Sponsor S2000 Suspension, Brake and Handling Deals Sponsor deals on S2000 suspension and S2000 handling products
Suspension Kits: Spoon, Bilstein, KW, Cusco, Endless Zeal, Amuse
Old 08-15-2008, 03:48 PM
GoTuningTommy's Avatar
Default Suspension Kits: Spoon, Bilstein, KW, Cusco, Endless Zeal, Amuse
Suspension Kits from Go Tuning Unlimited
Spoon Full Spec Damper Kit
Spoon Full Spec Coilovers feature a chromoly steel body with aluminum components and perches. Independent compression and ride height adjustability with 45mm piston 1-way adjustable shocks.
Springs Rates: Front 14 kg/mm, Rear 12 kg/mm
Spoon recommended fender ride heights: Front 645mm, Rear 635mm
Spoon Progressive Springs _____________________ Spoon Fixed Type Dampers
Stock Sping Rates: Frong 3.91kg/mm, Rear 5.20 kg/mm
Spoon Progressive Spring Rates: Front 4.7 kg/mm, 6.9 kg/mm Lowers About 25mm
Spoon Fixed Type Dampers can be used with any OEM sized spring. Improves handling with stiffer compression and rebound valving. Designed to be used with high grip radial tires.
We are a DIRECT Authorized Bilstein distributor! Lowest price guaranteed!
Bilstein PSS9 Coilovers
PSS9 - Performance Suspension System with 9 Damping Adjustments The Bilstein PSS9 Suspension is the "race inspired" fully adjustable ride height system featuring mono-tube gas shock absorbers with nine precise damping adjustments. The system includes adjustable mono-tube gas shock absorbers with nine precise compression and rebound settings from comfort to competition, front and rear application. specific, progressive rate springs allow accurate adjustment of vehicle ride height and center of gravity for the level of performance you seek.
KW Variant 3 V3 Coilovers
F&R Spring rate is 515 lbs/in (9.2 kg/mm). KW Variant 3 Coilovers are 2way adjustable with independent compression and rebound damping adjustment.
State-of-the-art technology from motor sports for more performance on the road. The separate and independently adjustable rebound- and compression damping allows for an individual suspension setup for different uses and preferences. The unique patented system with its two-stage valves allows a rebound damping adjustment (comfort) and a compression adjustment (driving dynamics) in the low-speed range while the high-speed range which controls the driving safety, is fixed.
- Damping technology with individually adjustable rebound- and compression technology inox-line* stainless steel technology.
- Individually height adjustable.
- Adjustment parameters approved by the German Technical Control Board (TÜV).
- High-quality components for long durability.
- Infinitely variable rebound damping adjustment.
- 14-way adjustable compression damping.
- Unique, individually working damping force adjustment.
- Comprehensive documentation for easy use.
Cusco Zero 2 Coilovers
Standard spring rates - F:10k/R:12k
High-end coilovers featuring 1way adjustment. Independent ride height and pre-load adjustment for full length adjustment. Includes aluminum upper mounts or pillowball upper mounts. Anti-rust and Anti-corrosion finished.
Cusco Zero 3 Coilovers
Standard spring rates - F:18k/R:20k (custom spring rates available)
High-end Mono-Tube coilovers featuring 24 step single adjustment. Independent ride height and pre-load adjustment for full length adjustment. Includes pillowball upper mounts. Anti-rust and Anti-corrosion finished.
Cusco Zero 3x Coilovers
Standard spring rates - F:20k/R:22k (custom spring rates available)
High-end Mono-Tube coilovers featuring 24 step 3way adjustment and a remote reservoir. Independent ride height and pre-load adjustment for full length adjustment. Includes pillowball upper mounts. Anti-rust and Anti-corrosion finished.
Amuse Hi-Tech Coilover Damper Kit 09 Spec
Amuse Hi-Tech Dampers are manufactured by Bilstein to Amuse specifications. These are far from off-the-shelf shocks. They have Amuse-spec piston diameters, valving, spring heights and spring rates.
