Reply to this topicStart new topicStart Poll
Clutch Deceleration Buzz at 2200 RPMs ?
Offline JFUSION
Posted: Nov 12 2009, 03:01 PM
· · · Quote Post
Guest
S2KI User #: 103417
S2KI Age: 0 yrs 44 days
PPD Average: 4.8
Enthusiast
CA -
I have the classic symptom of clutch buzz upon deceleration, but mine seems to occur only at 2200 rpms . Most posts I've read about this seem to have it occuring higher up in the rpms. The vibration I have is only on decleration, pretty much in any gear, off throttle. Acceleration does not produce the noise. The vibration lasts for a few hundred rpms. If I hit the throttle it goes away. Would this still be clutch buzz ?, if it is I'm perfectly fine with it, I just don't want it to be something else like bearings or CV's. Any info would be helpful. thanks very much.
Email Poster  Ignore
Top
Offline starchland
Posted: Nov 12 2009, 04:15 PM
· · · Quote Post
Guest
S2KI User #: 75493
S2KI Age: 2 yrs 66 days
PPD Average: 2.3
Owner
2000 Berlina Black/Black
CA -
hmm it could. 2200 is pretty low rpm i have never heard it this low. have you experienced clutch buzz?
are you sure its not coming from your shifter area or something loose in the engine bay such as the heat shield or an exhaust part?
user posted image199.8 stock whp on a dynojet
user posted image SADD Coalition - S2kers Against Door Dings
user posted image
...I bought a four banger instead :p
Email Poster  Ignore
Top
Offline JFUSION
Posted: Nov 12 2009, 04:28 PM
· · · Quote Post
Guest
S2KI User #: 103417
PPD Average: 4.8
Enthusiast
CA -
QUOTE (starchland @ Nov 12 2009, 04:15 PM)
Yeah I realize it is a lower rpm than others report, but the symptoms sound the exact same. I can't think of anything that is loose, I guess it could be an exhaust part, but who knows. I don't believe it is the shifter at all. I get a buzz at 2200 rpms for a couple hundred rpms only, happens on deceleration with foot off the accelerator, if I hit the gas pedal it goes away. Perfectly smooth above 2200 and below 2000. thanks for the reply.
Email Poster  Ignore
Top
Offline starchland
Posted: Nov 12 2009, 04:31 PM
· · · Quote Post
Guest
S2KI User #: 75493
PPD Average: 2.3
Owner
CA -
hmm does it always do it? not coming from the tranny is it?
Email Poster  Ignore
Top
Offline JFUSION
Posted: Nov 12 2009, 04:47 PM
· · · Quote Post
Guest
S2KI User #: 103417
PPD Average: 4.8
Enthusiast
CA -
yes it always does it, it is 100 percent repeatable. If it is coming from the tranny it doesn't come through the shifter, so I'm not sure. If I drive at 2200 rpms with steady pressure on the gas pedal it won't do it, but let off the gas and it starts. I've only owned the car for 3 weeks, 55,000 miles on it , with the original clutch. Engine, clutch, and tranny run like mint/new condition, no issues to report at all other than this small items.
This post has been edited by JFUSION on Nov 12 2009, 04:49 PM
Email Poster  Ignore
Top
Offline starchland
Posted: Nov 12 2009, 05:21 PM
· · · Quote Post
Guest
S2KI User #: 75493
PPD Average: 2.3
Owner
CA -
replaced any fluids?
Email Poster  Ignore
Top
Offline JFUSION
Posted: Nov 12 2009, 06:16 PM
· · · Quote Post
Guest
S2KI User #: 103417
PPD Average: 4.8
Enthusiast
CA -
QUOTE (starchland @ Nov 12 2009, 05:21 PM)
yeah I've basically gone through and done a full maintenance replacement since getting the car 3 weeks ago. New tranny fluid, new diff fluid, new coolant, a couple short oil change intervals with Honda oil filter, new pcv, fresh brake fluid, fresh clutch fluid, slave cylinder lube, shift fork lube, shifter lube, valve adjustment, new brake pads, new battery, new spark plugs, clutch pedal adjustment, fuel injector treatments, new air and cabin filters, convertible seal lube and latch adjustments, new windshield. The car runs like new other than this one small area.
