| Welcome Guest ( Log In | Register ) | Resend Validation Email |
| Pages: (4) [1] 2 3 ... Last » ( Go to first unread post ) | ![]() ![]() ![]() |
dbzerk |
Posted: Mar 19 2006, 02:59 PM
Guest S2KI User #: 44051 S2KI Age: 4 yrs 260 days PPD Average: 2 Owner 2000 Silverstone/Red Melbourne, Vic, Australia ![]() |
Hey all,
My clutch pedal has been feeling very rough. You would depress the pedal all the way then bring it up slowly and it would stick and feel very rough down the bottom. After not driving it for over a week it started to squeak everytime i pressed the clutch pedal down aswell!! Heres the fix... First remove the Clutch slave cylinder from the side of the transmission housing. There is only two bolts holding this in.. Here is the slave cylinder with the boot and rod removed. There is not need to remove the banjo bolt. Pic of the rubber boot and the cylinder rod removed. This should come apart from the slave cylinder with next to no force. When removed you can see that it is slightly damaged and rough. There is a nipple at the top which needs to be grinded down flat. When i removed the rod there was no grease on it. Grind the nipple down carefully and polish up to a high finish. Should look something like this Inside the clutch, you can see the release fork and the cup for the slave rod. Clean this out and reapply high temp grease. If you have a dremel with a polishing bit it would make the job alot easier. The actual boot over the fork can come out with a tug. Assemble the Slave cylinder with the boot and rod. Make sure there is high temp grease inside the boot and on the ball end of the rod. Slide the slave cylinder back into the transmission housing making sure that the rod arm ball sits in the cup of the release fork. Bolt up and you're done! Step on the clutch pedal a few times to work the grease between the joints.. -------------------- -[OWND]- **Quote & Fact of the day** MODS:Stereo Install- Cusco/Spoon Bracing- D2 Coilovers- FIXES:Squeaky/Sticky Clutch Pedal- Noisy transmission- Leaking Boot/Trunk
dbzerk |
Posted: Mar 19 2006, 03:01 PM
I should also add that you might want to lubricate the rod and pin on the clutch pedal side inside the car. This should be done frist as your problem may only be that..
AusS2000 |
Posted: Mar 19 2006, 03:56 PM
Moderator![]() S2KI User #: 5 S2KI Age: 9 yrs 43 days PPD Average: 8.4 Owner 2000 Silverstone/Red Sydney ![]() |
Nice! You should post this in Under the Hood.
Alister |
Posted: Mar 19 2006, 04:11 PM
Guest S2KI User #: 2851 S2KI Age: 8 yrs 162 days PPD Average: 0.4 Owner 2001 Silverstone/Red Melbourne ![]() |
Do you use stands when you are under there dbzerk?
AusS2000 |
Posted: Mar 19 2006, 04:14 PM
Mad if you don't.
dbzerk |
Posted: Mar 19 2006, 04:23 PM
LOL... i used buckets under the wheels..
Of course!!! Its a habbit of mine to use the stands on either side and also leave the jack up but not full pressure... |
dbzerk |
Posted: Mar 21 2006, 01:01 PM
AUS: Want to move this to UTH for me??
dbzerk |
Posted: Mar 24 2006, 01:19 PM
Thanks
Gink5 |
Posted: Mar 24 2006, 02:04 PM
Guest S2KI User #: 38302 S2KI Age: 5 yrs 100 days PPD Average: 0.9 Owner 2001 Spa/Indy Yellow/Black Newtown,PA ![]() |
You the man. This just happened to me in the past week. How long did it take?
This should def be put in the faq and DIY thread. --------------------
kent-k |
Posted: Mar 24 2006, 02:41 PM
Guest S2KI User #: 43216 S2KI Age: 4 yrs 286 days PPD Average: 2.3 Owner 2005 GrandPrix White/Tan Honolulu ![]() |
my 2002 had the same problem for a while. i finally kicked the laziness and did the same repair. i just used the dremel on the nipple, no fine polishing and it is super smooth.
and it look all of 15 minutes. it was more of a pain to jack the car up!LOL -------------------- ̿̿ ̿ ̿̿'̿'\̵͇̿̿\=(•̪●)=/̵͇̿̿/'̿'̿ ̿̿ ̿
Incubus |
Posted: Mar 24 2006, 03:02 PM
Guest S2KI User #: 5728 S2KI Age: 8 yrs 22 days PPD Average: 1.8 Enthusiast ![]() |
So there's no draining or bleeding necessary?
kent-k |
Posted: Mar 24 2006, 03:15 PM
^nope,don't take off the hose, just the two bolts that hold on the slave.
dbzerk |
Posted: Mar 24 2006, 10:36 PM
No more than half hour.. and the results speak for itself!
Dont need to touch the hoses at all |
iam7head |
Posted: May 23 2006, 01:17 AM
Guest S2KI User #: 55920 S2KI Age: 3 yrs 260 days PPD Average: 3.9 Owner 2000 Silverstone/Black Pasadena, SOCAL ![]() |
Just don't get so happy and step on the clutch before everything is back in and tighten Mine is doing the samething, thanks! Sometime i wonders how you guy found DIY like this. GREAT HELP I used dremel here also This post has been edited by iam7head on May 23 2006, 01:18 AM --------------------
SenderGreen |
Posted: May 23 2006, 03:19 AM
Guest S2KI User #: 32731 S2KI Age: 5 yrs 287 days PPD Average: 0.4 Owner 2003 Silverstone/Black Monrovia ![]() |
Excellent thread, I need to do this. I already got some Honda high temp urea grease (I think that's the right type). I wasn't even aware that the "nipple" needed to be ground down. Do you also need to do the shift fork with urea grease, or is this enough to elimate that notchy feeling?
