| Welcome Guest ( Log In | Register ) | Resend Validation Email |
| Pages: (31) 1 [2] 3 4 ... Last » ( Go to first unread post ) |
JN2KS2K |
Posted: Sep 17 2005, 11:52 AM
Guest S2KI User #: 50614 S2KI Age: 4 yrs 357 days PPD Average: 0 Owner 2000 New Formula Red/Black ![]() |
I too have recently had the same indications as everyone else that my tensioner is failing.
Will the tensioner break if I continue to drive around with it like it is? The noise I hear is very annoying!!! I will be taking it to get serviced, but I am concerned that it could break on the way to the shop. |
hotknives |
Posted: Sep 17 2005, 12:17 PM
Guest S2KI User #: 13198 S2KI Age: 8 yrs 20 days PPD Average: 0.1 Owner 2000 Silverstone/Black Toronto ![]() |
I too have this high pitch squealing noise when the engine is in idle even on my 98 toyota sienna ... I've tried to isolate the noise but to no avail, I've tried spraying white lithium grease on the serpentine belt but the noise is still there so it must be the chain tensioner right?
david1 |
Posted: Sep 17 2005, 06:12 PM
Guest S2KI User #: 6530 S2KI Age: 8 yrs 269 days PPD Average: 1.2 Enthusiast Columbus, OH ![]() |
Did the install this afternoon. The job would only have taken me about 15 minutes if I did not document and take pics of the procedure. Make sure you do this on a cool engine.
After running the car for a while with the new tensioner in I noticed the the car is a lot quieter at idle. For the past couple of years I just attributed the noisy valve train of my S to that. I thought I just had a noisy one. It sounded like a diesel at idle sometimes or sounded like the valves were out of adjustment no matter how many times they were checked. Hardtopguy had also done a valve adjustment a couple times and I checked the clearances a month ago and all was good. I still have some valvetrain noise, but all S2000's do. I have not driven the car to get it nice and hot and restart it 10 minutes later to see if the really bad noise is gone (cards in bicycle wheel spokes sound) but since the car is so much quieter, the tensioner was probably weak for the past couple of years and just finally started to really fail as of late. To my knowledge, there is no way to test the tensioner installed in the car. Here is what you will be looking at to replace the TIMING CHAIN AUTO TENSIONER. We will not be compressing the tensioner piston since we are doing a replacement. I will practice with that at a later date. Tools needed: T-50 hex 10 mm socket Ratchet and short extension Long tip/nose pliers The tensioner is located under the vtec solenoid/valve on the front passenger side of the head. A look at the bolts and the maintenance hole. (the larger brass bolt on the bottom left in the photo is not a tensioner bolt) You will see where the tensioner bolts are when you look at the new one. Now remove the two bolts that hold the tensioner and the maintenance bolt. The maintenance bolt is a T-50 hex and the the others are 10mm. They are not tight. Now remove the tensioner. It may take some rotation of the tensioner while pulling it out. Very little oil will come out, but there will be a good amount of leakage from the old tensioner since it works by oil pressure. Also, do not point the old tensioner down or the piston will fall out. The tensioner on top is the old one. As you can see, the piston has a lot of travel. Now insert the new tensioner in the head and bolt it in place. The bolts do not need to be super tight. to helms only calls for 8.7 pound of torque. Make sure the set pin is facing the maintenance hole and the bend on the set pin is facing east so it sort of looks like this l__ If it is facing this way __l it is difficult to remove through the maintenance hole. Grab the set pin and pull it out a little at first then get a better grip on it and pull it all the way out. You will hear a "pop" when the piston extends. Do not drop the set pin within the engine. Who knows what damage that would do. View of tensioner through maintenance hole. Removal of set pin. Looking at the old tensioner I noticed a flaw by one of the o-rings that the new one does not have. This may or may not contribute to a loss of oil pressure within the tensioner but there is no way to check that. If it does let the pressure drop, this could have partially been part of the problem. The tensioner would not have full internal oil pressure letting the chain have some slack making noise against the chain guides, but this is only a theory. The old tensioner is probably just plain old bad. -------------------- I.A.A-Science Officer 2009 335i Coupe-LBM - Black Dakota/Glacier aluminum-6spd|Nav|M-Sport|Premium|Logic7|Heated Seats|CA|BMW Performance Suspension & M3 Control Arms|M3 lip spoiler 2009 X5 3.0-AW-Black Dakota/Bamboo|Premium|Tech|Cold Weather|Ipod Rear Climate| 02 Spa S2000 Sold
MrClean |
Posted: Sep 18 2005, 05:25 PM
Member![]() S2KI User #: 5091 S2KI Age: 8 yrs 347 days PPD Average: 1.2 Owner 2004 Silverstone/Black Powell, OH ![]() |
Nice Job!
