I think it is time to change your PCV Valve.
Old 03-07-2006, 07:07 AM
iNetForce's Avatar
Default I think it is time to change your PCV Valve.
"The PCV Valve, or Positive Crankcase Ventilation valve is an emission control device that routes unburned crankcase blowby gases back into the intake manifold where they can be reburned. The PCV system is one of the oldest emission control devices, and also one of the most beneficial. Besides totally eliminating crankcase emissions as a source of air pollution, the constant recirculation of air through the crankcase helps remove moisture which otherwise would cause sludge to form. Thus the PCV valve extends the life of the oil and engine. The PCV valve requires little maintenance. The valve should be replaced somewhere around 20,000 miles(see the vehicle owners manual for service intervals)".
Here is another excellent link:
Explation with visuals about PCV Valves
There is no need to get a new one; most of the times you can clean yours. Sink the PCV valve in carb cleaner or something similiar, let it sit for while there and then clean it with a dry cloth or whatever you think is better for you. All you can find inside the PCV valve is oil build-up, thats why it is so simple to clean it up.
Old 03-07-2006, 08:11 AM
darkfx's Avatar
they are only 3 bux.. i just replace mine..
Old 03-07-2006, 08:45 AM
Banned
Quivers's Avatar
Im gonna go buy one today, thanks for the explanation.
Old 03-07-2006, 09:06 AM
TR-S2K's Avatar
Any picture of AP2 PCV Valve and where it is ?
Old 03-07-2006, 09:13 AM
darkfx's Avatar
its right on the valve cover.. it looks like a 90 degree plastic thing
Old 03-07-2006, 10:09 AM
iNetForce's Avatar
I will write a how to for the PCV valve, Ill include pics and stuff, it is very simple to change.
Old 03-07-2006, 10:11 AM
iNetForce's Avatar
SAme as the AP1, I will show you later..
Old 03-07-2006, 10:51 AM
WalkingDrunken's Avatar
Where'd you find it for 3? I found it for 13.
Old 03-07-2006, 11:00 AM
Race Miata's Avatar
[QUOTE=s2krev,Mar 7 2006, 11:51 AM] Where'd you find it for 3?
Old 03-07-2006, 12:17 PM
news2kroller's Avatar
is there a writeup on this somewhere? i have 25k on my car and id like to take care of this. thanks.
Quick Reply: I think it is time to change your PCV Valve.