EDIT: Honda recommends "Super Hi Temp Urea Grease" Honda part# 08798-9002 This post has been edited by SenderGreen on Jul 29 2006, 07:58 PM -------------------- "The 9000 series is the most reliable computer ever made. No 9000 computer has ever made a mistake or distorted information. We are all by any practical definition of the words, foolproof and incapable of error." |
replicah |
Posted: Jul 27 2006, 12:59 AM
Guest S2KI User #: 55666 S2KI Age: 3 yrs 266 days PPD Average: 0.7 Owner 2000 Berlina Black/Black yes ![]() |
four questions:
is there any real reason for that 'nipple' to be there? could there be any side effects for grinding it down? how did it get there? where do i get the grease from and does anyone know a product no.? Thanks! -------------------- ![]() |
SpitfireS |
Posted: Jul 27 2006, 02:57 AM
Guest S2KI User #: 54485 S2KI Age: 3 yrs 303 days PPD Average: 2.2 Owner 2000 Berlina Black/Black 17 ft below sea level. ![]() |
Answers are IMO
#1 - The reason the "nipple" is there is because the cup has a dimple in the centre (visible in the picture), so it doesnt wear there and forms the nipple on the rod. Nipple & dimple are eachothers "opposite", right? #2 - No side effects I can think of, smooth = better Don't grind it down millimeters, just the surface to polish. Start with 800 grid sandpaper or so and get a can of elbow grease #3 - It got there because of wear (and lack of grease) #4 - Any automotive store should have some high temp / EP grease. Molycote is a brand that comes to my mind. You're welcome -------------------- |
replicah |
Posted: Jul 27 2006, 04:37 AM
great answers
thanks again! |
aero3685 |
Posted: Aug 15 2006, 04:47 PM
Guest S2KI User #: 60950 S2KI Age: 3 yrs 116 days PPD Average: 0.5 Enthusiast Florida ![]() |
yeah, for stuff like this, oil pump gears... and stuff that will be needing high heat, you want to find a grease that has molybdenum in it. It is usually abbreviated as moly, and also usually listed on the front (no need to look through all the ingredients). -------------------- |
S2FiONE |
Posted: Aug 15 2006, 09:22 PM
Guest S2KI User #: 40690 S2KI Age: 5 yrs 14 days PPD Average: 0.5 Owner 2006 Custom Color/Blue Oklahoma City, Nevada ![]() |
My car have had this issue since the day I bought it. Dealer couldn't find out whats wrong. All they did is re-adjust the pedal height, which seem to works for a few days, then it came again. Thanks God I Found This Thread!!!! -------------------- ![]() Past: 01 BB S2000 Current: 06 SGM STi - APS SR56 & more... 99 Prelude SH -project. 07 YZF-R6 - Summer fun!
dbzerk |
Posted: Aug 16 2006, 01:01 AM
Cool!
hope i works for you! |
SpitfireS |
Posted: Sep 25 2006, 06:17 AM
Today was the day I actually performed this easy but rewarding maintenance.
Almost no grease found on the clutch fork & rod. The rod was a little damaged, less then the one in the picture. May I add that I also polished the other end of the rod. That's the end that "pivots" in the slave cylinder piston. For grease on the rod & fork I used a home cooked mixture of a never seeze compound & Molycote. Needless to say the clutch is working very VERY smoothy now. IMHO everyone should do this, I'm not sure how much grease Honda puts on during assembly. And / or how long it lasts. |
Jasonoff |
Posted: Sep 25 2006, 07:37 AM
Banned S2KI User #: 11163 S2KI Age: 7 yrs 138 days PPD Average: 5.9 Owner 2000 Silverstone/Black Waterloo ![]() |
Make sure you replace your clutch fluid at a regular interval as well. I'm suffering from that now after the new clutch.
Had to replace the master and slave due to what i fugure was rust/contamination since the flud was in long enough to asorb too much water. -------------------- ![]() Street Mode Track Mode --»![]() ____________________________ I hate you all. Especially Cory.
AssassinJN |
Posted: Sep 25 2006, 08:36 AM
Member![]() S2KI User #: 61984 S2KI Age: 3 yrs 88 days PPD Average: 3.7 Owner 2001 Silverstone/Black ![]() |
Is this in the FAQ post yet? If not can a mod please add it as I want to be able to find it later this month when I start going through all the fluid replacements etc... Thanks.
melonheadr6 |
Posted: Nov 13 2006, 01:25 PM
Guest S2KI User #: 59153 S2KI Age: 3 yrs 168 days PPD Average: 0.3 Owner 2003 Silverstone/Black ![]() |
Thank goodness for this post! Mine started doing this yesterday. I will get on this right away. SAAAWEET!
| Pages: (4) [1] 2 3 ... Last » | ![]() ![]() ![]() |