Great write-up with photos. -------------------- 06 Porsche Cayman S Wht/Blk PSS9s, 19" RG5s, Tint, Quaife TBD, Clearbra, Grill Mesh Kit & AWE Catback ------ '10 VW GTI/Minivan
HOTRODS2000 |
Posted: Sep 19 2005, 10:15 AM
Guest S2KI User #: 13083 S2KI Age: 8 yrs 22 days PPD Average: 0.2 Owner 2002 Spa/Indy Yellow/Black Wilmington, NC ![]() |
My MY02 has 10,000 miles and at this time I don't have any of the sounds/symptoms of a failing tensioner. Is this something I should do as a preventative maintenance item or will I have time to safely replace it once the symptoms start. Thanks to all who have contributed with helpful info in this thread.
-------------------- Sold the S2000 for the 2007 Cayman S. Sold the Cayman S. Looking for an S2000.
p0pe |
Posted: Sep 19 2005, 10:45 AM
Guest S2KI User #: 15508 S2KI Age: 7 yrs 331 days PPD Average: 1.8 Owner 2001 Silverstone/Black Lafayette, LA ![]() |
Cool, ordering one soon. Thanks for the writeup!
geminis2k |
Posted: Sep 19 2005, 12:09 PM
Guest S2KI User #: 46830 S2KI Age: 5 yrs 109 days PPD Average: 0.1 Owner 2001 Berlina Black/Black ![]() |
how much is the tensioner
SolReborn |
Posted: Sep 22 2005, 11:25 AM
Guest S2KI User #: 33374 S2KI Age: 6 yrs 190 days PPD Average: 0.3 Owner 2000 Berlina Black/Black Germantown, MD ![]() |
Can anyone chime in and give a part number for the tensioner? Billman?
2002S2K |
Posted: Sep 29 2005, 06:07 PM
Guest S2KI User #: 8805 S2KI Age: 8 yrs 160 days PPD Average: 0.4 Owner 2002 Sebring Silver/Black Red Bank ![]() |
I ordered mine yesterday from Jeff @ Hardtopguy.com. It was $103.xx plus shipping. A great price from what I am hearing.
I'll let you guys know how it goes after it is installed. -------------------- 2004 Silverstone S2000 2004 VW Touareg V8 Have any leather questions, feel free to ask...it is what I do for a living! Also see this thread http://www.s2ki.com/forums/index.php?showtopic=188740&hl= for a lot of leather info.
pikkashoe |
Posted: Sep 30 2005, 06:36 AM
Guest S2KI User #: 30423 S2KI Age: 6 yrs 324 days PPD Average: 0.6 Owner 2003 Sebring Silver/Red Miami ![]() |
I wish I would of seen this write up before I took my car in. For $103 it would come out cheaper than my ordeal at the dealer, its costing me $120 to fix the dents that the dealer put on my car when changing the tensioner.
Next time. . . -------------------- 2003 Honda S2000 Fujitsubo w Megan Racing Test Pipe Weapon R intake Pioneer Premier 860 MP, CDT Eurosport ES-620's Alpine MRV-545, SEAS Lotus 10" 18" SSR GT3's, Koni yellows with Ground Control
SolReborn |
Posted: Oct 4 2005, 11:25 AM
FYI: thanks to david1, the part number for the part is:
14510-PCX-005 |
GridGirl |
Posted: Nov 17 2005, 06:34 PM
Guest S2KI User #: 51112 S2KI Age: 4 yrs 340 days PPD Average: 0.1 Owner 2000 Berlina Black/Black ![]() |
Subscribing for my husband.
Hockey |
Posted: Nov 18 2005, 09:38 AM
Guest S2KI User #: 19727 S2KI Age: 7 yrs 222 days PPD Average: 2.6 Owner 2000 Silverstone/Custom Oceanside, CA ![]() |
Calling to order part today. Thanks for the good info.
Question.........by replacing with a new one and pulling the pin after install, I do not have to worry about running into the problem of retracting the piston? I read what happened to the other guy (NOPI show) and just wanted to clarify. I will DIY this soon, and yes I have a Helm's manual so I'll consult that too. Thanks all. -Hockey -------------------- A-Pillar tweeters, Rick's 7/8 aeroscreen, 1-piece floormats, leather console cover, Neuspeed X-Brace, Coastal Metals stainless grill set, MUZ prestige roof well mat, MH windblockers, JDM clear sidemarkers, Mingster's dead pedal, Voodoo shift knob, Kodokan's seat locks, Eibach pro-kit, Euro alignment specs, G2 painted calipers, Centric slotted rotors, PanaVise cellphone mount, Painted rear vallance, HKS Hi-Power dual exhaust, JDM badges, Comptech intake & STB, 3M clear bra, Koni yellows, NRG hood dampers, Weathershield car cover, Cabrioworld canvas top conversion, Hondata IMG, Mugen cooling mods, Krank Vent valves, OEM AP2V1 rims, Modifry glove box organizer and toe-savers, JPM custom Blue/Black interior. Need a "S2000" Caliper Logos? PM me
p0pe |
Posted: Nov 18 2005, 09:46 AM
Has anyone had the problem reoccur after changing the tensioner one or more times?
