Intake and Exhaust DIY and FAQ
Because people think that by having a filter outside the engine bay such as the AEM that you create more power.. You are talking about literally a 2-3 hp difference. Hardly worth it imo... A short ram does the job fine and on the plus side you aren't hacking up your car to fit some piece of junk under the hood.
If you want snorkel type intake I would recommend getting a Spoon, or Mugen (or replica of one or the other) Passwordjdm.com actually has one for a little above $1,000 I believe that is provn to make a decent amount of power.
Not necessarily. Depending on the intake the turbulence can actually compromise the velocity of the air and lower air flow into the internal combustion chamber. Depending on which brand you get you will make a bit more power. Either way unless your car is tuned its probably not worth the cost, or chance of hydrolock if the car is driven during the winter.
The reason I actually bought mine was to help with heatsoak which it has. A few hp won't kill me..
Originally Posted by Henwhee' timestamp='1361215382' post='22345633
with a short ram you are most likely losing 2-3hp vs. your stock intake
I enjoy having a short ram because I don't have to worry about hydrolock, it's easier to get to the filter for cleaning, it frees up space in the engine bay, and sounds pretty good
I'm interested in having the UK exhaust done to my stock s2000. I've read through some threads and still a tad confused. How is the best way to actually explain that I want the 32mm exhaust mod done to a muffler shop?
