just got j's 60RS and test pipe
evasive finally had some in i picked up the 60RS with the silver tip. They have 1 more left but supposedly jory is going to pick it up soon
i got the t1R test pipe with it too i hope it doesnt shoot a CEL on me
mike at evasive is going to get a sound clip of mine once i put it on
-Mike Kim
-Mike Kim
if you install the test pipe isn't that your car going to run different ?? isn't that's why people install aftermarket ecu?? what will happy if you run long time with test pipe without aftermarket ecu??
i just got it on last night! the exhaust is kinda loud...2 things bugging me when i go top down it SMELLS!! goddamn test pipe. the other thing is the exhaust rattles like crazy because i noticed during install its rubbing against something. the gains are pretty nice, the butt dyno says it got a lot more power/torque in the midrange
-mike kim
-mike kim
-mike kim
-mike kim
it's should be the 2nd hanger away from the tip. just wrap that around with some silcone tubing and zip tie it so it stays on. this should be the problem if your rattle sounds like metal on metal sound... like a nonstop tick tick tick sounds...
Great choice, I also have the J's with testpipe. The sound is pure heaven
I also had the rattle (metal on metal). It was the hanger hitting a metal part on the car at the very back by the tailpipe. This CAN be fixed. I got mine fixed in about 5 minutes. I'm not sure what they did, but no problems since.