SC_Highlander |
Posted: Nov 18 2005, 11:19 AM
Community Organizer![]() S2KI User #: 13784 S2KI Age: 8 yrs 6 days PPD Average: 1.5 Owner 2002 Suzuka/Nurburgring Blue/Blue Greer, SC ![]() |
If you are replacing with a new tensioner, there is no reason to compress the old one. Just unscrew the bolts, pull it out, and throw it away. The new one comes already retracted and pinned. --------------------
SC_Highlander |
Posted: Nov 18 2005, 11:20 AM
I did mine last spring at about 45k on the clock. I'm over 63k now without a peep from the new one. |
Billman250 |
Posted: Dec 21 2005, 10:21 PM
Gold Member![]() S2KI User #: 12160 S2KI Age: 8 yrs 42 days PPD Average: 4.2 Owner 2003 Silverstone/Black Long Island, New York ![]() |
My second tensioner is starting to make noise. I'll be on my 3rd soon (original plus 2 new)
I have about 3 other customers who will need a third soon like me. -------------------- Billman250 S2000 Repair DaveOnLI....RIP till we come together again.... Volks 16" CE28N, 04 trans, Gutted HKS Exhaust, Rick's 6plus header, T1R test pipe, Comptech: icebox, flywheel, oldschool silver STB, rear tie bar, ACT PP, Billman's shortshifter, aluminum pulleys, race pedals, 04 console, Cusco C/F rear strut brace, Mugen shift knob, left convex mirror 1996 Accord EX VTEC Wagon : 98 XR400 : 03 Malaguti F18 : 04 TRX450R Khoa...you will always be with us ![]()
Billman250 |
Posted: Dec 21 2005, 10:25 PM
This is a good place for this pic....no need to retract the old tensioner if you're installing a new one, as the new one comes retracted with the disposable holding pin in place.
However, make sure all these pieces come out and are accounted for. By design, it is nearly impossible to loose a piece inside the engine so don't worry Tensioner housing, and 5 addl. pieces that can come out of it: |
pikkashoe |
Posted: Feb 24 2006, 10:36 AM
I had my tensioner replaced in September, and now its starting to go again. Making worse noise than the first time. Im pretty sure with my luck the idiots at my dealer did something wrong. In order to assure its done right, Im going to do it myself this time.
Billman250 |
Posted: Feb 24 2006, 03:07 PM
I'm am currently working on a modified chain tensioner. I should have it ready in about two weeks. This one should last a lifetime, and I'll sell them on a rotation basis. Stay tuned
pikkashoe |
Posted: Feb 24 2006, 04:03 PM
Billman, keep me posted, Im just about ready to replace mine as well. Im very interested in your brand new design, hopefully it will last longer than the 5 months mine has. This will be my third replacement already.
Honda do you hear this, time to redesign your tensioner. |
FormerH22a4 |
Posted: Feb 25 2006, 11:20 AM
Gold Member![]() S2KI User #: 8094 S2KI Age: 8 yrs 191 days PPD Average: 1.3 Owner 2002 Sebring Silver/Black Calgary ![]() |
I recently had a short block replacement by my Honda and now I have this noise.
Should I just let my engine blow and get a real new engine? My engine was fine before getting the short block replacement, it only drank a litre of oil per 1000kms. -------------------- 02'Sebring Silver xviper - you will be missed on here ![]() ![]()
Billman250 |
Posted: Feb 25 2006, 11:27 AM
If it blows, they will blame you no matter what.
Fix it now. |
david1 |
Posted: Feb 25 2006, 11:29 AM
The tesioner is on the head, not the block. |
FormerH22a4 |
Posted: Feb 25 2006, 11:36 AM
They changed a few things in the head as well. Do you think they put the tensioner back on wrong or something with the timing chain? There is a new timing chain in there now. The noise isn't that loud, faint but still noticeable. I'll get them to hear the noise and will see what happens. I think i have a little but of play in my steering wheel now too. so many little things changed after the engine change. doh!! This post has been edited by FormerH22a4 on Feb 25 2006, 03:00 PM |
| Pages: (31) 1 [2] 3 4 ... Last » |
