Replacing a Wheel Stud
I snapped a stud...
I have a new one.
I took the wheel, caliper, caliper mounting bracket, and rotor off.
Then I beat the cut stud out.
but the knuckel is in the way. Sooo... I got to take the whole damn thing apart now, dont I?
anyone ever replace on of these?
Thanks
I have a new one.
Thanks
You should read this
Replacing a wheel stud requires the wheel bearing replaced.
Sucks - I know, from experience. GL
Yeah you have to take the whole knuckle off. Then I would recommend just taking the knuckle into a honda dealer and having the stud replaced, that'll save you most of the labor cost. You have to have new bearings pressed in and its almost impossible to do in your home garage. If you've got a mechanic friend now is the time to call in a favor.
Originally Posted by Mrfixit687,Nov 23 2007, 09:10 PM
how are u guys breaking studs, are you not properly torquing the lugnuts or wat
All DIY for me from now on........or I get Chris (Slows2k) - only prob is - there is about 8-9hrs of driving between us.
im gona replace all the studs deffinatly.
I have a set of hoosiers, toyo RA1s and street tires, so Im changing them alot. I guess I over stressed it a little too much.
all my rears are new, now the fronts are going.
