| Welcome Guest ( Log In | Register ) | Resend Validation Email |
Spec_Ops2087 |
Posted: Jun 14 2006, 08:15 PM
Member S2KI User #: 29495 S2KI Age: 6 yrs 150 days PPD Average: 3.9 Owner 2002 Sebring Silver/Black New Jersey ![]() |
Just a little video I found on streetfire on how the system actually works.
http://videos.streetfire.net/video/DDD9096...752F982ED3A.htm Might be easier to grasp when it is shown in a movie --------------------
WalkingDrunken |
Posted: Jun 14 2006, 08:23 PM
Guest S2KI User #: 30671 S2KI Age: 6 yrs 100 days PPD Average: 0.3 Owner 2001 Spa/Indy Yellow/Black Gainesville, Fl. ![]() |
That's a great lil video. I've seen a lot of them for almost every internal engine thingy but this is the first I've seen for vtec. Always fun to watch.
BulldogS2 |
Posted: Jun 14 2006, 08:38 PM
Guest S2KI User #: 57934 S2KI Age: 3 yrs 286 days PPD Average: 0.8 Owner 2006 Berlina Black/Black ![]() |
anybody else still confused? haha
-------------------- 06 Berlina aka best color l Ground Control sleeved springs l SSR SP1 aka Pimp wheels haha 18x8 fronts 18x9.5 rears l Greddy Ti-C
Red_Devil |
Posted: Jun 14 2006, 08:51 PM
Member![]() S2KI User #: 55591 S2KI Age: 3 yrs 351 days PPD Average: 1 Owner 2006 GrandPrix White/Black TopDown, California ![]() |
Just wondering how come VTEC must activate the last 2K rpm before red. What happen if VTEC start kick in from 2.5~3K rpm like turbo do?
btw, thanks for the video --------------------
gomarlins3 |
Posted: Jun 14 2006, 09:19 PM
Gold Member![]() S2KI User #: 6446 S2KI Age: 8 yrs 61 days PPD Average: 7.3 Owner 2002 Berlina Black/Black Kuna Idaho ![]() |
Nice. I am saving that link.
-------------------- Dark Stiletto ![]() Yablownowitz racing brought to you by Anytime Fitness. Happiness is a nice road, great weather, and driving the S with Sue in the seat next to me. "Whatever you do, where ever you go, enjoy the drive." I know for a FACT that the last year of production of the S2000 is 2003!!!!! After that, it will be the S2200 under an assumed name.
RWD_RCKT |
Posted: Jun 14 2006, 10:34 PM
Gold Member![]() S2KI User #: 5169 S2KI Age: 8 yrs 131 days PPD Average: 1.2 Owner 2004 Rio/Indy Yellow/Black Where people chew on hay ![]() |
That is a fascinating video... but now I am confused! I thought the two small lobes were used for "normal" and the large middle lobe was used for VTEC?
That video shows all lobes working before VTEC, just the sequence is gradual. The VTEC then just has all valves opening at the same time. If the video is true then VTEC and non VTEC would have the same lift, which is not true??? --------------------
RED MX5 |
Posted: Jun 14 2006, 10:58 PM
Life Member RIP![]() S2KI User #: 32853 S2KI Age: 5 yrs 364 days PPD Average: 3.3 Owner 2000 Silverstone/Black-Red Dry Branch ![]() |
Valve timing that is optomized for high RPM operation doesn't work well at lower revs. You could modify the motor to run on the high RPM cam profile ("VTEC") all the time if you wanted to (though for it to work at all you'd need a stand alone ECU), but all you'd get is a lumpy idle, very little torque at lower revs, and poor gas mileage. You'd still have the same power above 6k, but you'd pay for it big time at lower revs and at idle. VTEC allows a mild profle and staggered valve timing for excellent performance at lower revs and a change to a higher lift longer duration timing without the stagger for greater peak power at higher revs. It actually makes more sense to look at VTEC as a way of giving a high strung engine a decent idle and low end torque, because it actually does nothing to increase performance. The high lift cam profiles will deliver exactly the same power with or without VTEC. -------------------- First place - Hottest Honda Other - HIN Atlanta 2005 First place - S2000 Street - NOPI Nationals Supershow Atlanta 2006 ![]()
RED MX5 |
Posted: Jun 14 2006, 11:05 PM
The center rocker arm always rides on the center cam lobe, so it always goes up and down, but it isn't connected to the rockers that open and close the valves until the VTEC pins slide into place and lock all three rockers together. If that's not clear, read on and I'll try to explain it a little more fully. Below VTEC each valve is controlled by a single rocker arm. Note that in the video you can see how the two valves open and close at slightly different times. The center rocker also rides up and down on its cam lobe, but it is not connected to the two rockers that open and close the valves. It just moves up and down without doing any real work. Then, when the VTEC pins are pushed through the rockers (by oil pressure) all three of the rocker arms are locked together. Now the two arms that open the valves have to follow the center rocker arm, which is following the hotter cam profile. I hope that helps, but if it's not clear please feel free to ask more questions. |
Ks320 |
Posted: Jun 15 2006, 04:16 AM
Platinum Member![]() S2KI User #: 46520 S2KI Age: 4 yrs 271 days PPD Average: 3.1 Owner 2004 GrandPrix White/Black Hong Kong ![]() |
-------------------- "The end of a legend is the dawn of a new era." 1998 USDM BB6 TypeSH Nordic Mist (sold ...) 2005 USDM AP2 Sebring (sold to tan0116) 2004 JDM AP1 Grand Prix White Thank you Uehara-san ...
vindaloo |
Posted: Jun 15 2006, 05:07 AM
Guest S2KI User #: 58104 S2KI Age: 3 yrs 282 days PPD Average: 0 Owner 2003 Silverstone/Black Gurnee, IL ![]() |
figures...i go to click on the click and get 'page can not found'. looks like they're in the process of overhauling streetfire.net, so who knows when the video will be back up.
This post has been edited by vindaloo on Jun 15 2006, 05:08 AM |
Jsmply |
Posted: Jun 15 2006, 06:58 AM
Member![]() S2KI User #: 35918 S2KI Age: 5 yrs 245 days PPD Average: 1.1 Owner 2004 Custom Color/Black Miami, FL ![]() |
Seems to be working now vindaloo.
-------------------- R.I.P. RED MX5 MY04: Custom Carbon Black Paint Job, 4.77 Final Drive Gear in HTG AP2 Diff, Toda Flywheel, ACT Pressure Plate, CDV Removed, K&N FIPK Intake, AUT Cooling Plate, Fujisubo Exhaust, t1r testpipe for dyno, 06 Seats, Security: Clifford Matrix 10.5 Alarm w/ Proximity Sensor on Convertible Top with Power Backup, Electrified Seat-Bolts, Lo-Jack, and a camera. Move on to another car (preferably a Civic). . . mine isn't worth it! =P Meticulous OCD Maintenance & Logs = 218.7 WHP dynojet STD
vindaloo |
Posted: Jun 15 2006, 07:30 AM
Thanks! I had to watch that at least 3 times just to understand what's going on. Those Honda engineers are pretty damn clever. |
RWD_RCKT |
Posted: Jun 15 2006, 07:43 AM
That was a great explanation. Thanks! |
spectacle |
Posted: Jun 15 2006, 10:34 AM
Guest S2KI User #: 39680 S2KI Age: 5 yrs 133 days PPD Average: 1 Owner 2001 New Formula Red/Black Tampa, FL ![]() |
there's a better one floating around with commentary...when I get home if i remember I'll post it.