Email Poster  Ignore
Top
Offline dammitjim
Posted: Nov 12 2009, 07:40 PM
· · · Quote Post
Member
Group Icon
S2KI User #: 101473
S2KI Age: 0 yrs 103 days
PPD Average: 6.9
Owner
2002 New Formula Red/Black
WI
US -
Shift before 2200rpms. Problem solved.
user posted image
Vortech-AEM-Volk-Tein-Comptech
Email Poster  Ignore
Top
Offline ShiftGearAP1
Posted: Nov 12 2009, 11:05 PM
· · · Quote Post
Guest
S2KI User #: 85029
S2KI Age: 1 yrs 163 days
PPD Average: 0.6
Owner
2000 Berlina Black/Black-Red
Chicago, IL
US -
Sounds like my clutch buzz. (year 2000)
user posted image
Email Poster  Ignore
Top
Offline JFUSION
Posted: Nov 13 2009, 03:13 PM
· · · Quote Post
Guest
S2KI User #: 103417
PPD Average: 4.8
Enthusiast
CA -
QUOTE (dammitjim @ Nov 12 2009, 07:40 PM)
well it doesn't bother me the least bit, I just wanted to check to make sure it isn't some other issue.
Thanks for all the replies.
Email Poster  Ignore
Top
Offline starchland
Posted: Nov 13 2009, 03:19 PM
· · · Quote Post
Guest
S2KI User #: 75493
PPD Average: 2.3
Owner
CA -
the s2k as im sure youve heard makes alot of unique and weird noises. most of them being ok. its just the nature of the beast and something you may have missed with the thrill of a new car, and as you drive it you will start to get picky and hear these. thumbsup.gif heart.gif
Email Poster  Ignore
Top
Offline JFUSION
Posted: Nov 13 2009, 03:48 PM
· · · Quote Post
Guest
S2KI User #: 103417
PPD Average: 4.8
Enthusiast
CA -
QUOTE (starchland @ Nov 13 2009, 03:19 PM)
yup that's it, I've repaired lots of little rattles, air leaks and engine items since getting the car. The car is much smoother and quieter now than when I first got it that I notice other little things that I probably didn't notice at first. As long as it doesn't impact longevity it's all fine with me. thanks.
Email Poster  Ignore
Top
Offline Requiem
Posted: Nov 13 2009, 10:17 PM
· · · Quote Post
Guest
S2KI User #: 97664
S2KI Age: 0 yrs 211 days
PPD Average: 0.6
Owner
2000 Silverstone/Black-Red
Tampa
US -
I had this same problem with my first S2000. It definatly sounds like the infamous clutch buzz.
Email Poster  Ignore
Top
Offline Vik2000
Posted: Nov 14 2009, 02:11 AM
· · · Quote Post
Member
Group IconGroup IconGroup Icon
S2KI User #: 73475
S2KI Age: 2 yrs 118 days
PPD Average: 11.3
Owner
2004 New Formula Red/Black
Canada
CA -
could be buzz from TP if you have one...?
WTS/T Bronze Work XD9s
Email PosterMSN  Ignore
Top
Offline JFUSION
Posted: Nov 14 2009, 11:48 AM
· · · Quote Post
Guest
S2KI User #: 103417
PPD Average: 4.8
Enthusiast
CA -
QUOTE (Vik2000 @ Nov 14 2009, 02:11 AM)
Email Poster  Ignore
Top
Online gernby
Posted: Nov 17 2009, 10:40 AM
· · · Quote Post
Member
Group IconGroup IconGroup IconGroup IconGroup IconGroup IconGroup IconGroup Icon
S2KI User #: 8217
S2KI Age: 7 yrs 259 days
PPD Average: 3
Owner
2008 GrandPrix White/Red
McKinney, TX
US -
TP = Test Pipe, but I don't know why anyone would suspect this for a decelleration buzz.