Available in 2 versions:
Radial Setting - Includes 7kg/mm Front & 8kg/mm Rear Springs. Very streetable setup. The spring rates are matched to the grip levels of hi-performance radial street tires such as the Advan Neova or Bridgeston RE-01R tire. This setup was used with 255 series RE-01R tires in the Tuner Battle on the touge.
Radial Setting 07 Spec - F:8kg/mm R:8kg/mm
Radial Setting 07 Spec TT - F:10kg/mm R:12kg/mm
S-tire Setting - Includes 12kg/mm Front & 14kg/mm Rear Springs. Helper springs are included for the rear. Designed for track use with R-compound tires. Used on the the Touge Monster in the episode of Touge Showdown when Keiichi named the car the car his favorite touge car.
J's Racing CRUX Full Length Damper Kit w/ Pillow Mounts
Jointly developed with CRUX Engineering, a premier performance / racing suspension manufacturer. The products are designed from enormous data collected from countless field tests on the race track. First, the stroke, damping force, gas pressure are all optimized to achieve the best lap times. Then, feedback information are used to manufacture the best street / performance suspension kits for our customers.
Features:
- Aluminum body damper (front / rear)
- 30 stages adjustable damping force (custom setting of the damping force)
- SWIFT Straight Spring (several choices are offered to match your driving stage)
- Aluminum pillow upper mount for front & rear.
Available in 2 version:
Radial Tire (Street Tires) - Dampers valved for use with 8k-14k Front/Rear Springs
S-Tire (R-Compound Tires) - Dampers valved for use with 14k-24k Front/Rear Springs.
Moton Motorsports Dampers Simply the BEST.
*Available with Hyperco springs and monoball top hats.
2-way, 3-way, or 4-way Configurations
Features
- Monotube design with seperate reservoir - Better heat distribution, large main piston for quick response. Easy to adjust, bump and rebound adjusters can be placed in same spot for quick adjustments without taking the wheels off car. Easy to change springs especially on McPherson struts.
- Large piston rod diameter for more fluid displacement - Much better low speed damper control. Damper responds to the slightest movement of the suspension. Each single click on the adjusters is noticeable to the driver.
- Adjustable Gas Pressure - Added lifting force, able to run softer springs without bump stops or packers. Stabilizes platform when cornering, pitch and squat control without the use of stiff springs. Smoother over bumps and more traction due to softer springs Adjustable between (6-20 bar) (100 – 350 psi)
- Blow off valve system - Blows off at big impacts. Very smooth over Curb stones, car is easy to control. saves drive shafts, wheel bearings etc.
- Rebound adjuster closing off - Precise and repeatable. Each change is noticeable to the driver when adjusting orifices the rebound adjuster.
- Non preloaded valve stack - Smoother response without becoming harsh. Better tyre wear, tyre temperatures and traction.
- General Design - No revalves needed due to large adjustment range, proven reliability, easy to work with, very responsive to any adjustment change, no service and oil change needed during racing season. Cost effective and more time for other issues during racing weekends.
Moton Club Sport 2-Way Coilover Suspension
The Moton Club Sport Damper utilize the same internal technology as Moton's full Motorsport dampers. They offer the same range of adjustment with just 7 position bump and rebound vs. 15 with the Motorsport damper. Dependable and easy to work with, this system will allow you to use a wide range of spring rates and eliminate the worry of having to constantly re-valve every time you want to increase or decrease your spring rate. They do not require constant maintenance to ensure they work properly - you can put them on and drive! They are made with the highest quality materials and workmanship available.
Features:
- Double Adjustable (2-Way Separate Compression & Rebound)
- Large 22mm piston diameter
- External reservoirs with remote lines
- Lightweight aluminum body dampers
- Billet aluminum lower mounts
Zeal Super Function Coilovers
The Super Function is a popular track-spec coilover kit designed for use with S-Tire compounds. The Super Function series consists of five types: A, B, C, D, E. Depending on the vehicle and type of driving, a user can chose from five different types of Super Function coilovers to best suit their needs. The upper mount is a pillow-ball type and the damper case is made of lightweight heat-resistant aluminum. Experience direct suspension feel and less unsprung weight. Recommended for time attack.
