| Welcome Guest ( Log In | Register ) | Resend Validation Email |
Wisconsin S2k |
Posted: Feb 26 2005, 09:08 PM
Guest S2KI User #: 4905 S2KI Age: 8 yrs 147 days PPD Average: 3.3 Owner 2002 New Formula Red/Black Germantown, WI ![]() |
So my girlfriend was telling me that a relative of hers had the argument the other day that once you use synthetic you can't go back to regular. This obviously isn't true, but he was insistent. I know from the oil journals here that going back to minoil after being on synoil is fine.
Anyways, readin the oil journals I could not find any specifics on where the myth comes from and any technical information to debunk it. I'm hoping to get a good solid answer here and maybe then it can be placed as an addendum to the oil journals FAQ under "switching from synthetic back to mineral".
Slows2k |
Posted: Feb 26 2005, 09:28 PM
Poop Magnet![]() S2KI User #: 13878 S2KI Age: 7 yrs 157 days PPD Average: 9.3 Owner 2002 Spa/Indy Yellow/Black ![]() |
Untill you have specifics of what happened to the engine, what type of car etc. etc. It's way to early to blame switching back to synthetic.
Diagnosing the failure is the 1st step to eliminating synthetic oil as a cause. -------------------- Whoretech'd twice ;) R.I.P. JS. ![]() ![]() ![]() ![]()
ol' dood |
Posted: Feb 26 2005, 10:58 PM
Guest S2KI User #: 42541 S2KI Age: 5 yrs 24 days PPD Average: 0.1 Owner 2003 Sebring Silver/Black ![]() |
How can you expect a solid answer when you provide so little info about the car? Saying that the engine 'blew' or 'went' means nothing. It's like saying, 'Hey, I picked up my date last night and after I drove 10 miles, my engine blew. Do you think that she caused the engine to blow'? I don't mean to be a smartass, but if you want to do a cause/effect determination, you need much more info. Personally, I doubt that switching back to non-synthetic oil is the culprit. If you've read the oil journals, you know how good present-day mineral oils are. Blaming the engine failure on the oil is probably wrong.
Wisconsin S2k |
Posted: Feb 27 2005, 08:28 AM
The point of the thread was NOT to diagnose the engine. To my understanding that is irrelevant, since going from synthetic to mineral will NOT cause an engine to die in any way shape or form.
I was simply trying to get some technical information dispelling the myth that you CANT go back to mineral after using synthetic. THAT is the purpose of this thread. Not to diagnose the problem of the old car. |
Wisconsin S2k |
Posted: Feb 27 2005, 08:29 AM
See? this phrase in my original post? THIS is the purpose of this thread. |
Slows2k |
Posted: Feb 27 2005, 08:46 AM
PM Road Rage, he's the only one on the board who is a oil engineer.
I still think it's easier to diagnose the failure at hand than disprove a unrelated theory. |
PilotKD |
Posted: Feb 27 2005, 09:19 AM
Member![]() S2KI User #: 31233 S2KI Age: 6 yrs 71 days PPD Average: 1.1 Owner 2004 Suzuka/Nurburgring Blue/Blue South Jersey ![]() |
Total coincedence. An engine is not going to get "addicted" to synthetic and then
-------------------- 2004 Suzuka Blue S2000
hondamanwill |
Posted: Feb 27 2005, 09:22 AM
Member S2KI User #: 37660 S2KI Age: 5 yrs 199 days PPD Average: 0.4 Owner 2001 Spa/Indy Yellow/Black Milwaukee Wi ![]() |
Hey Matt are we talking about a GM product? I have seen lots of problem with GM's blowing motors after doing intake gaskets. Intake leaks cause coolant oil mix washing the main and rod bearings. Due to the lubricant ability of Synoil maybe switching to a conventional oil may have been the death of it. Let us know.
But to answer you question switching oil should not cause a motor to blow. I have seen switch from on oil to another can cause problems since some oils run wax additives and when switching from one to another the detergent in an oil can cause the wax additives to be washed out and glogging oil passages etc. But switching from Synoil to Regular NO! P.S. seen this happen to fords V6's too This post has been edited by hondamanwill on Feb 27 2005, 09:23 AM -------------------- A bad day in racing is better than a good day at work. Light travels faster than sound. That’s why some people appear bright until you hear them speak.
Wisconsin S2k |
Posted: Feb 27 2005, 09:42 AM
i'm going to edit my original post to remove the unrelated story. it was really just kind of a side story vs the real topic i had started. will i'm not sure on the GM product. i'll find out and PM you. |
Road Rage |
Posted: Feb 28 2005, 02:09 PM
Guest S2KI User #: 27613 S2KI Age: 6 yrs 191 days PPD Average: 1.5 Owner 2004 Silverstone/Black-Red Midlothian ![]() |
This is one of those synoil myths that hangs around forever. I found a 20 year-old article in my archives that had this, and about 9 more, synboil myths.
