Go Tuning Unlimited Car No.1 - ASM USA Demo Car
Old Aug 14, 2006 | 12:05 PM
RevJunky's Avatar
Default Go Tuning Unlimited Car No.1 - ASM USA Demo Car
I purchased the car in December 1999 and have been on S2Ki since the beginning. It's about time I share some pics after 7+ years of ownership!
It's been 8 years and I decided to change things up a bit, new build starting page 5!
Pre-2007 pics on page 1, Post-2008 pics starting page 5 and on.
Post-2008 Build Preview:
Parts already collect for the new build:
More to come later...
Engine
ASM 70mm Titanium Single Exhaust
ASM Exhaust Manifod -07
ASM Radiator Overflow Tank
ASM Oil Catch Tank
ASM Oil Filter Bracket
ASM Ram Air Cleaner Box
ASM Radiator Plate
Mugen Aluminum Radiator
Mugen Radiator Cap
Mugen Thermostat
Mugen Fan Switch
Mugen Reservoir Caps
Mugen Engine Mounts
Mugen Dry Carbon Ignition Coil Cover
Mugen Oil Filler Cap
Toda Ultra Lightweight Pulley Kit
J's Racing Magnetic Engine Drain Bolt
J's Racing Magnetic Transmission Drain Bolt
J's Racing Differential Drain Bolt
Spoon Baffled Oil Pan
Spoon Radiator Stays
Sun Auto Grounding Kit
Sun Auto Hyper Voltage System GT
APEXi VAFC II w/ Frog Harness
Denso IK24 Iridium Spark Plugs
Custom Carbon Fiber Intake Heat Shield
Hondata Intake Manifold Gasket
Samco Radiator Hoses
Motec M400 Engine Management System
Test spares:
Mugen Version 1 Air Intake System
GOTO Garage Titanium Radiator Plate
GT Design Titanium Intake Arm
Toda ITB's
Drivetrain
ASM SRE Clutch Disc
ASM Stainless Mesh Clutch Line
ASM Half Shaft Spacers
Toda Chromoly Flywheel
Mugen Pressure Plate
Mugen Transmission Mounts
Mugen Differential Mounts
J's Racing 4.44 Final Drive Gears
J's Racing Diff Distance Collar
O.S. Giken 2-Way LSD
Spoon Capacity-Up Differential Case
Spoon Direct Shift Lever Assembly
Honda OEM AP2 Transmission
Honda OEM AP2 Driveshaft
Honda OEM AP2 Differential
Suspension / Chassis
ASM GT Front Tower Bar
ASM GT Front Lower Arm Bar
ASM GT Rear Tower Bar
ASM GT-S Rear Lower Arm Bar
ASM Floor Ladder Bar
ASM Inner Fender Brace
ASM Front Lower Arm Bar
ASM Front Bumper Steer Bracket
Moton 2-Way Dampers
Hyperco Sraight Spings + Helper Springs
Custom Aluminum Monoball Top Hats
Mugen 31.8mm Front Sway Bar
Mugen 30mm Rear Sway Bar
Mugen Front Compliance Bushings
Mugen Front Lower Arm Bushings
Mugen Front Lower Damper Bushings
Mugen Front Upper Arm Bushings
Mugen Rear Lower Arm Bushings
Custom Monoball Adjustable Swaybar Endlinks
J’s Racing Front Roll Center Adjuster / Camber Joint
J’s Racing Rear Roll Center Adjusters / Camber Joint
J’s Racing Front Gusset Plate
J's Racing Front Tie Rod Ends
J's Racing Rear Tie Rod
J's Racing Steering Rigid Sleeve
Spoon Center Brace Bar
Spoon Subframe Rigid Kit
ARP Custom Length Chromoly Wheel Studs
Honda OEM AP2 Front Subframe & Arms
Brakes
J's Racing / Endless 6-pot Front Brake Kit
Custom Slotted Rear Rotor
Endless Brake Pads
ASM Stainless Mesh Brake Lines
Wheels / Tires
Prodrive GC-07C 17x8.5+54 British Black
Prodrive GC-07J 17x8.5+55 British White ASM Edition
Prodrive GC-07C 17x9+45 ASM Edition
Nitto NT01 Tires 255/40-17 Non-staggered
Nitto NT05 Tires 255/40-17 Non-staggered
SSR Decolte Evolution F:18x7.5+55 R:18x8.5+55
Bridgestone S-03 Tires F:225/40-18 R:255/40-18
Exterior
ASM Dry Carbon Front Aero Bumper GT-10
ASM Dry Carbon Front Aero Fenders -04
ASM Dry Carbon Aero Bonnet
ASM Dry Carbon Trunk (temporary)
ASM Dry Carbon GT Rear Wing (temporary)
ASM Dry Carbon Ducktail Spoiler
ASM Dry Carbon Side Aero Spoilers
ASM Dry Carbon Front Canards GT-12
ASM Carbon Fiber Brake Ducts
ASM Carbon Fiber Front Lip Spoiler -07
ASM Rear Aero Bumper -07
ASM Front Tow Hook
ASM Rear Tow Hook
ASM Titanium License Plate Bolts
ASM Stainless Steel Radiator Plate Bolts
ASM Bonnet Dampers
ASM Short Antenna
Mugen Dry Carbon Hardtop
Axle Corp Front Diffuser
Axle Corp Rear Diffuser
MRacing Carbon Side View Mirrors
Honda OEM AP2 Headlights
Honda OEM AP2 Tailights
Honda OEM JDM Emblems
Interior
ASM Handbrake
ASM Shift Boot
ASM Exgel Seatbelt Pads
ASM Racing Steering Boss
ASM Karo Floor Mats
Mugen S1 Bucket Seats
Mugen Seat Rails
Mugen 6-point Roll Cage
Mugen Roll Cage Cover
Takata 6-Point Safety Harness
Worksbell Rapfix II Quick Release
Personal 330mm Neo Grinta Steering Wheel
Honda OEM NSX-R Horn Button
Honda OEM NSX-R Horn Button Ring
Honda OEM Titanium Shift Knob
Honda OEM AP2 Center Console Cover
Race Technology DL1 Data Logger
Race Technology Dash2 Display Cluster
This is about how the car looked for the first 7 years of it's life.
