Apline x100/x305 Backgrounds
Old 04-30-2009, 04:11 PM
dukegrad's Avatar
Default Apline x100/x305 Backgrounds
I've done some looking into making custom backgrounds for my newly installed iDA-x305. They look sweet and it's a great way to personalize your HU. Didn't see much here on making/sharing custom ones. So....
First of all: mods, is this kind of discussion allowed?
Second, if so, I'll post the APNs for a couple I've done plus instructions on how to do it.
None of this is rocket science and it's not hard to find all the info, but I'd like to encourage some graphics dudes here to create some custom ones for the S2KI crowd
-e
Old 04-30-2009, 05:52 PM
kamal's Avatar
Hey I'd love to figure out how to make custom backgrounds for my x305... post up! I don't see why there'd be any issues.
Old 05-01-2009, 05:16 AM
dukegrad's Avatar
To get things started. Here's what my 305 looks like now...
I took "cdsix's" (pride-rock user) Honda screen and tweaked for what I wanted. Pretty sweet if I do say so myself Keep reading if you want to learn more about the process...
Alpine's i-personallize offering just didn't cut it for me so I started the hunt. As usual, Google was my friend... I don't take credit for any of this. Just summarizing for the group. Thanks to "Mufasa" at Pride-Rock and "xoned.net" for info and tool development. Fine print aside, now here goes...
Prep
1. Go grab XND Converter. This is used to convert the image to Alpine's APN format. Extract this to your 'puter. "C:\XNDConv" for example.
2. Go grab IrfanView. You'll also need the plugin pack for it (that's where the RAW support lives). This is a free image converter tool to change your JPG into a RAW file that XND Converter can use. Install both the app and the plugins. Photoshop or other image proggy might work, but I haven't tried it.
3. Take a picture of your ride (or whatever).
4. Use IrfanView resize/crop down to 320x240. Save as RAW format.
5. I recommend you copy that RAW file to wherever you extracted XND Converter
Convert
6. Go to "Start/Run..."
7. Type "cmd"
8. Browse to "C:\XNCConv" or wherever you extracted the XND Converter
9. If you copied the RAW file in here already (#8 above) type the following: "xndconverter.exe XXXX.raw", where "XXXX" is your file's name.
10. You should get a success message from XNDConverter.
Upload
11. I've found that fewer files are better. Start w/ a blank key just to be safe.
12. Copy that resulting APN file over to a USB key and load into your x305 as normal (settings/display/BGV Download/Start/[select your file]
13. Set your BGV Type to "User" and exit out to see the result.
There is also an all-in-one online tool here but I wanted more control over what got cropped, etc. Haven't used it so you're on your own if you go that route...
Pride-Rock's site is www.pride-rock.com. It's a great resource for more info. He has additional wallpapers here. Note that the wallpapers located there are for AV HUs and are therefore not sized right for the x305 (wrong aspect ratio). No big deal though, just click an image you want, right-click the larger popup to save as JPG. Then crop/resize starting at #4 above.
Enjoy!
-e
Old 05-01-2009, 06:13 AM
kamal's Avatar
Nice, I'll have to fool around with this over the weekend and come up with some backgrounds. Thanks for the info... there's a ton of other x100/x305 users on here that will also find it helpful.
Old 05-01-2009, 06:20 AM
kamal's Avatar
Mind sharing any of the .jpg/.apn files you've already created?
Old 05-01-2009, 07:21 AM
dukegrad's Avatar
DISCLAIMER: The original graphics aren't my own work. I've tweaked them to my liking and converted to APNs... use at your own risk (worked fine for me, but you never know)
Honda (my fav)
Explode
Get both APNs here (link expires in 7 days, can't post these file types here I don't think).
-e
Old 05-01-2009, 07:41 AM
kamal's Avatar
Nice... I'm using that Honda one and I'll post my own creations this weekend
Old 05-01-2009, 08:12 AM
dukegrad's Avatar
Cool! Look forward to seeing your creations. Hopefully some more creative folks than me (maybe that's you?) can come up with some S2K specific ones.
You'll find that putting bright stuff in the middle can make it hard to read the text display, that's why mine are pretty dark. I wanted to do one like Honda version, but with the stylized "S". Didn't get around to it.
Old 05-03-2009, 07:42 PM
9kFever's Avatar
thanks
anyone else make one?
Old 05-05-2009, 04:53 PM
dukegrad's Avatar
9kFever, did it work for you?
Not many interested in this stuff, I guess
I found it cool that it could be done. Maybe it's just me...
-e
Quick Reply: Apline x100/x305 Backgrounds
