| Welcome Guest ( Log In | Register ) | Resend Validation Email |
| Pages: (2) 1 [2] ( Go to first unread post ) | ![]() ![]() ![]() |
Spoolin |
Posted: Mar 28 2009, 03:34 PM
Member![]() S2KI User #: 21406 S2KI Age: 6 yrs 334 days PPD Average: 1.2 Owner 2002 Sebring Silver/Black Sellersburg, IN ![]() |
I know the laws of physics and I know what you are saying.......HPx5252/RPM. I know more than you may think I do. This graph you see that I posted is very deceiving and is basically stretched out and flattened. I can go back to the dyno and pull up a graph that is more normal that people see and you will see the increase in hp more on it or the way the curve goes up more than out. The only reason why the HP stays more or less consistant throughout a wide band is because my turbo is running out of steam and I lose 3 psi at the top end. And you do know why that number 5252 is used correct? It's the point at which all engines cross their TQ and HP curves. This post has been edited by Spoolin on Mar 28 2009, 03:38 PM -------------------- -581 whp 440 tq @ 25 psi on 110 octane. -LoveFab GT1 manifold (Jet Hot coated) and 3" DP, T3/T4 Precision 6262sp turbo, AEM EMS, AEM boost solenoid, AEM 3.5 bar MAP sensor, Innovate XD-1 standalone wideband O2, RC1000cc injectors, AEM injector driver, Full Blown twin pump fuel setup, Tial 44mm wastegate, Tial Q BOV, Inline-Pro 3mm HG(8.8:1 CR), Supertech built head, UR 3" dual exhaust, Inline-Pro diff. conversion, Inline-Pro 750 hp intercooler, custom IForged Aero wheels. Built engine, tranny and more boost coming soon.
s2kswe |
Posted: Mar 28 2009, 03:42 PM
Guest S2KI User #: 79525 S2KI Age: 2 yrs 20 days PPD Average: 0.6 Owner 2008 Berlina Black/Black ![]() |
Yes indeed it is, and you have a point about the curve being hard to really judge from the appearance. However, when the curve power curve is going slightly downwards(Which is easy to spot), the torque will be dropping quite significantly.
When I tuned my first project I didn't have electronic boost control, which resulted in a powercurve that was kinda flat from 5000 and up. I was very unhappy with the tune overall as the car went like mad at 4500-7000, but really felt mild above that. This was a lower power level than you are running tho, so the effect may be experienced as worse with smaller power. As long as you are happy about the curve its a good curve right? |
siadam |
Posted: Mar 28 2009, 03:47 PM
Member S2KI User #: 84535 S2KI Age: 1 yrs 257 days PPD Average: 1.5 Enthusiast Around ![]() |
Where is teh video?
-------------------- ![]() Often imitated, never duplicated ® |
Spoolin |
Posted: Mar 28 2009, 04:02 PM
Don't look at the whole upper HP graph, look at the AF at the bottom. See where it stops? Thats where my 9100 rpm redline is. draw a straight line up to the HP graph. Now, look at where the HP starts falling off, thats about 8000 rpm and where my boost started falling to 25 psi. 8000 to 9100 rpm is 1100 rpm of fall off on the graph and isn't much to me at all and frankly, I can't even tell at all when driving. We are going to be adding another spring in the wastegate to up it to 16 psi spring today and may put it back on the dyno to see if it will hold 28 psi to 9100 rpm.
Spoolin |
Posted: Mar 28 2009, 04:03 PM
You asking where we video'd it? It was in Jeffersonville, IN. |
siadam |
Posted: Mar 28 2009, 08:43 PM
I did't see it anywhere? Said video added? |
Ian300D |
Posted: Mar 28 2009, 09:08 PM
Member S2KI User #: 92480 S2KI Age: 1 yrs 66 days PPD Average: 1 Owner 2001 Silverstone/Black ![]() |
-------------------- ![]() See you on the highway. |
Spoolin |
Posted: Mar 28 2009, 09:11 PM
Its in there on page 1 or 2. Youll have to look for my post and copy the link and paste it to open it up in a new browser and youll be able to watch it. Its hosted through streetfire i believe. My tuner/friend posted and made it.
candymanjl |
Posted: Mar 29 2009, 04:21 AM
Member![]() S2KI User #: 15960 S2KI Age: 7 yrs 110 days PPD Average: 0.3 Owner 2005 Silverstone/Black Ft. Lauderdale ![]() |
first off dyno's over mph are annoying, post it over RPM so we can all see what's really happening
just because the power flattens a little up top doesn't mean it's the end of the world. in the end power under the curve gets you down the track faster, more power under the curve, the faster you're going -------------------- 2005 S2000 - Stolen, thieves suck.
Skatethesea |
Posted: Mar 29 2009, 04:44 AM
Member![]() S2KI User #: 76582 S2KI Age: 2 yrs 116 days PPD Average: 2.2 Owner 2001 New Formula Red/Black-Red Va Beach ![]() |
This is sick. God Bless honda engines. They can sure take a beating.
-------------------- VTSC W/AC 305rwhp tuned on AEM EMS ACT HD Clutch and LW Flywheel! 12.5lb boost pulley, 725cc ID injectors, SOS MAP sensor and retune soon. Watch for that 400hp mark!!! ![]()
Sellout |
Posted: Mar 29 2009, 08:32 AM
Guest S2KI User #: 89984 S2KI Age: 1 yrs 138 days PPD Average: 0.4 Enthusiast ![]() |
They always come out over MPH instead of RPM when the RPM sensor gets screwed up. You also lose the torque curve, since that's calculated from RPM on a dyno... |
candymanjl |
Posted: Mar 29 2009, 08:44 AM
oh yeah, forgot about that
AndyFloyd |
Posted: Mar 29 2009, 09:28 AM
Member S2KI User #: 74411 S2KI Age: 2 yrs 173 days PPD Average: 2 Owner 2003 Silverstone/Red ![]() |
sick, i need a 16psi tune. Think maybe blevins wants to do it on stock HG with some blue? eh eh?
-------------------- 03 AP1 silverstone PFAB ELT GT3076R 431whp - 281 ft/lb 12psi 93 octane 462whp - 310 ft/lb 16psi 93+116 octane ( needs ignition ) 91 Honda Prelude 4ws ( daily ) *old ride* 93 miata built engine, 296whp 270ft/lb mustang dyno. 12.2 @ 117mph |
buzz944 |
Posted: Mar 29 2009, 11:33 AM
Member![]() S2KI User #: 84881 S2KI Age: 1 yrs 248 days PPD Average: 1.8 Owner 2005 Silverstone/Black-Red Jeddah, KSA ![]() |
nice number man
Spoolin |
Posted: Mar 29 2009, 12:43 PM
If you look at the dyno sheet of the stock S making 701 whp with a bigger turbo than mine, youll notice we are making about the same TQ. |
Spoolin |
Posted: Mar 29 2009, 12:52 PM
Andy, im sure Blevins wont mind tuning yours. Ill ask him for you or you can give him a call.
Spoolin |
Posted: Mar 29 2009, 01:03 PM
Thanks guys. About the dyno sheet over rpm, we tried that. But because we kept losing rpm signal after about 7500 rpm, it was all screwed up. So we had to just leave it over mph which kinda stretches the graph out and makes things look flat. Im going to go over there and see if we can figure a way to show the rpm graph to show TQ and all but i doubt we ca do it without it being screwed up and the numbers wrong.
| Pages: (2) 1 [2] | ![]() ![]() ![]() |
