06 -07 Service Bulletin
Old 04-13-2007, 03:02 PM
acurandy@aol.com's Avatar
Default 06 -07 Service Bulletin
Not sure if anyone knows if this yep, but here it is. I work for Honda and just got word of it.
SYMPTOM
The MIL is on withPGM-FI DTC P1172( air fuel sensor1) circut out of range, high) and /or P2A00(air fuel sensor[sensor 1] circut range/performance problem)
PROBABLE CAUSE
The air/fuel sensor is damaged by moisture in the exhaust system during engine warm up
Corrective action
Use the HDS to update the ECM/PMC PGM-FI software. Replace the air/fuel sensor
NOTE: The PMG-FI software has been changed to delay A/F sensor heater operation when there is a high probability of moisture on the A/F sensor.
Old 04-13-2007, 05:34 PM
FISH22's Avatar
hmmm, is this really a recall, or a tsb? would this throw a CEL? not sure what this means, and how the car would act with this condition....
Old 04-13-2007, 05:37 PM
R3DS2K's Avatar
i posted about my cel coming on with only 3000 miles on my s2k when i first got it.. it was for a bad air/fuel sensor.. so i guess its real but only sounds like a tsb so if u dont have cel u dont get new parts
also since mine was replaced late last year.. i dont think they reprogram the ecu
Old 04-13-2007, 05:38 PM
FISH22's Avatar
checked my owner link, and it says there are no recalls right now. is this just VIN specific?
Old 04-13-2007, 05:39 PM
FISH22's Avatar
interesting, was the car acting wierd?
Old 04-13-2007, 05:41 PM
R3DS2K's Avatar
drove fine and even able to redline. with no problems but i did clear the code a few times but came back right away..
heres the link to when i had the cel.. but didnt have tsb out yet i dont think
https://www.s2ki.com/forums/index.ph...pic=451071&hl=
Old 04-13-2007, 06:01 PM
SenderGreen's Avatar
From the original posters info, it looks like you would have a CEL. MIL and CEL are synonymous. CEL=Check engine light, MIL =Malfunction Indicator Lamp, same thing.
Old 04-13-2007, 06:29 PM
FISH22's Avatar
okay, never heard of 'MIL' before.
Old 04-13-2007, 07:49 PM
atlxkevinx's Avatar
hmmm. is this foreal? I am confused, can someone explain in simpler terms? Is there a problem with the 06-07 and should I take my car to the dealer?
Old 04-13-2007, 08:18 PM
s2steve's Avatar
Ok, the air/fuel sensor is similar to an oxygen sensor, except that it tells the computer the exact air/fuel ratio of the exhaust, as opposed to the O2 sensor, which has a much limited range, and doesn't actually tell the computer what the A/F ratio is. What is happening is when the engine warms up, the moisture that has collected in the intake/motor/exhuast can contaminate the A/F sensor and cause it to burn out/malfunction. If your car doesn't have any problems, don't worry about taking it to the dealer. Most likely the problems are related to certain environmental conditions that are not experienced everywhere.
Quick Reply: 06 -07 Service Bulletin
