| Welcome Guest ( Log In | Register ) | Resend Validation Email |
| Pages: (3) [1] 2 3 ( Go to first unread post ) | ![]() ![]() ![]() |
Kodokan_4 |
Posted: Nov 26 2004, 07:45 PM
Gold Member![]() S2KI User #: 14775 S2KI Age: 7 yrs 136 days PPD Average: 1.8 Owner 2002 Sebring Silver/Custom Judo Town, USA ![]() |
I needed to remove the radio door and trim plate so they can go to the CF shop.
Just thought some of you might like to see how easy it is: First, put the shift lever in reverse, and cover the lever and the console with a folded t-shirt or other padding. Pull firmly one one side of the radio door, until the lower clip releases. Do the same to the other side. Then pull a little harder on each side, until the middle clip releases. ![]() When the middle clip on the right side releases, a small space will open up near the top- insert the tape-covered screwdriver here: ![]() Cover the surrounding parts with tape, and don't pry on anything. Use the tip of the screwdriver to push the backside of the plastic forward (it comes out very easily): ![]() Padded screwdriver: ![]() To remove the radio door from the trim plate, use something like this to push out the retaining pins (a coathanger will do). Remember to protect the surface with tape: ![]() Parts ready to go: ![]() -Pete -------------------- Creator of the S2000 Seat Locks ![]() "Life's too short .... Don't waste it !!!" - Travis Hunt "Please take good care of your S2000, keep it by your side for long and enjoy it from the bottom of your heart and share the quality and legacy of the S2000 with many friends so that the legend of the S2000 will continue for long." - Shigeru Uehara |
freq |
Posted: Nov 27 2004, 06:28 AM
Moderator![]() S2KI User #: 31172 S2KI Age: 6 yrs 75 days PPD Average: 5.6 Owner 2000 Berlina Black/Black A-List E-Thug ![]() |
With a MY'04+ console the console needs to be removed (or at least pulled up) first before the radio door assembly can be removed. FYI
-------------------- /l ,[____], l---L -0lllllll0- ()_) ()_)--O-)_) ![]()
toosoonjunior |
Posted: Nov 27 2004, 12:20 PM
Guest S2KI User #: 39594 S2KI Age: 5 yrs 136 days PPD Average: 0.1 Owner 2000 New Formula Red/Black Denton, TX ![]() |
What kind of tool is that you're using in that picture? I'm having trouble getting the pins out. They don't seem to be budging. I tried a coathanger and nail so far, so any help would be appreciated. This post has been edited by toosoonjunior on Nov 27 2004, 12:27 PM
Adis82 |
Posted: Nov 27 2004, 12:25 PM
Guest S2KI User #: 5730 S2KI Age: 8 yrs 103 days PPD Average: 0.8 Owner 2002 Berlina Black/Black Glendale, CA ![]() |
Sounds like you've got a CF addiction!
Kodokan_4 |
Posted: Nov 27 2004, 12:35 PM
The pins in my radio door slid out like butter, I didn't have to push hard at all. Make sure you are pushing them straight out, not at an angle. The bend in the tool helps to accomplish this. The tool I used will probably be hard to come by. It's a 17g needle normally used for placing an epidural catheter in someone's back. I cut the tip off, so it isn't sharp. I'm in anesthesia school, so I just happened to have an unused one laying around. I couldn't find a wire coathanger anywhere- go figure. -Pete |
MaxGeek |
Posted: Nov 27 2004, 12:45 PM
Guest S2KI User #: 30895 S2KI Age: 6 yrs 88 days PPD Average: 1.3 Owner 2000 Silverstone/Black WA ![]() |
I think you can also use pliers to get those pins out if your having trouble using a poking stick.
pierceman |
Posted: Nov 27 2004, 07:25 PM
Gold Member S2KI User #: 12821 S2KI Age: 7 yrs 181 days PPD Average: 4.3 Owner 2004 Berlina Black/Black socal ![]() |
pete, good to see a post from you, hope all is well, can not wait to see the finished door.
MAtt -------------------- 02 nsx supercharged Sold! 07 mdx mods 09 mdx wifes 89 S13 tracks |
Incubus |
Posted: May 12 2005, 04:01 PM
Guest S2KI User #: 5728 S2KI Age: 8 yrs 103 days PPD Average: 1.8 Enthusiast ![]() |
That's exactly what I needed. I knew I was missing a piece of information from somewhere. Thanks. --------------------
anthonys2k |
Posted: May 12 2005, 11:55 PM
Guest S2KI User #: 37209 S2KI Age: 5 yrs 209 days PPD Average: 0.2 Owner 2001 New Formula Red/Black USA |
does the trim have to come off to to just replace the radio door?..i just want to replace my 01 radio door with the newer one...how would i do that?..
Kodokan_4 |
Posted: May 13 2005, 03:48 AM
Yeah, the trim has to come off to change the radio door. -Pete |
Incubus |
Posted: May 13 2005, 06:56 AM
If I may step in...
Anthony, You need to remove the trim and door as one unit. While the trim is out, remove the door from that big trim piece. Put the new door in the old trim piece and reinsert it into the dash of the car. Does that sound accurate to ya'll? That's the way I see it happening. |
anthonys2k |
Posted: May 13 2005, 10:29 AM
ok..thats sounds right..just summed up...thought there might be an easier way without taking the trim out, oh well..how long do you think it would take?..about an hour?
