yippee..cylinder #2 misfire
Old Feb 29, 2004 | 11:06 AM
MyHieu's Avatar
Yesterday the weather was so nice , i took it out for a nice drive since the car has been in the garage for 2 months. This morning went out to start the engine, CEL (Check Engine Light) came on. Have no freakn idea what causes it, so i went to Autozone have them check it out for free (woohoo!) The code PO302 showed up saying cylinder #2 misfire and there's the other code P1399 or Pl399 (?) doesn't said what it is. My question is how bad is it? Anyway of fixing it or i'll have to take to the dealer? Thanks to all that respond!
Old Feb 29, 2004 | 04:24 PM
vepas's Avatar
I had a cylinder misfire at about 18,500 miles, and the dealership replaced all the fuel injectors. They tried just one and it helped, but all four fixed it completely. Just make sure if you have it done, they order enough injectors to do them all. For mine, they only ordered the parts for one, and I had to wait an extra couple of days for the them to wait for the parts to replace the others. Ever since then, I have had no problems. If you decide to wait awhile to get it fixed, I believe it will not cause any problems, just give you a rough ride. Hope that helps.
Old Feb 29, 2004 | 04:34 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Try swapping coils from cyl 2 and 3, at least you can narrow it down.
Old Feb 29, 2004 | 04:50 PM
thongfoto's Avatar
Anyone know what causes these cylinders to misfire?
Is it just age, abuse, lack of maintenance or ...?
Old Mar 18, 2004 | 10:14 AM
clownfish's Avatar
i just brought my car into the dealship for a cel problem and they diagnosed the car having a misfire on cylinder #2. The technician said one of the vaccum hose is bent wrong? so the air wasn't flowing smoothly to the MAP sensor causing it to read +/- voltage somewhere. That's why the cel was on. We'll see if my cel comes back on.
Old Mar 20, 2004 | 10:58 PM
MyHieu's Avatar
They said it was one of the spark plug recall on mine....good luck on yours...
Old Sep 17, 2004 | 09:03 AM
Siepel's Avatar
Today my S2000 also remained misfiring cylinder #2 (only 3 or 4 times before, but just a few seconds at startup).
I added in Rick's link here: https://www.s2ki.com/forums/index.php?showt...0&#entry4468347
Regards,
Siepel
Old Sep 17, 2004 | 09:14 AM
hpark's Avatar
from my experience it could be a fuel injector being clogged or not functioning properly...probably just age and not much you can do assuming you run good quality gasoline....i don't know how effective those fuel injector cleaners are (never tried them)
Old Sep 17, 2004 | 10:04 AM
RazorV3's Avatar
the 2003 and newer s2000's have this problem fixed right? i recall seeing the sparkplug recall applied up to MY2002.
Old Sep 17, 2004 | 10:16 AM
Siepel's Avatar
My car had both the sparkplug recall and European oil jet bolts recall done in September 2002...
Are there more people with clogged fuel injector problems (even mainly on cylinder #2) just assuming that is actually the problem on my poor car...
Thanks guys!
Siepel
