| Welcome Guest ( Log In | Register ) | Resend Validation Email |
| Pages: (15) « First ... 13 14 [15] ( Go to first unread post ) | ![]() ![]() ![]() |
AusS2000 |
Posted: Oct 4 2009, 10:56 PM
Moderator![]() S2KI User #: 5 S2KI Age: 9 yrs 44 days PPD Average: 8.4 Owner 2000 Silverstone/Red Sydney ![]() |
Another thing to consider is the radius. A fly wheel is much larger than a pulley and torque is measured in ftlb (feet times pounds) so distance from the axis makes as much difference as weight, and in a pulley that 4lbs difference is only about 2 inches from the axis.
ans2k |
Posted: Oct 4 2009, 11:01 PM
Member S2KI User #: 83762 S2KI Age: 1 yrs 197 days PPD Average: 3.8 Owner 2006 Silverstone/Black-Red ![]() |
This post has been edited by ans2k on Oct 4 2009, 11:02 PM --------------------
slackfaster |
Posted: Oct 8 2009, 09:53 PM
Gold Member![]() S2KI User #: 36687 S2KI Age: 5 yrs 136 days PPD Average: 0.6 Owner 2002 Berlina Black/Black lost angeles ![]() |
Here is a twist to this thread... This guy says that OEM dampeners only work at THE OEM RATED HP if you increase your HP then you need to look into an aftermarket dampener or you're potentially doing as much damage as using an un-harmonically balanced pulley. as my dad used to say "how do you like them apples" :rofl"
-------------------- There are only three sports: Bullfighting, Motor Racing, and Mountaineering; All the rest are merely games. -- Hemingway |
ans2k |
Posted: Oct 8 2009, 10:03 PM
^ anyone wants to translate that for me?....
ans2k |
Posted: Oct 8 2009, 10:12 PM
i read the whole article and stile dont get it. they talk about old cars, so that not about the s. the imports are similar to the americans. but i thought our engines are internally balance. twist? vibrations? can someone explain?
S2Kage |
Posted: Oct 9 2009, 06:36 AM
Member S2KI User #: 84329 S2KI Age: 1 yrs 183 days PPD Average: 3.6 Owner 2004 Silverstone/Black Philadelphia, PA ![]() |
What he is saying is that all the assholes who said how important the OEM balanced pulley is are wrong.
Get it now? -------------------- |
o'malley_808 |
Posted: Oct 9 2009, 09:34 AM
Member![]() S2KI User #: 73631 S2KI Age: 2 yrs 114 days PPD Average: 0.8 Owner 2000 New Formula Red/Black ![]() |
People change flywheel weight all the time with no bad side effects, I doubt that a small pulley running a belt is going to make a difference. And as for the people about the harmonic balance they have no clue what they are talking about. Harmonic balancer offsets the weight of the pistons to make the engine run smoother/less vibration.
I would consider this part mainly a cosmetic item with minimal gains, no need to worry about ruining a motor from this part. --------------------
turbosix |
Posted: Oct 10 2009, 08:34 AM
Guest S2KI User #: 84508 S2KI Age: 1 yrs 177 days PPD Average: 2.6 Owner 2003 GrandPrix White/Tan dfw ![]() |
you guys are retarded. the article is from 1979, jesus christ.
-------------------- 1984 buick regal t-type . 1992 lexus ls400 . 2003 honda s2000 |
Voodoo_S2K |
Posted: Oct 10 2009, 10:18 AM
Community Organizer![]() S2KI User #: 4277 S2KI Age: 8 yrs 102 days PPD Average: 4.2 Owner 2002 Spa/Indy Yellow/Black Bay Area, California ![]() |
Nickamsweet |
Posted: Oct 10 2009, 10:23 AM
Member S2KI User #: 83673 S2KI Age: 1 yrs 199 days PPD Average: 2.3 Owner 2000 Monte Carlo Blue/Black Scotland ![]() |
^^ I know exactly what i was thinking... it's the vibration etc in the first place that you want to harmonically dampen... Think we need to put some acceleromators on the end of a balanced and unbalanced and see the difference...
slackfaster |
Posted: Oct 11 2009, 04:17 PM
yeah cause the mechanics of internal combustion engines have changed so much since then... --- kids The the article specifically noted our exact OEM harmonic dampener design (bi-metal separated by polymer) and said that type was engineered for the specific OEM hp rating and, being non-adjustable, couldn't work as designed after the torque and hp increase resulting from aftermarket tuning. He suggested that since harmonic dampening was important for high hp engines, an adjustable aftermarket dampener (which could be tuned to the specific setups) would be a good idea if you were modifying the power of your car. |
GyorsS2000 |
Posted: Oct 17 2009, 04:48 AM
Member![]() S2KI User #: 103737 S2KI Age: 0 yrs 35 days PPD Average: 0.4 Owner 2001 Berlina Black/Black ![]() |
I got the pulley's on my 01, and have had no issues. I got all the pulley's not just the crankshaft. I noticed a rather impressive diffrence after the install. It pulls non stop all the way to redline, and from a dead stop in 1st gear, start to roll without dropping the clutch and at V-Tec engagment the tires break loose. Thats with exhaust, test pipe, and intake. I haven't had any issues yet since the install. I will say that damn crankshaft pulley bolt is a real pain in the ass to take off though!
Locost47 |
Posted: Oct 17 2009, 08:22 AM
Guest S2KI User #: 87039 S2KI Age: 1 yrs 115 days PPD Average: 0 Enthusiast Co.Armagh ![]() |
Hi, I race a westfield with the F20c engine and have had a solid billet crank pully on the engine for three seasons of racing without issue. When the engine was stripped down after two seasons the crank journals and bearings were 110% perfect with no sings of wear. Im also running an exedy paddle clutch and cromolly flywheel. I think the main issue with aftermarket crank pullys is making sure the tolerances are as per the oem pulley. I have heard of the back of the pully which sits in the oil seal either being slightly undersized or oversized causing an eventual oil leak. The pully on my car was made using the specs of the oem pully and was hard adonised to prevent wear from the belt.
iDomN8U |
Posted: Nov 6 2009, 04:59 AM
Member![]() S2KI User #: 58298 S2KI Age: 3 yrs 195 days PPD Average: 3.3 Owner 2003 Silverstone/Black Ontario ![]() |
Still no Dyno
Requiem |
Posted: Nov 7 2009, 05:14 AM
Guest S2KI User #: 97664 S2KI Age: 0 yrs 211 days PPD Average: 0.6 Owner 2000 Silverstone/Black-Red Tampa ![]() |
I ran one on my Eclipse for about 50,000 miles. I never had any problems what-so-ever. I never even noticed more vibration. I was thinking about getting the T1R myself as soon as my Christmas shopping is finished.
wadzii |
Posted: Nov 7 2009, 05:58 AM
Guest S2KI User #: 9588 S2KI Age: 7 yrs 203 days PPD Average: 0.2 Owner 2001 Berlina Black/Black-Red Raleigh, NC ![]() |
the oem pulley is not a harmonic damper or whatever, the rubber in the pulley is to soften the engine pulses going through the belt to the alternator, etc. there is nothing harmonic or balancing about it.
the t1r pulley probably dosnt gain much as its not underdrive, a couple lbs that close to the center of rotation isnt going to do much as someone else here has said.
| Pages: (15) « First ... 13 14 [15] | ![]() ![]() ![]() |
