| Welcome Guest ( Log In | Register ) | Resend Validation Email |
| Pages: (2) 1 [2] ( Go to first unread post ) | ![]() ![]() ![]() |
Bonesy |
Posted: Jun 24 2008, 03:25 AM
Guest S2KI User #: 9564 S2KI Age: 7 yrs 204 days PPD Average: 0.5 Owner 2002 Spa/Indy Yellow/Black Wiltshire ![]() |
not sure whether i can add comments here, but
- Passenger Side: Bosch 20" around £7.50 - Driver Side: Bosch 16s - £8.50 s is for the spoiler Isn't the driver side wiper the onger one, the 20"? This post has been edited by Bonesy on Jun 24 2008, 03:26 AM
Bouchehog |
Posted: Jun 29 2008, 02:31 PM
Guest S2KI User #: 68294 S2KI Age: 2 yrs 249 days PPD Average: 0 Owner 2002 Silverstone/Black Norton, Stockton-on-Tees ![]() |
You don't have a section for "leaking roof seals" or "motorway wind-noise" from the hood, both of which would be (have been!) very useful.
I had a problem with wind-noise at high speeds and a leaky hood which was due to wear on the hood striker plates meaning that the seal wasn't tight enough. You link to a thread on replacing the striker plates under "Rattling Roof Catches" but it would help if there were separate sections for those problems - it's a bit of a leap of imagination to go to rattling roof catches to resolve the problem! |
AquilaEagle |
Posted: Jul 8 2008, 11:24 AM
Admin![]() S2KI User #: 18211 S2KI Age: 6 yrs 335 days PPD Average: 35 Owner 2009 GrandPrix White/Black-Red 2002 Silverstone/Black-Red ![]() |
-------------------- "Please take good care of your S2000, keep it by your side for long and enjoy it from the bottom of your heart and share the quality and legacy of the S2000 with many friends so that the legend of the S2000 will continue for long." - Shigeru Uehara - Chief Designer, S2000 - 12th April 2009, Trentino, Italy "S2000 came from a dream; it was built with passion and even though production will end on 7th August the dream will live on, so please keep it by your side for long!" - Mr. Aoki - Honda Collection Centre - S2000 Final Production Tour 11th July 2009, Motegi, Japan ![]()
AquilaEagle |
AquilaEagle |
Posted: Jul 11 2008, 10:12 AM
Boot release faliure
http://www.s2ki.com/forums/index.php?showtopic=612610 |
AquilaEagle |
Posted: Aug 17 2008, 04:52 AM
simonprelude |
Posted: Aug 26 2008, 02:09 AM
Gold Member![]() S2KI User #: 36433 S2KI Age: 5 yrs 144 days PPD Average: 3 Owner 2003 Imola Orange/Black Somerset ![]() |
I don't run aircon and bought an 1138mm belt, there is no way this will fit. The one I removed was an 1163mm so someone might want to check the information on that one, unless the 1138 is from a US model and any ancillaries are located differently ?? -------------------- ![]() ![]()
m1bjr |
Posted: Nov 13 2008, 02:42 PM
Member![]() S2KI User #: 63803 S2KI Age: 3 yrs 32 days PPD Average: 6.3 Owner 2006 Silverstone/Black-Red Bridgwater, Soms. ![]() |
HID Headlamp adjustment, particularly useful after lowering the car.
HID headlamp Adjustment after lowering the car -------------------- No Boost, No Bottles, Just You and the Throttle. NA F20C. ![]() ![]() HOWTO GUIDE: KW V3 Coilovers, Megan Rear Bumpsteer Mod & T1R Front Bumpsteer Mod Installation
simonprelude |
Posted: Nov 29 2008, 02:31 AM
Can we add this in.................
OEM Wheel Fitments For reference, the OEM MY00-03 (16") wheel sizes and offsets are as follows: Front: 16" x 6.5", +55 offset, 205 tire Rear: 16" x 7.5", +65 offset, 225 tire and the OEM MY04+ (17") wheels are as follows: Front: 17" x 7.0", +55 offset, 215 tire Rear: 17" x 8.5", +65 offset, 245 tire |
AquilaEagle |
Posted: Dec 24 2008, 03:28 AM
AquilaEagle |
Posted: Feb 13 2009, 11:21 AM
Shopman |
Posted: Feb 15 2009, 12:07 PM
Member![]() S2KI User #: 51130 S2KI Age: 4 yrs 48 days PPD Average: 1.4 Owner 2005 Silverstone/Black Camberley, Surrey UK ![]() |
Make your roof catches adjustable to take up wear, stops leaks and and wind noise.