Versions:
Type A - 6-Way Adjustable
Type B - 30-Way Adjustable
Type C - 6x6 Way Double Adjustable w/ Remote Reservoir
Type D - 6x30 Way Double Adjustable w/ Remote Reservoir
Type E - 30x30 Way Double Adjustable w/ Remote Reservoir
Recommended Users:
- Those wanting to prove one's real worth on the circuit.
- Those wanting to increase lap times.
Features:
- Independent Height Adjustability
- Damping Adjustable
- Single Inverted Monotube
- Overhaul OK
- Damping Setting Change OK
- Remote Reservoir Included (Type C, D, E)
Spring Rates:
F: 16kg/mm R: 16kg/mm
Zeal Function X Coilovers
ZEAL Coilover suspension systems uses the originally developed X-Coil spring. The height adjustable coilover kit has been designed to capitalize on the linear characteristics of the X-Coil spring. The Function Series line-up has been developed to meet the needs of a variety of different driving stages. The Function-X is a 30-way adjustable coilover kit designed for sporty street use and track use. Function-X has 30-way damping adjustment and height adjustment, designed for sporty street driving and track use. Due to its architecture, changing the damping setting is simple. The chrome-plated damper body and aluminum part prevents rust and keeps the unit lightweight.
Recommended Users:
- Those seeking to improve handling on the track.
- Those who want to be able to fine tune their suspensions for the track.
Features:
- 30-Way Damping Adjustable
- Overhaul OK
Spring Rates:
F: 8kg/mm R: 8kg/mm
Zeal Function Xs Coilovers
ZEAL coilover suspension systems use the originally developed X-Coil spring. This height adjustable coilover kit has been designed to capitalize on the very linear characteristics of the X-Coil spring. The Function Series lineup has been developed to meet a variety of different needs. The Function-Xs has 6-way damping adjustment and height adjustment, designed for comfortable street use. Due to its architecture, changing the damping setting is simple. The chrome-plated damper body and aluminum part prevents rust and keeps the unit lightweight.
Recommended Users:
- Those seeking to improve handling on the street.
- Those who want to be able to fine tune their suspension on the street.
Features:
- 6-Way Dampening Adjustable
- Overhaul OK
- Dampening Setting Change OK
Spring Rates:
F: 6kg/mm R: 6kg/mm
Zeal Function T Coilovers
The Function-T completely eliminates the usage of hexavalent chrome and the shell casing is produced with nickel boron plating. Different from existing chrome plating products, it is much more anti-corrosive and eliminates the spring seat seizing to the adjustable brackets. X-Coils-R spring utilize the newfound performance of the Function-T. 6 and 30 way adjustable options are also available with rigid or pillowball top mounts. Custom spring rates are available for your own custom Function coilovers.
Recommended Users:
- Those who go to the circuits/track for fun and as a hobby.
- Those who see coilovers which are easy for maintenance.
Features:
- 6-Way or 30-way Dampening Adjustable
- Overhaul OK
- Steel Shell Case with Electrolysis Nickel Boron Plating
Zeal Function A Coilovers
The typically delicate aluminum body has instead achieved high rigidity due to the Function-A nickel boron plating which increases resistance to abrasion and high temperatures. The low frictional properties of boron also allow a more direct damping action. X-Coil-R springs utilize the new found performance of the super light weight Function-A. Both 6 and 30way adjustable options are available with rigid of pillowball top mounts. Custom spring rates are available for your own custom Function coilovers.
Recommended Users:
- Those who seek their own custom dampers.
- Those who seek lightweight and high-end materials.
Features:
- Overhaul OK
- All Aluminum Shell Case with Electrolysis Nickel Boron Plating
Mugen NZ Suspension Kit
Springs rates: F: 7kg/mm R: 11 kg/mm
Mugen NZ Coilovers feature single adjustable dampers. Ride height is independently adjustable from pre-load. Includes billet aluminum bottom mounts, reinforced OEM top hats, and all required hardware for installation.
