HID Replacement
Old 07-08-2007, 06:34 PM
SLstone s2k kid's Avatar
Default HID Replacement
I know alot of people here think its a bad idea to replace HID bubls, but i wanna give it a shot. Does anyone here have step by step instructions on how to replace the bulbs?
Old 07-08-2007, 09:16 PM
s2kshift9k's Avatar
pull the bumper and pull out the head light
your going to need a special tool or small plyers to turn the hid bulb cover to get to the HID
not too hard at all i think there is a DIY on here some where
Old 07-08-2007, 09:17 PM
ChinoMan's Avatar
Just Be Careful....i have my Brother-in-law do it. (he owns a performance shop.)
Old 07-08-2007, 09:49 PM
stphotographer's Avatar
You can also remove the wheel and the plastic fender lining and remove the bulb from the back of the headlight.
Old 07-08-2007, 11:14 PM
i know i'm going to need a star shaped tool to remove the cover, where can i get it?
Old 07-08-2007, 11:34 PM
stopmenot2002's Avatar
Do not disconnect Battery. not neccessary, @BULB size D2S <==
On line here is the item Good set to have for a handy guy. Remove wheel for easy acess, then remove all inside front & back fender clips with a flat head crew drive , abit harder for the inside uper clip, but take time. (note: if the fender clip not at position as you try to pry it out, simply turn the whole clip by hand to position for easy crewdriver access)except for one or two bolt on bottom front, and just kinda drop the fender hanging while 1. unplug the wire at the light house 2.remove the security crew, remove the cover by turning it to the left (it's just pressure tight, so use a bit musle to turn & remove that cover)3. Turn the light bulb plug from the bulb lefty, 4. then remove the small safetywire clips(just on upper top of bulb) that hold the bulb to the housing.(try to use the mirror to see how its line up before unclip the safetywire so you know how to put it back after. remove bulb then replace with new, *make sure turn on the light to check for light before putting back everything. http://cgi.ebay.com/SECURITY-TAMPER-Screw-...bayphotohosting
This is the best advice I can give you, Good Luck
STOP2K
Old 07-08-2007, 11:43 PM
CKit's Avatar
Make sure you disconnect your battery first.
Old 07-08-2007, 11:48 PM
blackout's Avatar
I removed a bulb from one headlight to another. The bulb is still good. Just dont handle the bulb with bare hands
Old 04-05-2010, 12:48 PM
Banned
Kyushin's Avatar
D2S bulb? What aftermarket bulbs would be brighter and still compatable to PnP?
Old 04-05-2010, 12:57 PM
Banned
Kyushin's Avatar
Are these good bulbs?
http://www.amazon.com/PHILIPS-6000K-Ultino...e/dp/B000LYRFLC
Quick Reply: HID Replacement
