help adjusting HIDs
Old 01-15-2006, 06:11 AM
ApexMotorPro's Avatar
Default help adjusting HIDs
change hid bulbs to 6600k and it seems like it points down more and i cant find a place to adjust them at. i know in my integra i can use a screw driver but i dont see anywhere to adjust it with. anyone with pics? thanks in advance
jay
Old 01-15-2006, 06:23 AM
Slows2k's Avatar
Changing the bulbs doesn't effect the lights adjustment.
Old 01-15-2006, 06:38 AM
i took the headlights out to change the bulbs and for some reason it looks like it points lower than stock. maybe its the bulbs. but is their anywhere i can adjust the lights at?
Old 01-15-2006, 06:44 AM
Slows2k's Avatar
There are 2 adjusters on the back of each headlight. I highly reccomend you follow the adjustment procedure in the Helm service manual. Misadjusted HID's will blind oncoming traffic.
The correct light pattern will have the driver's side light lower than the right.
You didn't need to remove the entire light to replace the bulbs. removing thefront fender liner clips on each side gives you enough room to replace the bulbs.
Old 01-15-2006, 06:49 AM
thanks slows2k
Old 01-15-2006, 03:17 PM
mikegarrison's Avatar
It helps to have a long (at least 8 inches) #1 phillips screwdriver. (#2 is the most common phillips size, #1 is smaller)
Old 01-15-2006, 03:47 PM
Billman250's Avatar
Received 1,253 Likes on 763 Posts
Seems there's a big misconception about the s2k HID's. One headlight is not lower on the drivers side, they are both the same. Each headlight has a built-in low-left/high-right diffuser. Take a look at my quickie pic. The red line is light cast from the left light, and the blue line is from the right.
I have misadjusted the headlights on the wall so you can see how it works.
To make the head lights perfect, you must raise one or lower the other, so the patterns are right on top of each other. Note the pic marked "correct". That's how you get that nice white defined line as you pass buildings and stuff.
Once you pull up to a nice wall, walk in front of each headlight and block them one at a time. You will be able to distinguish each pattern from each light, and decide which one to raise, or which one to lower.
NOW....once they are level, them you can bring both down or up equally to adjust for oncomming traffic.
Maybe archive this one
Old 01-15-2006, 03:54 PM
freq's Avatar
Nice crayon work there billman.
Old 01-15-2006, 03:57 PM
Billman250's Avatar
Hey it looks like your lights all red and blue!
Old 01-16-2006, 05:23 AM
vtec9's Avatar
who placed that wall in the middle of the road?
Quick Reply: help adjusting HIDs