As best i have been able to determine, looking at my 30 years of info on the topic, the "warning" never has had anything to do with a failed engine, or any engine mechanical failure for that matter. It likely was made up by a salesman or seller of a synoil mfr, hoping to "scare" clientele into staying the course. ****************************************************************** Switching TO synoil on a very old engine is a different matter.I often do not recommend it, esdp for engines with questionable maintenance history, or ones that are 10 years old older. A look into the oil fill will often show a lot of varnish and/or sludge. I believe it originates from the high detergency of synoils vs the older minoils. Oxidation and sludging were common with old minoils, and in many cases, it was sludge that was keeping seals/gaskets from leaking - valve cover gaskets, even some oil stem seals. Using synoil in an engine with sludge often caused leaks, and it certainly caused the synoil to get very dirty very fast, reqruiring more frequent oil changes than a synoil should require, at elast until the cleaning was completed. -------------------- 2004 S2000 Silverstone/Red & Black #1701 "Khan" Mugen exhaust, fan switch, thermostat Spoon snorkel intake, modified OE airbox, AFE filter Denso Iridium IK-24 sparks Team Voodoo Pearl aluminum knob Rick's X-brace V1 hardwired StopTech slotted rotors StopTech SS brake lines Red calipers (G2) Lubricants/additives: Engine: Havoline or Motorcraft GF-4 spec with Honda PCX filter Tranny: GM Synchromesh Friction-Modified or SF MTL-P Brake: Ate Super Blue or Motorcraft Super Premium DOT3 Clutch: Motorcraft Super Premium DOT3 Differential: LE 607 90w (API GL-5) Fuel: Lube Control or Red Line SI-1 / SI-2 2004 Acura TL - Deep Green Pearl/Camel 5AT 2003 SVT Mustang Cobra (497 rwhp) 1997 Subaru Outback (beater) |
Wisconsin S2k |
Posted: Mar 1 2005, 09:56 PM
thanks for the info!
Wisconsin S2k |
Posted: Mar 8 2005, 01:39 PM
So in other words that USED to be the case... where there were a higher amount of detergents in synoils vs minoils. But not from what I see, they are more even on the cleaning detergents. So maybe 20 years ago this was the case, but now the oils have evened out... |
YER-SLOW |
Posted: Jul 17 2007, 03:12 PM
Guest S2KI User #: 52369 S2KI Age: 4 yrs 91 days PPD Average: 0.3 Owner 2000 Silverstone/Black FL... ![]() |
Switching back will not blow your motor at all...
The only reason people say that you cant go back is because they really dont understand that is just what they are told... Regular oil has acid in it and that is why you have to change it so quick... Synthetic oil does not have acid so you dont have to change it as quick... Going back to reg oil you are going to put that acid back in the motor, which eats up your cylinder walls... -------------------- |
iam7head |
Posted: Jul 17 2007, 03:26 PM
Guest S2KI User #: 55920 S2KI Age: 3 yrs 341 days PPD Average: 3.8 Owner 2000 Silverstone/Black Pasadena, SOCAL ![]() |
so wrong, in so many level --------------------
VAD |
Posted: Jul 18 2007, 08:35 AM
Member![]() S2KI User #: 44427 S2KI Age: 4 yrs 328 days PPD Average: 11.3 Owner 2003 GrandPrix White/Tan Malta Il,by the grain elevator ![]() |
wow.... -------------------- "I am a most unhappy man. I have unwittingly ruined my country. A great industrial nation is controlled by its system of credit. Our system of credit is concentrated. The growth of the nation, therefore, and all our activities are in the hands of a few men. We have come to be one of the worst ruled, one of the most completely controlled and dominated Governments in the civilized world - no longer a Government by free opinion, no longer a Government by conviction and the vote of the majority, but a Government by the opinion and duress of a small group of dominant men." --President Woodrow Wilson
90crvtec |
Posted: Jul 18 2007, 08:44 AM
Guest S2KI User #: 56321 S2KI Age: 3 yrs 331 days PPD Average: 0.5 Owner 2003 Spa/Indy Yellow/Black Kansas City ![]() |
iDomN8U |
Posted: Jul 18 2007, 09:05 AM
Member![]() S2KI User #: 58298 S2KI Age: 3 yrs 275 days PPD Average: 3.3 Owner 2003 Silverstone/Black Ontario ![]() |
Well, when oil sits around in the oil pan for a long time after it has been used, the gas + air + moisture will breakdown and it starts to turn acidic. Which could pit bearing etc etc.
Why bring up such an old thread to make a comment like that? This post has been edited by iDomN8U on Jul 18 2007, 09:05 AM
SpitfireS |
Posted: Jul 18 2007, 09:30 AM
Guest S2KI User #: 54485 S2KI Age: 4 yrs 18 days PPD Average: 2.2 Owner 2000 Berlina Black/Black 17 ft below sea level. ![]() |
Besides.. most "synthetic" oils in the US are group III based oils, IOW mineral based, IOW dino based oil.
Thanks to Mobil. -------------------- |
iDomN8U |
Posted: Jul 18 2007, 09:53 AM
How about semi-synthetic, I believe they are also group II-III?
