Important note: check the screen located in your VTEC solinoid...
Old Mar 17, 2004 | 04:16 PM
beroznikmal's Avatar
Default Important note: check the screen located in your VTEC solinoid...
Symptoms:
1. vtec disabled
2. A weird noise coming for the general area of the vtec solinoid...... kindda like a loose heat sheid rattling. It only occured after 2500 RPMS......
The fix.....
clean your vtec solinoid screen....
Beroz
Old Mar 17, 2004 | 04:22 PM
Gernby's Avatar
Got any pics?
Old Mar 17, 2004 | 05:09 PM
didn't think about it.... I think there are three holes on the solinoid the screen is on the bottom. It says in the helms manual taht the screen should be cleaned from time to time....
Beroz
Old Mar 17, 2004 | 05:17 PM
mxt_77's Avatar
What did you find in yours?
Old Mar 17, 2004 | 05:57 PM
just stuff..very fine dirt......
Old Mar 17, 2004 | 06:01 PM
Slows2k's Avatar
The "stuff" is sludge. Have you been changing you oil regularly?
Clogged VTEC screens are usually found on cars without frequent oil changes. I've cleaned plenty of them.
Old Mar 17, 2004 | 06:03 PM
Yes sludge...
I change my oil every 3000 miles... not sure what happened... I am guilty of using a cheap oil filter... I am considering upgrading the filter because of this.....
maybe HAMP oil filters????
Beroz
Old Mar 17, 2004 | 06:05 PM
Slows2k's Avatar
How many miles on the car?
Old Mar 17, 2004 | 06:06 PM
spider's Avatar
Where exactly is this VTEC screen?
Old Mar 17, 2004 | 06:07 PM
Slows2k's Avatar
Between the VTEC solenoid/valve assembly and the cylinder head.