Pre-2007 pics; I kidnapped HunterEz for 3 days to take these!
Pre-2007 Parts List
Engine
Mugen Cold Air Intake V.1
Mugen Exhaust Manifold
Mugen Sports Exhaust System
Mugen Radiator Cap
Mugen Thermostat
Mugen Fan Switch
Mugen Reservoir Covers
GOTO Garage Titanium Radiator Plate for Mugen V.1 Intake
Pappy�s Intake Heat Shield
Carbing Oil Catch Tank
Spoon Magnetic Drain Plugs
J's 4.44 Final Drive Gears
J's SPL Half Shaft Spacers
Interior
Mugen S1 Bucket Seat and Rails
All Red Interior Conversion
AP2 Center Console
JPM Shift Boot and Console Pad Skin
Rick�s Windsreen
Coastal Metals Dead Pedal
Honda Titanium Shift Knob
Exterior
Gears Front Spoiler + Clear Bra
Axle CF Rear Diffuser
Honda Side Strake
Honda Rear Spoiler
Honda Black Chrome S2000 Emblems
Honda JDM Silverstone H Badges
AP2 Headlights
AP2 Tail Lights
Glass Window Soft Top & Frame Conversion
Custom Front Fenders
JDM Clear Side Markers
Suspension
Mugen NZ Damper Kit
SSR GP-0 Decolte Evolution Wheels with S03 Tires (Street)
Prodrive GC-07C with RA1 Tires (Track)
Comptech Adjustable Co-Axial Front Sway Bar
Comptech Lower X-Brace
Custom Adjustable Swaybar Endlinks
J's SPL Rear Anti-Bumpsteer Kit
J's Engine Torque Damper, Strut Bar, Heatshield Combo
J's Rear Roll Center Adjuster
J's Front Camber Joint / Roll Center Adjuster
Spoon Front Zero Bumpsteer Bracket
Mugen Hard Bushing Set
Stoptech Big Brake Kit
Axxis Deluxe Plus Pads
Rear slotted Rotors
Carbotech XP Race Pads
Custom 10mm T-6061 Aluminum Hub/Wheel-Centric Wheel Spacer
ARP Chromoly Extended Wheel Studs, Custom Length
Stereo
Alpine CDA-9835 Head Unit
Alpine MRV-F407 V12 Amp
Alpine MRV-T757 V12 Amp
Alpine 6-Disc Ai-Net CD Changer
Boston Acoustics 6.5 Pro Front Speakers
Boston Acoustics 4.5 Pro Rear Speakers
Boston Acoustics 10.5LF Pro Subwoofer
Modified JL StealthBox
Custom Sub Cover
Optima Yellow Top Battery
Accessories
Honda Security System
Muz Roof Well Mat
Muz Trunk-Lid Saddlebag
Muz Trunk Liner
Gorilla Spline Lugs
Valentine 1 w/ remote Display and Controls
Old Aug 14, 2006 | 12:16 PM
KickAzzS2k's Avatar
Thats hell of a mod list man. Very nice car, and very nice wallet!!
Old Aug 14, 2006 | 12:26 PM
4doorj's Avatar
sweet pictures!!!!
just curios... do u still love the s as when u first purchased it?
Old Aug 14, 2006 | 12:30 PM
RevJunky's Avatar
Originally Posted by 4doorj,Aug 14 2006, 12:26 PM
sweet pictures!!!!
It's strictly a weekend/track car so I don't drive it enough to get tired of it.
Here are some more pics!
LoudMusic's Avatar
Wow, really nice angles on some of those pictures. Cool perspective shots.
Old Aug 14, 2006 | 12:43 PM
Aze85's Avatar
nice car
Old Aug 14, 2006 | 12:55 PM
GoTuningTommy's Avatar
nice aaron!!
Old Aug 14, 2006 | 12:59 PM
XclusiveAutosports's Avatar
VERY nice car! You need to whore it more often. BTW, I want your brakes so badly...
Old Aug 14, 2006 | 01:10 PM
Columbo's Avatar
wow... really sexy car. Its so clean... i love it!!! thumbup:
Old Aug 14, 2006 | 01:19 PM
duff0000's Avatar
more of the axle diffuser!!!!!!!!!!!!!!!!
Clean!!!!!!