Incubus |
Posted: May 13 2005, 10:45 AM
No way it would take that long. I got the trim out in about five minutes, and that's because I had to run inside to get some electrician's tape to protect the dash. If your car is MY2000-2003, then you don't have to remove the center console. Just follow the steps above and you'll be alright.
I think the first step to any project is to find the right tools/materials. |
iNetForce |
Posted: May 20 2005, 05:36 PM
Guest S2KI User #: 43672 S2KI Age: 4 yrs 353 days PPD Average: 0.5 Owner 2006 Laguna/Bermuda Blue/Black Hialeah, FL ![]() |
Great write up. I just did mine today. I didnt have to pry out the backside though. Pins were kind of hard to get out.
Thanks. -------------------- |
Kodokan_4 |
Posted: May 20 2005, 06:18 PM
The parts just went back in a couple of weeks ago.
Here's the finished product. The inside of the radio door and trim piece were done, as well. -Pete |
Incubus |
Posted: May 20 2005, 06:25 PM
Explain!!! I think it looks great! Did they use your old piece as a mold, or is it some kind of cover? Looks awesome!
anthonys2k |
Posted: May 20 2005, 08:01 PM
that looks great
XLeezardx |
Posted: Jun 14 2005, 05:52 AM
Guest S2KI User #: 47524 S2KI Age: 4 yrs 243 days PPD Average: 0.7 Owner 2002 New Formula Red/Black Dallas Texas ![]() |
I changed my radio door out yesterday. But the problem is that the door opens slow now. did i put the spring in wrong or something? how many springs are there?
-------------------- www.myphonelounge.com
Nhan |
Posted: Jun 14 2005, 07:14 AM
Member S2KI User #: 10821 S2KI Age: 7 yrs 227 days PPD Average: 1.4 Owner 2002 Suzuka/Nurburgring Blue/Blue Savannah ![]() |
push the spring Inwards, so that the round piece is over it..it should solve the prob...
-------------------- Retired S2K Owner 02' Suzuka Blue Engine Comptech Supercharger w/ AC / Tech2 9lb pulley & Godzilla BOV / Comptech Differential with 4.57 gears / Stage 4 Competition Clutch & Lightend Flywheel / Fujitsubo Headers & Exhaust / RC650cc / NGK 7173 Spark plugs / KrankVents / Engine Management AEM EMS 1052 tuned by Mase @ Stage6Performance.com / Dynoed 345whp-200lb tq (on Dyno Dynamics) / Exterior J's Racing Half Lip with Canards / Airwalker Side Skirts / Feels Rear Lip / J's Titanium Blue Knob / Seibon Mugen Style Hood Painted / AP2 Headlights Conversion / Rick's Blue S2000 Badge / 35% Tint / Wheels COMING SOON :LOL: Suspension Bilstein PSS9 / ICE Alpine 9833 / Infinity 60.5cs / Rockford 1000.2 Amplifier / Rockford Punch 10" / Rockford Capacitor /
Congo |
Posted: Jul 26 2006, 08:01 PM
Guest S2KI User #: 52113 S2KI Age: 4 yrs 99 days PPD Average: 1.3 Owner 2000 New Formula Red/Black Wales ![]() |
AHH...my pins wont come off. and it's hard to get nething into the hole to push out the pins. Mine looks kinda rusted @ the end where shows and i've been trying to push out the pins, and no luck.
Kwando |
Posted: Jul 26 2006, 08:08 PM
Guest S2KI User #: 1208 S2KI Age: 9 yrs 9 days PPD Average: 1.5 Owner 2001 Spa/Indy Yellow/Black Aurora ![]() |
subscribed... thx for the info...
AstroPhsx |
Posted: Jul 28 2006, 10:43 PM
Member![]() S2KI User #: 56310 S2KI Age: 3 yrs 331 days PPD Average: 0.5 Owner 2003 Silverstone/Black Lawrence, KS ![]() |
http://www.s2ki.com/forums/index.php?showtopic=408253&hl=
if you need info on why your door doesn't open all the way it's because of how you put in the spring, i just added a few more pics on what to do when you get the radio door out of the car
racerfan |
Posted: Jul 29 2006, 01:19 AM
Guest S2KI User #: 20339 S2KI Age: 6 yrs 359 days PPD Average: 0.3 Owner 2004 Sebring Silver/Black City of Asians ![]() |
Dang, someone should be selling those CF pieces its damn nice.
-------------------- For Sale: MSN Messenger: jlim@telus.net ![]()
YELLOS20003 |
Posted: Jul 30 2006, 09:11 AM
Member![]() S2KI User #: 39825 S2KI Age: 5 yrs 128 days PPD Average: 0.3 Owner 2006 Laguna/Bermuda Blue/Black Nashville TN ![]() |
ideugene |
Posted: Jul 30 2006, 03:21 PM
Gold Member![]() S2KI User #: 21055 S2KI Age: 6 yrs 342 days PPD Average: 2.3 Owner 2001 Berlina Black/Black NYC ![]() |
Looks good carbon whore
-------------------- My Africa Mission: http://www.s2ki.com/forums/index.php?showtopic=228562&st=0 FS- Lots O' Parts!!! Updated frequently
| Pages: (3) [1] 2 3 | ![]() ![]() ![]() |