Current S2000:
'08 GPW with Red/Black interior, 18" Work Meister 3pc wheels, OEM front lip, PWJDM Intake, JVC KD-AVX44 DVD Head Unit, Hondata FlashPro on order.
Previous S2000:
'02 Suzuka Blue, Rick's 4.77 Gears and Yellow Box, Custom Wideband Fuel / VTEC Controller, Custom Test Pipe, Innovative Motorsports LM-1 Wideband O2 Controller / Datalogger, AEM CAI w/ Insulator Sleeve, Hondata Manifold Insulator / Spacer, Mugen Thermostat, Fan Switch, Rad. Cap, Denso IK24's, Digrappa X-Brace, Muz 30mm Solid Front Sway Bar, JIC FLT-A2 Coilovers
Email Poster  Ignore
Top
Offline Vik2000
Posted: Nov 17 2009, 01:03 PM
· · · Quote Post
Member
S2KI User #: 73475
PPD Average: 11.3
Owner
Canada
CA -
there've been numerous cases when tp caused buzz due to it hitting the metal. but anyway, shouldn't be the prob for you in this case.
Top
Offline JFUSION
Posted: Nov 17 2009, 03:09 PM
· · · Quote Post
Guest
S2KI User #: 103417
PPD Average: 4.8
Enthusiast
CA -
yeah I don't have a TP, it's all stock. Thanks for the replies on this, it's likely the clutch then if others have had it.
Email Poster  Ignore
Top
Offline mikey0129
Posted: Nov 17 2009, 06:02 PM
· · · Quote Post
Guest
S2KI User #: 41914
S2KI Age: 4 yrs 331 days
PPD Average: 0.1
Owner
So CaLi LA GARDENDA
US -
sounds like a clutch buzz.. mine does it too.. i heard changing the clucth to a newer version eliminates the buzz 03 and up
Email PosterAOL  Ignore
Top
Offline JFUSION
Posted: Nov 17 2009, 07:12 PM
· · · Quote Post
Guest
S2KI User #: 103417
PPD Average: 4.8
Enthusiast
CA -
I had the car at my Honda dealer a few weeks ago getting an alignment done on it. When I went to pick up the car the service advisor said everything checked out well, all of the suspension parts are in good shape. But the mechanic noted an odd vibration in the car, he had no idea where it was coming from or what could be causing it. They recomended that I bring the car back to them in the spring and have them check it over to see what they can find with it. I was very surprised they didn't recognize the vibration, the car runs silky smooth in all respects other than this one tiny deceleration zone. I couldn't have done any worse if I had taken my car to a GM dealer, since the Honda dealer obviously didn't know anything about S2000s. smile.gif
Email Poster  Ignore
Top
Offline JPoon
Posted: Nov 18 2009, 04:54 PM
· · · Quote Post
Guest
S2KI User #: 102336
S2KI Age: 0 yrs 78 days
PPD Average: 0.1
Owner
2001 Silverstone/Black
US -
I have similar buzzing sound in the lower RPM's but mine is mostly from 2500 - 3500 RPM, no matter what the gear, although 5th and 6th arent as noticable than the lower gears. I just assumed this was the clutch buzz, as I couldn't think of anything else it could be.
Email Poster  Ignore
Top
Offline jibber951
Posted: Nov 19 2009, 12:55 AM
· · · Quote Post
Guest
S2KI User #: 98410
S2KI Age: 0 yrs 193 days
PPD Average: 0.2
Enthusiast
CH -
I have an 2001 model, and it does the same thing.
Clutch buzz when decellerating between 4k - 3k, and also between 2,5k and 2k. It's normal IMO, but it can be annoying at times.
Something else i've been wondering about this clutch buzz... does it hurt the car in some way? I always try to make it stop by slightly pressing the gas pedal (because i feel like i'm stressing the clutch otherwise). Am i simply too worried about it maybe?
Email Poster  Ignore
Top
Subscribe to this topic | Subscribe to this forum | Download / Print this Topic