Skunk2 Pro C Coilovers
Skunk2 PRO-C full dampers offer the latest advanced shock technology featuring an adjustable race inspired mono-tube design for dramatically improved handling and cornering performance. The mono-tube design coupled with oversized shafts and pistons help make the PRO-C damper extremely responsive and durable. Each PRO-C kit features precise 12-way adjustable valving and come with CNC-machined forged top mounts with spherical bearings or polyurethane bushings for maximum performance and feel; and have been tested extensively on the street and track. PRO-C dampers features shortened shock bodies and shafts to maintain proper suspension travel on lowered vehicles. Most PRO-C shock bodies are adjustable to allow additional height and preload adjustment and allow the driver to dial in all aspects of the vehicle balance and feel.
� Large Diameter Mono Tube Design
� 12-way Adjustable Precision Valving
� Shortened Shock Body and Stroke
� Adjustable Shock Length
� Adjustable Spring Preload
� Adjustable Ride Height
� SAE9254V Racing Springs
� Forged Upper Mounts
� Triple Upper and Lower Seals
Spring Rates: F:10 kg/mm, R:10 kg/mm
MSRP is :$1,599
PM for special S2Ki Pricing
Stance GR+ Coilovers
9k/9k Spring Rates.
The GR+ is Stance main flagship line of coilovers. Oversize diameter shocks allow large pistons for ultimate performance and response. 15-way adjustable damping allows the driver to tune the shocks for any conditions and handling characteristics. With huge range of adjustment that can be felt and seen, GR+ offers serious performance for all levels of drivers. GR+ coilovers are built with highest quality materials and tolerances to ensure durability and performance.
Features:
* Adjustment Knob15-Way Damping Adjustable
* Upper Pillowball Bearing Adjustable Camber Uppermount
* Upper Pillowball Bearing Pillowball Uppermount
* Spring Cold Wound Linear Spring
* Monotube Inverted Monotube Shocks
* Dustboot Dustboot
* Collar Aluminum Collars & Upper Mounts
* Bracket Height Adjustable Lower Bracket
Shipping/Insurance Info:
- Shipping cost will be determined by location.
- Insurance will be included on all orders.
- Shipping to Canada, Hawaii, Alaska, or international. Please PM me for shipping quote.
- For local pick up please PM me. We are located in Orange County, CA.
- The product(s) will be very well packaged.
Payment Info:
- You can order by phone, email, PM, or through our website at gotuning.com
- We accept Visa, Mastercard, Discover, Paypal, Cash, Bank Cashier's Check.
- All order MUST be shipped to billing address or confirmed address for paypal.
- Paypal payments can be sent to paypal@gotuning.com.
- 8.75% Sales Tax sales tax is required for all sales within California.
GoTuningTommy is offline
Old 08-15-2008, 08:29 PM
bulletS2k's Avatar
pm sent.
bulletS2k is offline
Old 09-05-2008, 02:33 PM
We are offering an SPECIAL Introductory pre-order price for all s2ki members!! Please pm for pricing! We will be receiving these coilovers in 2 weeks!!
Old 09-06-2008, 05:03 PM
Mr. Francesco's Avatar
Price for the Spoon full specs and the various options for the ZEAL Super Functions please.
Mr. Francesco is offline
Old 09-06-2008, 07:33 PM
ofire's Avatar
pm the price for the skunk to 84041 please
ofire is offline
Old 09-08-2008, 08:45 AM
pm sent!
Old 09-12-2008, 04:53 PM
HONDA RR's Avatar
HONDA RR is offline
Old 09-13-2008, 01:14 AM
A51_AP1's Avatar
Exact suspension I'm looking to get. Might be a little bit ahead but can I get a price? Then I could probably dump off 1/2 my NA parts and some more turbo parts plus my KWv3's.
A51_AP1 is offline
Old 09-15-2008, 08:46 AM
pm sent!
Old 09-17-2008, 01:37 AM
Tomatoevo's Avatar
Please pm pricing and approx shipping weight to 78721.
Interested in Spoon & Amuse (high spring rate versions). Is it possible to get Function X in 16k F & 14k R setting?
Tomatoevo is offline
