical engineering project where nothing electrical was done wink.gif You get two thumbsup.gif for that one...keep that up and you'll put guys like me out of business.
user posted imageuser posted image
2000 PPG Romanesque Crimson candy over Brickyard Red Metallic base/Black interior with candy accents
http://users.rcn.com/dhintz/ (OLD page) <--- Click on 'Michelle' for more info...
Looking for Loooove S2000 style? Check out the S2000 Love Connection
Member of T.I.T.S. - Scam Prevention/Recovery Unit for Maryland
user posted imageuser posted imageuser posted image
Email PosterUsers WebsiteAOL  Ignore
Top
Offline Darksyde
Posted: Oct 14 2003, 08:10 AM
· · · Quote Post
Guest
S2KI User #: 24858
S2KI Age: 6 yrs 249 days
PPD Average: 0.1
Owner
2003 Berlina Black/Black
Orlando
US -
It is not what you see you should fear but what lies beneath.
Email Poster  Ignore
Top
Offline xviper
Posted: Oct 14 2003, 08:30 AM
· · · Quote Post
Guest
S2KI User #: 1612
S2KI Age: 8 yrs 332 days
PPD Average: 11.6
Owner
2000 Silverstone/Black
CA -
thumbsup.gif You got NADS, man! I know how expensive those gauges are. eek3.gif
  Ignore
Top
Offline 3ngin33r1
Posted: Oct 14 2003, 10:10 AM
· · · Quote Post
Gold Member
S2KI User #: 19859
PPD Average: 6.4
Enthusiast
Kingston, WA
WA -
Next up, the control unit.
Top
Offline 3ngin33r1
Posted: Oct 14 2003, 10:11 AM
· · · Quote Post
Gold Member
S2KI User #: 19859
PPD Average: 6.4
Enthusiast
Kingston, WA
WA -
and I'll try to take better pics, I took the above ones at night in my shed and they came out bad.
Top
Offline 3ngin33r1
Posted: Oct 14 2003, 11:37 AM
· · · Quote Post
Gold Member
S2KI User #: 19859
PPD Average: 6.4
Enthusiast
Kingston, WA
WA -
Gauge pics updated.
Top
Offline 3ngin33r1
Posted: Oct 14 2003, 12:04 PM
· · · Quote Post
Gold Member
S2KI User #: 19859
PPD Average: 6.4
Enthusiast
Kingston, WA
WA -
The control unit is normally lit up white when the lights are on and during initial power up with the lights off.
Lit White[/PHOTO]
Step one: Remove the five crews holding the control unit casing together
Five Screws[/PHOTO]
Step two: Lift off the upper portion of the casing
Upper case removed[/PHOTO]
Step three: Lift out the circuit board from the lower portion of the casing. There is one screw located off center on the circuit board, DO NOT REMOVE THIS SCREW. It is a retaining screw for a component on the other side of the board.
Circuit Board[/PHOTO]
Step four: Locate the four LEDs on the top of the circuit board. LED! is the differential pressure warning light and is located on the far right side of the board. The numbering of the LEDs on the board is a bit screwy, LED2 is located on the far left of the board and from left to right, they are numbered LED2, LED4, LED3, LED5, LED6. Only LED2, LED3 and LED6 have actual LEDs in them.
LED Numbering[/PHOTO]
Step five: Take a blue Sharpie (or any color of your choice) and color the tops of LED2, LED3 and LED6.
LED Coloring[/PHOTO]
Step five: Reassemble the the unit back into the casing. There is an alignment pin on the case that coresponds with the alignment hole on the board. It can only go back together one way (unless you force it and break the alignment pin). Put the five screws back in and tighten down (not too tight, you're screwing into plastic and it can easily strip)
Step six: Reconnect to your vehicle wiring and light it up.
Blue Control Unit[/PHOTO]
Top
Offline 3ngin33r1
Posted: Oct 14 2003, 01:34 PM
· · · Quote Post
Gold Member
S2KI User #: 19859
PPD Average: 6.4
Enthusiast
Kingston, WA
WA -
Alrighty, I'm dumb.
There is an easier way to ensure gauge calibration. Each gauge has a default warning setting. If you disconnect the power from the control unit, it will revert to the defaults. I have an email into Defi for a list of gauge defaults but if anyone has oil press/temp gauges and you don't mind disconnecting the power to your control unit and telling me the defaults so I can get mine set right, I'd appreciate it.