http://www.s2ki.com/forums/index.php?act=S...0#entry15616246 More about roof leaking - adjustments etc. Leaking roof **************************** If your elastic hood straps become limp (probable life 4years) I've described a DIY way to make replacements in the following thread. Worn out straps can cause problems with the hood not folding properly. Can cause the catches to tear the hood if really bad but normally the symptom is a hood that doesn't fold down flat. DIY strap replacement ***************************** A sharp area on the hood frame can cut your roof. A simple mod to stop this happening-worth doing straight away as it is a very common problem. Roof Wear Mod Alternative material for covering the frame: Chainstay Protector See thread here: Using Lizard Skins Chainstay Protector ***************************** Want to look up a part or an exploded part drawing? With the proviso that the parts shown are for US spec cars and prices are in $ and the ref. numbers might not be the same in the UK, still quite useful Honda eStore parts look-up Enter Model & Year and find part. **Edit** Looks like you need to register now** Another one:- Honda Parts Catalogue ***************************** Honda accessory fitting instructions in PDF form: Accessory Fitting instructions MY2005 Assessory Fitting Instructions MY2003 ***************************** If you haven't got an owners manual they are available in interactive form for all years and all Honda models 1990-2009 here: Interactive Honda Handbook Zip file WS/Manual Another version here, very easy to read in book form. Click on full screen for best effect. (00-03) Part 1 (00-03) Part 2 (00-03) Part 3 **************************** Install Guide: KWv3, Bumpsteer kits., Coilovers, Megan Toe Arms, T1R spacers By M1bjr Install Guide **************************** How do you change the manifold? Good write up here: Header change **************************** MB's Big thread for idle / hesitation / kangeroo probs!, DIY diagnosis! **************************** MY04-05-06 clutch delay slave cylinder removal - fed up with that awful smell of burning clutch plates? MY04-05-06 clutch delay slave cylinder removal **************************** Clutch Fork Greasing Guide: 1) Jack up/raise the car securely. It should be high enough so you can get under it. 2) Remove the (2) 12mm bolts that hold the slave cylinder to the transmission. 3) Remove the rubber dust boot from the bell housing and remove the slave cylinder. Support the slave cylinder so that it does not hang from the hose. 4) Pull out the shift fork as far as possible. You will not be able to remove it, as the fork end is larger than the hole where the dust boot was. 5) Put very little high temp grease on the fork and on the roller pivot of the fork. I used Valvoline Syntech high temperature grease. I couldn't get my fingers in far enough, so I used a combination of an old knife and a piece of 10ga solid wire to apply/spread the grease. 6) Push the release fork back onto the release bearing. This will "pop" on and stay. 7) Put the slave cylinder back onto the bell housing, making sure the ball of it fits into the recess on the release fork. Replace the (2) 12mm bolts and tighten. 8) Lower the car and you are ready to go! Whatever you do, DO NOT PUSH IN THE CLUTCH PEDAL WHEN THE SLAVE CYLINDER IS REMOVED! Also... Sticky Clutch Down shifted 4 to 2? Mechanical over-rev? Cracked retainers? Very informative post here: DIY Valve retainer replacement with head in place **************************** This post has been edited by Shopman on Sep 24 2009, 11:18 AM -------------------- The facts, and nothing but the facts please... Heated Seats Fitted Roof wear mod Headrest Speakers Intake Guide Mod R/L Traction Control Replacement Roof Elastic Straps Soundproofing Roof Liner Mod Roof Catch repair Adjustable Roof Catches 1999-2009 Ltd Edition Cill Badges ![]()
Irvatron |
Posted: Aug 7 2009, 01:24 PM
Member![]() S2KI User #: 54004 S2KI Age: 3 yrs 319 days PPD Average: 6.9 Owner 2000 Silverstone/Black ![]() |
Can we add about lambda sensors.
Fuelparts one dont work too well with the S, I and 'shepp' have had problems. Shepp has also had a problem with the cheap ebay ones too. -------------------- ![]() Meets attended: Lakes meet II 2009, Lakes meet 2009, JAE 2007, MegaMeet 3 2006 ![]() |
mikey k |
Posted: Aug 8 2009, 02:03 AM
UK Moderator![]() S2KI User #: 30788 S2KI Age: 6 yrs 13 days PPD Average: 9.8 Owner 2005 Moon Rock/Black-Red Cheapest Cheshire ![]() |
Post what you want to add and I'll do it for you.
Added sizes of OEM wheels. -------------------- |
Spykee |
Posted: Aug 19 2009, 12:09 PM
Guest S2KI User #: 82330 S2KI Age: 1 yrs 233 days PPD Average: 0.7 Owner 2004 Moon Rock/Black Northamptonshire ![]() |
Not sure whether there's a Master Tech at Avonvale Northampton anymore if I'm honest with my recent service and the phone number is wrong.
its 01604-413411 -------------------- Alex ![]() Silkolene Pro-S engine oil, Silkolene BOA 90LS diff oil, Berk Technology Decat, JR Induction Kit with Polished Inlet Pipe, Polished Aluminium Spark Plug Cover, Mugen Oil Cap, Mintex 1144/Black Diamond Predator Fast Road Pads, Painted Calipers, Toyo T1-R's, Pioneer DEH-P7000 HU, Infinity Reference Series Components, Headrest Speakers, S2000 Wind Deflector Graphic, GT100 gear knob, number plate mount removed, Roof on the move mod... |
Irvatron |
Posted: Sep 1 2009, 01:16 PM
Can we add this in:
Avoid the use of fuelparts Lambda sensors, the response time is different from the OEM Honda lambda sensor. The problem is when the car has stood for a length of time and is still warm (around an hour or two) the car splutters, jerks and kangaroo's for approx 15 seconds the it adjusts fueling correctly after this time and drives normally, it can be quite dangerous especially pulling out of junctions. Best to use Honda Lambda sensors, Denso, walker etc. |
Irvatron |
Posted: Sep 4 2009, 06:32 AM
I was looking for a part number and came across this site, can we put it in the FAQ as it will be most useful?
It has all the parts number and pictures which you can zoom into the find the required part no. http://www.honda-parts-catalog.com/hpc.php The current one in the FAQ does not seem to work anymore http://www.hondaautomotiveparts.com/ Thanks |
Shopman |
Posted: Sep 24 2009, 11:20 AM
I have added a link to a very useful thread:
to my FAQ post - see above. |
Nezzy |
Posted: Nov 3 2009, 01:01 PM
Member S2KI User #: 103074 S2KI Age: 0 yrs 57 days PPD Average: 0.7 Owner 2000 Berlina Black/Black ![]() |
Can I just add that the rear window cleaner from BMW has now been discontinued. They do however have another Version which is a glass cleaner but also does a great job. The New Part Number is 83 12 0 009 881. Hope this helps.
| Pages: (2) 1 [2] | ![]() ![]() ![]() |
