| Welcome Guest ( Log In | Register ) | Resend Validation Email |
| Pages: (2) [1] 2 ( Go to first unread post ) | ![]() ![]() ![]() |
PAS2KNut |
Posted: Feb 15 2005, 05:47 PM
Moderator![]() S2KI User #: 6912 S2KI Age: 8 yrs 32 days PPD Average: 1.2 Owner 2002 New Formula Red/Black Central, MA ![]() |
1. Purchase 3/4" MDF
2. Remove door panel. 3. Remove speaker and basket. 4. Take speaker basket and trace around the outer edge of the basket. 5. Find center of the traced pattern. 6. Determine hole cutout size. (Normally found in instruction manual for speakers) 7. Using compass trace circle the size of the cutout hole. 8. Using jigsaw, or other tool to cut out hole. 9. Now using a jigsaw cut around the pattern you first traced from the speaker basket. 10. Insert basket into cutout. 11. Trace the four hole around the outer edge. 12. Drill hole for screw to mount bracket to car. 13. Using large diameter drill bit make holes larger so screws will be counter sunk. 14. Pre-mount bracket to door with four screws to check fit. 15. Take bracket off and paint. 16. Re-mount bracket and mount speakers. -------------------- ![]()
Bass |
Posted: Feb 15 2005, 05:52 PM
Member![]() S2KI User #: 9933 S2KI Age: 7 yrs 267 days PPD Average: 13.5 Enthusiast Franklin MA ![]() |
very nice write up
darkknight1999 |
Posted: Feb 15 2005, 06:39 PM
Member![]() S2KI User #: 2703 S2KI Age: 8 yrs 245 days PPD Average: 3.5 Owner 2002 Suzuka/Nurburgring Blue/Blue Boston, MA ![]() |
Great Job Jim!!
-------------------- -JOHN "Pumping lots of bass to a tweeter is like stuffing a basketball into a pigeon—neither will survive" - ME-Mag
NFRs2000NYC |
Posted: Feb 16 2005, 11:16 AM
Moderator![]() S2KI User #: 25356 S2KI Age: 6 yrs 238 days PPD Average: 6.8 Owner 2003 New Formula Red/Black New York ![]() |
Kick a$$!
mt rsx |
Posted: Feb 18 2005, 01:25 AM
Guest S2KI User #: 34981 S2KI Age: 5 yrs 281 days PPD Average: 0 Owner 2000 Porter Ranch ![]() |
This is the only part I didn't get...what exactly is counter-sunk, and how will the screws hold the wood in place if the pr-drilled holes are larger that the screw diameter used? btw...you made this look so easy I will definitely be doing this by myself for my next car (hopefully the S) |
s2uk |
Posted: Feb 18 2005, 01:42 AM
Guest S2KI User #: 39571 S2KI Age: 5 yrs 136 days PPD Average: 2.1 Enthusiast homeless ![]() |
i did mine last night and only just saw this thread, good idea on painting them, didnt think of that so i will be psinting mine today, finishes the look off.
Cyclon36 |
Posted: Feb 18 2005, 08:10 AM
Sponsor![]() S2KI User #: 36703 S2KI Age: 5 yrs 216 days PPD Average: 1.7 Owner 2005 Rio/Indy Yellow/Black Villa Rica, Georgia ![]() |
Good Job! Added this thread to my how to section (link below).
As a word of advice, the door panels get a good bit of moisture in them when it rains. Using MDF might not be the best idea although it is easy to work with. Since you're not using it to make an enclosure, I would recommend using standard finished plywood. If it's exposed to moisture, it won't expand or buble like MDF. The paint does help though. The best solution would be 3/4" plastic like plexi or something. Of course, that's a little harder to come by. -------------------- The BIG list of S2000 parts and accessories. The BIG list of S2000 How-To's The BIG list of S2000 FAQ's
SheDrivesIt |
Posted: Feb 18 2005, 12:21 PM
Member S2KI User #: 41378 S2KI Age: 5 yrs 68 days PPD Average: 3.4 Owner 2004 Silverstone/Black Cincinnati ![]() |
He is counterboring the mdf bracket so that the bracket mounting screws will be below the surface when it is mounted. Otherwise, the flange of the speaker would rest in the mounting screws for the bracket. The couterbores do not go through the mdf bracket. They only go deep enough so that the head of the mounting screw will be below the surface. --------------------
mt rsx |
Posted: Feb 18 2005, 01:25 PM
huh? |
SheDrivesIt |
Posted: Feb 18 2005, 01:48 PM
What part do you not understand. Do you not understand the words countersunk or counterbore? |
mt rsx |
Posted: Feb 18 2005, 02:27 PM
Precisely...I never took woodshop class |
SheDrivesIt |
Posted: Feb 18 2005, 03:01 PM
Picture a hole drilled through a piece of wood. The hole, when viewed from the side, will just look like a simple column. When you counter bore or counter sink it, a larger cutting tool (drill bit) is used to open up the one end of the hole so that the head of the screw will fit inside but still tighten up against the wood but the head of the screw will be past the surface of the wood.
