Video/Sound clip of bad timng chain tensioner
Old 11-21-2007, 02:19 PM
triumph87's Avatar
Default Video/Sound clip of bad timng chain tensioner
For a few days my car has been making a noise in the engine bay, i recorded it tonight and want to see if anyone knows what it could be.
Someone told me it sounds like it could be a bad bearing or maybe a valve?
It does it mostly on hot starts and not every time, when you rev for 1 second the sound will go away.
What do you guys think...
Sound Clip
http://www.youtube.com/watch?feature...&v=fD0wXdMbkUU
Cheapest i have found the part is at Ganley Honda
Replacement
http://ganleyhonda.com/mm5/merchant.mvc?Sc...egory_Code=S7g6
For anyone that is having the same Problem I found a great DIY with pictures
DIY
http://www.superhonda.com/forum/showthread.php?t=307198
S2ki DIY Guide
Old 11-21-2007, 02:40 PM
f23power's Avatar
ahhh that infamous rattling noise. its the sign of a dying timing chain tensioner (TCT). its about a $130 part and 30 min job. it controls the tension on your timing chain. s2000's are notoriously known to have TCT go out. a temporary fix is an oil change. PM "Billman250". he's a got a highly modified GenX TCT. As of yet, honda hasnt acknowledged that its a design flaw. its located under the VTEC solenoid on the bottom left part of the valve cover if your looking from the front.
ive replaced my TCT 2x on my ap1 when i still had it. a buddy of mine replaced his 2nd one within 10xxx miles of installing the 1st one.
-a
Old 11-21-2007, 02:43 PM
triumph87's Avatar
Could it cause any problems, Will my engine get damaged, I wont be able to fix it for a week or 2 because i am not home. Should i take it to the dealership or would this be fixable at home?
Do you know where i could find instruction?
Old 11-21-2007, 02:56 PM
f23power's Avatar
you should be fine...i wouldnt be hard on the car though...the last thing you need is your timing chain going out on you completely and then you'll have bigger issues such as valve train damage.
Heres the part you need
i cant find the write up....but do a search...its around..
-a
Old 11-21-2007, 03:03 PM
FISH22's Avatar
Yes, TCT. Cheap part, and takes about 5 min. to change.
Old 11-21-2007, 03:05 PM
FISH22's Avatar
Here is a lot about the issue. In it theres also a replacement walk-through.
Click me
Old 11-21-2007, 03:10 PM
triumph87's Avatar
Just found that thread thanks everyone for the help, You guys are fast!! that took about 20 minutes for a answer.
Will this be ok for a week or 2 if left alone or do i risk permanent engine damage
Old 11-21-2007, 03:18 PM
Billman250's Avatar
Received 1,253 Likes on 763 Posts
Keep it out of VTEC, you should be fine.
I have a lifetime/modified unit with a permanent fix.
Old 11-21-2007, 03:19 PM
Billman250's Avatar
oh yeah, edit the title for reference
Old 11-21-2007, 03:20 PM
triumph87's Avatar
Thanks billman.
Quick Reply: Video/Sound clip of bad timng chain tensioner