I will post the reply from Defi once I receive it.
Top
Offline TriaXenginE
Posted: Oct 14 2003, 02:12 PM
· · · Quote Post
Group IconGroup IconGroup IconGroup IconGroup IconGroup IconGroup IconGroup IconGroup Icon
S2KI User #: 6491
S2KI Age: 8 yrs 59 days
PPD Average: 6.1
Owner
2002 Midnight Blue/Black-Yellow
Firenze, Italia
IT -
very cool, marcus.
user posted image
  Ignore
Top
Offline TurboVtk
Posted: Oct 14 2003, 02:20 PM
· · · Quote Post
Member
S2KI User #: 1380
S2KI Age: 8 yrs 357 days
PPD Average: 1.3
Owner
2004 Rio/Indy Yellow/Black
Bronxville/NY
US -
way cool
In 1999 -- '90 Accord Beige/Burgundy -- Sold
In 2000 -- '96 Integra GS Green/Beige -- Traded In
In 2000 -- '00 Integra GSR White/Black -- Rear Ended Totaled
In 2000 -- '00 Integra Type R Yellow/Black -- Traded
In 2000 -- '00 Integra Type R Black/Black -- Sold
In 2001 -- '01 S2000 Yellow/Black -- Stolen/Dead
In 2001 -- '01 S2000 Yellow/Black -- Traded In
In 2002 -- '02 S2000 Yellow/Black -- Traded In
In 2004 -- '04 S2000 Black/Black -- Returned To Dealer After 2 Weeks (They fkd' Up the Driver Door)
In 2004 -- '04 S2000 Yellow/Black -- Picked up on 3/20/04 Now TURBOED
In 2004 -- '90 Honda Accord EX Blue Metallic/Tan -- The Beyatch
In 2006 -- '06 Honda Civic EX Silver/Gray-Traded no depreciation!!!
In 2006 -- '06 Honda Element Black/Black Picked up on 8/19/06
" Have you ever been so confused about being confused with something so confusing that is confusing the hell out of you, for being confused about that which is so fuking confusing to begin with!"
Email PosterAOL  Ignore
Top
Offline 3ngin33r1
Posted: Oct 14 2003, 05:01 PM
· · · Quote Post
Gold Member
S2KI User #: 19859
PPD Average: 6.4
Enthusiast
Kingston, WA
WA -
Ok, and here we go direct from Defi for factory warning settings:
Turbo : about 98kpa
Oil and Fuel Press. : around 147kpa
Oil Temp.: around 120 degrees(Celsius)
Water Temp.: around 100 degrees(Celsius)
Exhaust Temp.: around 860 degrees(Celsius)
Top
Offline Johnny--2K
Posted: Oct 15 2003, 06:36 AM
· · · Quote Post
Guest
S2KI User #: 10687
S2KI Age: 7 yrs 230 days
PPD Average: 1.5
Enthusiast
Brookfield
US -
one question...maybe a dumb one...but just to save the time of taking everything apart and risking damage to any of the boards/pins, in the second picture, if you were VERY careful...couldnt you just use your blue sharpie to color in the hashes and numbers? It would be a little more tedious, but less risk of damaging something electrical!
I dont know, maybe it wouldnt work?!?
2003 Mustang Cobra Convertible - Delivered 7-29-09 with 7960 miles!!! Not stock anymore!! :D
2007 Grand Cherokee SRT-8 - SOLD!!
2005 Acura TL NightHawk Black Pearl/Quartz 6-speed/Navi! SOLD!
2003 Acura 3.2 TL (Winter Beater)SOLD!
2002 Sebring Silver/Red #854 w/ Hardtop.....SOLD!!
"Some around here call the S2000 the best Honda ever. Whether you agree or not, most at least believe the little roadster has already carved out a chapter for itself in the annals of future classic car-dom. And its done so in less than three years on the market. How much longer Honda churns out these gems we can't say; how much longer doesn't really matter. What matters is that so long as there are S2000s to fling like go-karts through city parks and down mountain roads, so long as that sweet little 2.0-liter keeps spinning out a mind-boggling normally aspirated 120 horsepower per liter, or so long as you can lie back, close your eyes and feel the snick-snick of the billet shifter in your grip, then the S2000--because it existed at all--is legendary already"
Autoweek March, 2002
Top
Offline 3ngin33r1
Posted: Oct 15 2003, 07:26 AM
· · · Quote Post
Gold Member
S2KI User #: 19859
PPD Average: 6.4
Enthusiast
Kingston, WA
WA -
If you color the numbers and hashes you change the shutdown color of the gauge face, which has them in red. You could do it that way if you wanted though. Mike look a bit ghetto.