If you look at a flat head screw from the side, the head is shaped like a triangle. If you use a drill bit the same or slightly larger diameter than the screw head, you can drill a little into the 3/4" MDF (or wood) just enough so that the head of the screw is not sticking up. Better? |
s2uk |
Posted: Feb 25 2005, 07:43 AM
suzukas2000 |
Posted: Feb 28 2005, 05:30 PM
Guest S2KI User #: 40245 S2KI Age: 5 yrs 113 days PPD Average: 0.3 Owner 2004 Suzuka/Nurburgring Blue/Blue FL ![]() |
nice speakers how do they sound? -------------------- Phil ![]() 04 Honda S2000 Engine: HKS Racing Suction Kit, J's 60RS w/ Megan Test Pipe. Suspension: Megan Coilovers, Megan Strut Bar Wheels and Tire: 16" Volk Racing TE37 Gunmetal with Hankook RS2: 205/55/16 and 245/45/16 Audio: Pioneer DEH-P9800BT, Pioneer TS-160R, Infinity 2CH Amp Other Goodies: AP1 Slave Cylinder, Black Chrome "H" Badge, Blue Convex Mirror, Modifry's Audio Control, and Shift Beeper. Alarm: Clifford G5 750 w/ proximity sensor + GPS Tracking |
s2uk |
Posted: Mar 1 2005, 08:26 AM
have not got them in my car as yet due to it being hit, they have very good reviews though, should get my car back in four weeks so will post once they get powered up. still a long way to go in building the system only started three weeks ago and most of the bits have only just arrived from the US, so much better price than here in the UK. cant wait to get it all put in the car once its back. |
s2kneo |
Posted: Nov 24 2005, 10:48 PM
Guest S2KI User #: 52671 S2KI Age: 4 yrs 82 days PPD Average: 0 Owner 2001 Spa/Indy Yellow/Red ![]() |
Does this create any issues with the door panel?
PAS2KNut |
Posted: Nov 25 2005, 05:03 AM
No |
Dylan Hunt |
Posted: Nov 26 2005, 10:42 AM
Guest S2KI User #: 22640 S2KI Age: 6 yrs 301 days PPD Average: 1.5 Owner 2001 GrandPrix White/Black-Red NJ ![]() |
nice nice, I started the process
-------------------- Whatever life holds in store for me, I will never forget these words: "With great power comes great responsibility." This is my gift, my curse. Who am I? I'm Spiderman.
Dylan Hunt |
Posted: Nov 26 2005, 10:49 AM
Just wondering, are our speakers 6.5 inch? Because I got 6.5 inch /160mm JL Audio Coaxials and I don't think they fit
AlanL |
Posted: Nov 26 2005, 12:16 PM
Guest S2KI User #: 44667 S2KI Age: 4 yrs 321 days PPD Average: 0.2 Owner 2005 Silverstone/Black Vancouver, WA ![]() |
The OEM speakers are slightly smaller than 6.5". I have seen some posts refer to them as "european 6.5". That's the whole reason for this thread - very few aftermarket 6.5" speakers will fit the OEM mounts without building something like this bracket.
My Diamond D661s speakers were considerably larger than the OEM holes, but worked fine with a bracket just like the one described here
Cyclon36 |
Posted: Nov 26 2005, 12:37 PM
FWIW, the Polk Audio Momo speakers come with these brackets already in the box. Makes install a breeze and they won't warp since they're plastic.
Dylan Hunt |
Posted: Nov 30 2005, 11:41 PM
Tada!!!
Thanks!!! This is awesome!!! I'd paint but I'm too lazy. ![]() |
JDM S2000 |
Posted: Jul 13 2006, 07:54 AM
Banned S2KI User #: 1954 S2KI Age: 8 yrs 301 days PPD Average: 0.5 Owner 2001 New Formula Red/Black Milwaukee ![]() |
will 1/2 mdf make a huge differnce, only reason i ask is I have a ton of it
-------------------- 01.Formula Red.Comptech SC w/Aftercooler.Alpine 9856.Alpine Type S 6.5.Polk DB 10". Alpine Amp.Eibach Pro Kit.Comptech Catback Exhaust
PAS2KNut |
Posted: Jul 13 2006, 08:31 AM
You will loose a 1/4" of mounting depth. If your speakers don't need the extra depth to clear the window when it's in the down position then the 1/2" should be fine. |
JDM S2000 |
Posted: Jul 13 2006, 08:33 AM
Alpine Type S
is what they are. Ill try 1/2 and if that doesnt work ill go buy some 3/4 |
| Pages: (2) [1] 2 | ![]() ![]() ![]() |