Top
Offline BlueS2000Boy
Posted: Oct 15 2003, 06:39 PM
· · · Quote Post
Guest
S2KI User #: 10182
S2KI Age: 7 yrs 255 days
PPD Average: 3
Owner
2002 Suzuka/Nurburgring Blue/Blue
cooper city
US -
looks great
2008 SKYLINE 370GT PEARL WHITE
2008 Ducati 1098S TriColor
2009 Yamaha YZF-R1 Custom Ben Spies WSBK
2010 Yamaha YZF-R6........ crossing fingers new bike is out
Top
Offline 3ngin33r1
Posted: Oct 15 2003, 07:22 PM
· · · Quote Post
Gold Member
S2KI User #: 19859
PPD Average: 6.4
Enthusiast
Kingston, WA
WA -
Thanks Blue.
I was very leary of the blue dash project and not being satisfied with it's appearance but once I got the blue audio controls I felt much better, now that I've blued the Defi's I can't wait to get the rest of it done.
The blue is so much easier on my eyes at night. The stock orange, even with the brightness down was really getting to me.
Top
Posted: Oct 15 2003, 07:24 PM
· · · Quote Post
Guest
S2KI User #: 10182
PPD Average: 3
Owner
cooper city
US -
ya once i finish my interior i am goin gto start on the gauges.
Top
Offline SierraC3_S2000
Posted: Oct 16 2003, 07:53 AM
· · · Quote Post
Guest
S2KI User #: 27802
S2KI Age: 6 yrs 188 days
PPD Average: 0
Owner
2003 Suzuka/Nurburgring Blue/Blue
Americus
US -
There is an alternate way to keep your calibration when removing gauge needles. This works on any gauges and even factory instrument clusters.
1> Start car and let it idle for about 5 minutes.
2> Record or take a picture of the location of all your needles.
3> Do whatever mods your are planning to do.
4> Reconnect gauges minus needles.
5> Start car and let it idle for another 5 minutes.
6> Replace needles on the gauges in their previous recorded locations.
By the way the gauges look awesome.
Tim
Yahoo  Ignore
Top
Offline S2000PR
Posted: Oct 17 2003, 05:22 AM
· · · Quote Post
Gold Member
S2KI User #: 27467
S2KI Age: 6 yrs 195 days
PPD Average: 0
Owner
2000 Berlina Black/Black
San Juan
PR -
I like these gauges....
S2K Turbocharged Black/Black.
NSX 94' Stock
  Ignore
Top
Offline 3ngin33r1
Posted: Oct 17 2003, 11:43 AM
· · · Quote Post
Gold Member
S2KI User #: 19859
PPD Average: 6.4
Enthusiast
Kingston, WA
WA -
thanks.
Top
Offline S2000PR
Posted: Oct 17 2003, 02:06 PM
· · · Quote Post
Gold Member
S2KI User #: 27467
PPD Average: 0
Owner
San Juan
PR -
Very nice job!!!
  Ignore
Top
Offline jamskate
Posted: May 21 2008, 09:55 AM
· · · Quote Post
Guest
S2KI User #: 84300
S2KI Age: 1 yrs 263 days
PPD Average: 0
Enthusiast
US -
Great Post!!! I just got done doing all mine purple... I'll post pics when I have them all installed..
FYI - on the boost gauge there is a small spring that slides over a pin on the top circuit board that makes contact with the outer casing, becareful you don't loose it when disassembling that gauge(caught mine pop out from the corner of my eye).
Thanks again
Jam
Email Poster  Ignore
Top
Offline 3ngin33r1
Posted: May 21 2008, 10:09 AM
· · · Quote Post
Gold Member
S2KI User #: 19859
PPD Average: 6.4
Enthusiast
Kingston, WA
WA -
Good lord, you dug this one up didn't you?
Top
Pages: (2) [1] 2  Reply to this topicStart new topicStart Poll
Subscribe to this topic | Subscribe to this forum | Download / Print this Topic
